Like Tree4Likes
 Old 01-20-2013, 07:13 PM   #481
jcutler0622's Avatar
Posts: 116   (View Stats)
jcutler0622 is a splendid one to beholdjcutler0622 is a splendid one to beholdjcutler0622 is a splendid one to beholdjcutler0622 is a splendid one to beholdjcutler0622 is a splendid one to beholdjcutler0622 is a splendid one to behold
Groaned at 70 Times in 8 Posts
I have been reading for the past 2 hours. I know for most the answer might be simple. Honestly I am kinda heart broken as I was only going to mod on the light side CS CBE/CS SRI and turbo inlet/ racepipe and Forge BPV.
Am I at heavy danger if I drive this way for a couple months without upgrading internals. I have no way to log or and it will be 2-3 months before I can get some kind of data logger/HPFP Internals.
Should I take the intake and RP off until I can get the HPFP internals? Will the Forge BPV effect this in any way and am I safe to leave it on now?
Thanks guys for making the issue clear cut. I just need to be 110% sure I just bought the car last friday my wife would kill me if something went wrong this early. Thanks again.
2010 Mazdaspeed 3
CS CBE//CS RP//CS SRI //CS turbo inlet//Forge BPV//Autotech Internals//Cobb AP//CP-E TMIC//BC Coilovers//Rich Tuned//NGK Iridiums//
jcutler0622 is offline   Reply With Quote
 Old 01-20-2013, 07:29 PM   #482
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
Groans: 106
race pipe and bpv will do nothing but giving you more sound. As far as the intake and tih it is your call I went for about a few months with just a cold air intake and a ap and just monitored my fuel pressure, to be honest if funds is a issue you can always sign up for me bill me later and purchase the internals that way, I would rather pay something off for 6 months instead of having to save money to purchase a new engine.
go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle
suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55
motherfnmonsta is offline   Reply With Quote
 Old 01-20-2013, 07:32 PM   #483
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
Testpipe is just for sound eh?
are you sure?
Sent from a GenPu
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
The Following 3 Users Say Thank You to Zdraveca For This Useful Post:
Easter Bunny (01-21-2013), Hush (01-20-2013), KusteLokal (01-21-2013)
 Old 01-20-2013, 07:35 PM   #484
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
If you don't have an AP, then you really don't know do you? You are probably fine, bit you don't know if you can't monitor.
Tappin'
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
The Following User Says Thank You to ASHMS3 For This Useful Post:
jcutler0622 (01-20-2013)
 Old 01-20-2013, 07:37 PM   #485
Groans: 106
are you sure?
Sent from a GenPu
when mounted to the stock downpipe I would not think you would really see that much gain as you would if where mounted to a catless downpipe to be honest if I am wrong then oops and I am sorry.
But he should get internals before doing anything else especially with his vehicle being a 2010 and getting some age on it,no telling how much stress has been put on his stock internals
 Old 01-20-2013, 07:52 PM   #486
Zdraveca's Avatar
Groans: 145
Blog : Does a downpipe make a difference on a stock turbo MazdaSpeed3? : Stratified Automotive Controls
GT2876r
E85 FREEKTUNE
The Following 2 Users Say Thank You to Zdraveca For This Useful Post:
Hush (01-20-2013), jcutler0622 (01-20-2013)
 Old 01-20-2013, 08:04 PM   #487
Hush's Avatar
Posts: 520   (View Stats)
Groans: 156
Just to be sure...when you say turbo inlet/ racepipe, these are two different things, TIP is attached to your SRI, the Racepipe replaces the mid-pipe and a catylitic converter just below the DP in the exhaust system.
If I were in your shoes....I would take the RP off. Danger is unknown, without monitoring. You might be OK, you might be about to outrun the hpfp. I would tread lightly until I knew for sure, had an AP, and internals ready to go in.
Removing a cat is power gain.
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
The Following 3 Users Say Thank You to Hush For This Useful Post:
DingoDave (01-20-2013), Easter Bunny (01-21-2013), jcutler0622 (01-20-2013)
 Old 01-20-2013, 08:05 PM   #488
So I am going to take the intake off after reading this. Thanks guys. Should I be good with the catless racepipe ( which I know I will see gains from) I did on my previous ms3 gen1's x3.
So untill I get AP and HPFP internals I would be safe running catless RP, CBE and forge bpv right? Or should I wait.
The car has been babied. I know it is 2010. But with only 16k miles on it. All service records, owned by an old man. The car is clean.
suggestions would be great! Thanks guys!
2010 Mazdaspeed 3
 Old 01-20-2013, 08:05 PM   #489
Groans: 106
ya that is for downpipe bro, the guy above mentioned a race pipe which is the mid pipe or some people call a test pipe, that replaces the second catalytic converter, but either way he needs to get something monitor his shit or upgrade the internals, dont want to turn this into a pissing contest or anything so do not take offense to anything I am saying.
The Following 2 Users Say Thank You to motherfnmonsta For This Useful Post:
 Old 01-20-2013, 08:06 PM   #490
Thanks Hush!! Noted.
2010 Mazdaspeed 3
The Following User Says Thank You to jcutler0622 For This Useful Post:
Hush (01-20-2013)
 Old 01-20-2013, 08:13 PM   #491
Zdraveca's Avatar
Groans: 145
are you really going to teach me what replaces what? the point is that you have more gains with TP/RP than dp.
The guy should make himself a favor and take both intake and testpipe unti he gets something to monitor with or internals
GT2876r
E85 FREEKTUNE
The Following User Says Thank You to Zdraveca For This Useful Post:
Hush (01-20-2013)
 Old 01-20-2013, 08:17 PM   #492
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
Testpipe/Racepipe is what makes the power gains while on stock turbo.
@jcutler0622; have an old android device? buy a bluetooth obdII adapter on ebay for $20 and torque with mazdaspeed pids for $15. Easy & cheap way to monitor.
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Hush (01-20-2013)
 Old 01-20-2013, 08:26 PM   #493
Found the adapter. Does an app exist for it? I have an iphone right now not quite sure how I can freak this. What are the mazdaspeed pids for 15 bucks. Thanks for the advice I think I am going to go this route and monitor whats going down.
Thanks again everyone for all help!
2010 Mazdaspeed 3
 Old 01-20-2013, 08:32 PM   #494
alphasaur's Avatar
Groans: 235
I believe torque is only available for android devices.
You can purchase a cheap android device (like a motorola droid) for about $30-$40. The torque application is $5 I believe, and the plugin to read mazdaspeed3 specific parameters is $15. The adaptor is about $20. You're looking at about $80 total.
I'd still recommend an ap over this solution, but it does okay in a pinch.
/speed 3- bye
/lol nator.
 Old 01-20-2013, 08:38 PM   #495
Zdraveca's Avatar
Groans: 145
or he can get this and be done with it UltraGauge Automotive Information Center and OBDII Scan Tool
GT2876r
E85 FREEKTUNE
alphasaur (01-20-2013), jcutler0622 (01-21-2013)
 Old 01-21-2013, 07:05 AM   #496
Had a sweet talk with the wife. Ordering the HPFP internals today. Rolling with the Autotech. Thanks for all the valuable info. Last question. Running just the RP,SRI w/ turbo inlet and CBE w/ the upgraded internals. Should I be good, no reliability issues to worry about? Trying to keep car as close to stock with just a little power. I am not trying to go big at all. AP would be my next upgrade I guess. Breaks my heart I can't do coilovers and rims next.
2010 Mazdaspeed 3
 Old 01-21-2013, 10:18 AM   #497
hippiekid's Avatar
Posts: 4   (View Stats)
hippiekid can only hope to improve
Groaned at 3 Times in 1 Post
Ok in the 6 weeks that ive been apart of this forum I consider myself a short time reader, first time poster, I reciently installed a Cobb AP Checked the two parameters for FP that it monitors( I believe act. press and dis. press) before I installed auto tech HPFP internals, AP was showing at idle about 450ish on both and 1660ish on both accelerating. with new HPFP internals, 550ish at idle on both, and 1660 dis. press, 1760 act.press accelerating. Now for the question, ive read < 1600psi = bad day so A. why did i start with < that (at Idle) and 2. why do I still see 550# after install? I did Install Myself In a CLEANNNN dinning room area, (car was in CLEAN shop as well) IM a Nub, I know this, if the answer is on here and I havent seen it please just give me a Keyword to search for. thanks all
hippiekid is offline   Reply With Quote
 Old 01-21-2013, 10:58 AM   #498
Hush's Avatar
Groans: 156
Not sure if this answers your question, but idle is not the problem, you are OK. It is at WOT that you want to be over 1600psi.
-2012 CWP MS3 -
ASHMS3 (01-21-2013), Easter Bunny (01-21-2013), hippiekid (01-21-2013)
 Old 01-21-2013, 11:13 AM   #499
PUGENE's Avatar
Posts: 1,902   (View Stats)
Groans: 61
I guess it's a really difficult concept.
If you're going to mod the car, get internals. Yeesh, you need a degree in Mechanical Engineering to comprehend that.
AP/Internals should be the first thing anyone should buy for this car. Regardless. You will get more gains from an AP than you will from just an intake/tip...there's no justification in doing it the other way around. One of the most important things you need to do with the car is monitor certain parameters (Act. Fuel Pressure, KR, etc.).
Sorry, end rant, I'm not a gear head, but, cmon.
Precision: PTE 5858
Tial: 44mm EWG
CPE: Stage 2 RMM//Manifold
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
POWERED BY PURPLE DRANK
PUGENE is offline   Reply With Quote
The Following User Says Thank You to PUGENE For This Useful Post:
alphasaur (01-21-2013)
 Old 01-21-2013, 11:18 AM   #500
alphasaur's Avatar
Groans: 235
torque monitors a few parameters the ultragauge doesn't, but it's a nice device.
/speed 3- bye
/lol nator.
 Old 01-21-2013, 11:30 AM   #501
greatdane68's Avatar
Posts: 456   (View Stats)
greatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the world
Groaned at 45 Times in 22 Posts
I've got an SRI on my car, and a Hypertech tuner (couldn't pass up the deal I got on it). I've also got an Ultra Gauge that I can monitor fuel pressure with.
At WOT, I'm getting over 1700 psi on the stock pump, and I peak at 18.71lbs of boost, then smooth out to around 16-16.5lbs.
So far so good for me. I called Hypertech, and they told me that with their tune, I should be good to go as far as a TMIC without upgrading the internals. Only when I do the downpipe will I need internals.
We'll soon find out.
2010 Mazda Speed3
Autotech HPFP internals, Cobb AP V3, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP, Catted DP,
Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ruff Racing 355 wheels, 18x8, +40, 235/40-18 tires
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
2011 Dodge Challenger R/T
1997 Geo Prizm
greatdane68 is offline   Reply With Quote
 Old 01-21-2013, 12:11 PM   #502
Hush's Avatar
Groans: 156
I also use an UltraGauge during the week. Does not replace an AP WOT log, as the hpfp can dip in a split second, and only for a couple of seconds, and that will be the time you are not looking at it. It may not be a total failure, but it is a sign, a sign that something bad might be coming.
I was limping along for 6 months without internals, so I have been there. But I did have an AP, so I could at least see that my hpfp was dipping low after just an SRI and TIP.
-2012 CWP MS3 -
 Old 01-21-2013, 01:24 PM   #503
I haven't seen a dip, but I don't drive my car hard all the time, as I'm sure you don't either.
I'm getting a spare pump soon (only 6000 miles on it), and when I do, I'm gonna rebuild it with some internals, then put it on the car after my warranty expires (along with a downpipe). Unless I see something before then that would warrant me putting it on sooner.
2010 Mazda Speed3
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
1997 Geo Prizm
 Old 01-21-2013, 06:20 PM   #504
hippiekid's Avatar
That helps thank you!
I have been monitoring my KR and During WOT runs I look down and (sometimes) I get up to 1.5 degree reading. When I accelerate at approx 50% throttle, i get (again sometimes) 0.6 degree reading around 3k in 2nd gear. both instances are sparatic and clear quickly.
Is this bad and what should I do? I currently have the auto tech internals and running the OFF THE SHELF stage 1 93 octane v231 cobb AP tune.
 Old 01-21-2013, 06:32 PM   #505
ms3rick's Avatar
Posts: 2,959   (View Stats)
Sri/tip n test pipe I was fine, 1700+
Threw on a stage 1, 4 logs I hit 1 cell of 1599, bought internals and hit up @Lex;
2nd best thing I've done. 1st was donate mod
Partial throttle knock is ok, and under 1.0 is usually false knock
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
Last edited by ms3rick; 01-21-2013 at 06:32 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to ms3rick For This Useful Post:
Hush (01-21-2013), magicka (02-06-2013)
 Old 01-21-2013, 06:32 PM   #506
Hush's Avatar
Groans: 156
^this - beat me - but since I already typed it...
Sporadic KR is pretty normal during regular driving, particularly if motor is cold, again it is at WOT that KR needs to be watched for anything over 1.
-2012 CWP MS3 -
 Old 01-21-2013, 06:53 PM   #507
alphasaur's Avatar
Groans: 235
what's up with you pu owners wanting to spend hundreds on mods but not wanting to spend $300 on a piece that can prevent you from venting a 3-6k motor?
/speed 3- bye
/lol nator.
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
Hush (01-21-2013), PUGENE (01-21-2013)
 Old 01-22-2013, 12:43 AM   #508
I'm planning on doing mine at the same time I do my downpipe. I don't have money to spend on a new engine.
2010 Mazda Speed3
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
1997 Geo Prizm
The Following User Says Thank You to greatdane68 For This Useful Post:
alphasaur (01-22-2013)
 Old 07-06-2013, 10:44 AM   #509
L3THAL6's Avatar
Posts: 168   (View Stats)
L3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the world
Groaned at 6 Times in 1 Post
For anyone who is on the fence or nervous about rebuilding their CDFP, don't be!
Its a simple, quick install. It was actually harder to put my intake on then it was to rebuild my CDFP.
L3THAL6 is offline   Reply With Quote
Cp-e or PTP fuel pumps? manelscout4life MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 99 06-09-2010 04:32 PM
Fake Walbro Fuel Pumps melly mel MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 5 09-01-2009 12:21 PM
2 fuel pumps and a throttle body straydoginc MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-26-2009 09:18 AM
AP users w/upgraded fuel pumps... Speedn3
Cobb Access Port/Maps
30 12-08-2008 06:14 PM
Page generated in 0.51366 seconds with 31 queries
