> 2010 MS3 - Wheels & Tires
Like Tree5Likes
  • 1 Post By Neverlift
  • 1 Post By MikeBavaro
  • 1 Post By KiwiFlavor
  • 1 Post By Silaramic
  • 1 Post By MS3Shadow
 Old 09-21-2016, 11:10 AM   #1
michaelhanson96's Avatar
Posts: 15   (View Stats)
michaelhanson96 will become famous soon enoughmichaelhanson96 will become famous soon enough
Groaned at 9 Times in 3 Posts
Default What rims & tires?
I have a 2012 mazdaspeed3 I want to get xxr 530 18x8.75 +33. But what tires do I put on any recommendations? I live in Southern California there isn't that much rain to worry about. Also will I have to get my fenders rolled? It will be on stock suspension when I first get them. I don't know much about rims and tires, that's why I decided to post about it, thanks for any feedback.
michaelhanson96 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to michaelhanson96 For This Un-useful Post:
g00s3y (09-21-2016), Neverlift (09-21-2016), Vansquish (09-21-2016)
 Old 09-21-2016, 11:11 AM   #2
KiwiFlavor's Avatar
Posts: 2,443   (View Stats)
Sir, please change the term rims to wheels.
Also, Nitto NT05 or RE71 seem to be of choice.
2012 NASA Spaceship Gray MS3
 Old 09-21-2016, 11:25 AM   #3
MikeBavaro's Avatar
Posts: 269   (View Stats)
MikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant future
This the adress to the the best online wheel/tire size calculator that I have ever seen Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
2007 MS3
True Red
HKS BOV-K&N CAI-APV3-CS TMIC
CS Short Throw-Whiteline Bushings-CS Rear Bar
1968 Mustang
Built 289 w/ factory heads
Built C4
Bulit 8" posi
Runs low 14's at 100 flat
MikeBavaro is offline   Reply With Quote
 Old 09-21-2016, 11:36 AM   #4
KiwiFlavor's Avatar
OP! Read this
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS
I myself used to own XXR 530s with the exact same specs. Let me tell you man, you're going to have to roll your fenders flat and cut bumper tabs. Read: A lot of work
Thor Hammer (09-21-2016)
 Old 09-21-2016, 02:01 PM   #5
Originally Posted by KiwiFlavor View Post
OP! Read this
So in all honesty should I just get the xxr 530 18x7.5 +38? It has the same width as stock wheel which is 18x7.5 +52.5.
The Following 4 Users Say NO Thank You to michaelhanson96 For This Un-useful Post:
g00s3y (09-21-2016), stockms3 (09-21-2016), Thor Hammer (09-21-2016), Vansquish (09-21-2016)
 Old 09-21-2016, 02:11 PM   #6
KiwiFlavor's Avatar
Depends. With that offset and width, you will have less of a concave look.
 Old 09-21-2016, 02:13 PM   #7
MikeBavaro's Avatar
You are going to be 14.5mm closer to the brakes and suspension...... I would run spacers
2007 MS3
True Red
1968 Mustang
Built C4
Bulit 8" posi
The Following User Says NO Thank You to MikeBavaro For This Un-useful Post:
 Old 09-21-2016, 02:16 PM   #8
KiwiFlavor's Avatar
Uhh, with +38 offset he will move outwards. Closer to the fender.
PearlySpeed (09-21-2016)
 Old 09-21-2016, 02:17 PM   #9
Are there any cons to spacers, I've heard any type of aggressive driving is not good on spacers. What do you think?
The Following 2 Users Say NO Thank You to michaelhanson96 For This Un-useful Post:
g00s3y (09-21-2016), Vansquish (09-21-2016)
 Old 09-21-2016, 02:18 PM   #10
KiwiFlavor's Avatar
You won't need spacers for that offset.
I use 5mm spacers. No problem. It's a problem if you use spacers that are bigger than 5mm without extended studs.
 Old 09-21-2016, 02:19 PM   #11
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Neutral  -1 score
Aggressive driving on quality hub centric spacers is perfectly fine should you have 12.9+ grade hardware installed. OEM wheels studs are not adequate for spacers + aggressive driving. With a lower offset, you will not need spacers. That is misinformation you can positively ignore. The wheel will be more flush with the body lines & fenders compared to stock.
michaelhanson96 likes this.
Past Mazdas & Speeds
The Following 3 Users Say Thank You to Neverlift For This Useful Post:
anavrinIV (09-22-2016), KiwiFlavor (09-21-2016), Vansquish (09-21-2016)
 Old 09-21-2016, 02:21 PM   #12
MikeBavaro's Avatar
Its not 38mm more offset than stock.... its +38 compared to +52.5, a -14mm differential.
To answer your question OP, spacers can be an issue if you do not have enough thread engagement on your studs. as long as you have enough thread you should be good.
2007 MS3
True Red
1968 Mustang
Built C4
Bulit 8" posi
 Old 09-21-2016, 02:25 PM   #13
KiwiFlavor's Avatar
This is what you posted.
I am well aware of how offset works man. How is a +38 going to be closer to the brake and suspension compared to +52?
Lower offset WILL bring the wheels outside and not inside.
 Old 09-21-2016, 02:27 PM   #14
MikeBavaro's Avatar
Wait..................... I done gone and went full retard. Its been a long day, My bad
2007 MS3
True Red
1968 Mustang
Built C4
Bulit 8" posi
The Following User Says Thank You to MikeBavaro For This Useful Post:
 Old 09-21-2016, 02:29 PM   #15
KiwiFlavor's Avatar
Lol we've all had that day.
 Old 09-21-2016, 02:33 PM   #16
Thanks for the info and the great laugh.
The Following User Says Thank You to michaelhanson96 For This Useful Post:
 Old 09-21-2016, 02:42 PM   #17
KiwiFlavor's Avatar
Are you planning to lower your car at all? Will you have passengers a lot of time?
 Old 09-21-2016, 02:43 PM   #18
Yea and yea.
 Old 09-21-2016, 02:46 PM   #19
KiwiFlavor's Avatar
Then if u dont want all the work, i'd suggest getting something 8" with +38 at the most. U're still going to have to roll your fenders but prob wont be as much as your first option
 Old 09-21-2016, 02:50 PM   #20
So 18x8+38. And as far as rolling fenders you can roll the back fenders on the speed3 right? Because this dude on YouTube had his front rolled and they cut the back and it was a hack job. He had 18x8.5 on coils not sure on offset
 Old 09-21-2016, 02:55 PM   #21
KiwiFlavor's Avatar
Yes. On that link i gave u, u will find that everyone if not most of them have their fenders rolled. You wont need to roll your front.
 Old 09-21-2016, 04:34 PM   #22
How about 18x8 +40
 Old 09-21-2016, 05:14 PM   #23
KiwiFlavor's Avatar
Like i said, go to that link and see what people have. If i were you, I'd roll my fenders anyway.
 Old 09-21-2016, 06:40 PM   #24
Donnyg20's Avatar
Posts: 60   (View Stats)
Donnyg20 is a glorious beacon of lightDonnyg20 is a glorious beacon of lightDonnyg20 is a glorious beacon of lightDonnyg20 is a glorious beacon of lightDonnyg20 is a glorious beacon of lightDonnyg20 is a glorious beacon of light
I have 18x8 et35 lowered on corksport springs on koni orange struts. I don't rub even with 4 people in the car. (No fender rolling done). I also run the stock tire size.
Donnyg20 is offline   Reply With Quote
 Old 09-21-2016, 08:47 PM   #25
Silaramic's Avatar
Posts: 54   (View Stats)
Silaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud of
You've got to be talking about Danny......hahah!
Silaramic is offline   Reply With Quote
 Old 09-21-2016, 09:13 PM   #26
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
Lol, with his ricelands. And said his speed 3 was AWD.
sent from my Nexus 6P
 Old 09-21-2016, 10:27 PM   #27
Yea that's who I'm reffering to.
Rims & Tires josh0408 MazdaSpeed 3/6 - Suspension & Brakes 8 12-27-2010 06:55 PM
Winter Rims/Tires Package or just Tires? Amber3 MazdaSpeed 3/6 - Wheels & Tires 12 12-02-2009 12:20 AM
Page generated in 0.50903 seconds with 26 queries
