Like Tree9Likes
  • 3 Post By TWOptSL0W
  • 4 Post By helmetface
  • 1 Post By Voltwings
  • 1 Post By Dust
 Old 08-17-2012, 02:01 PM   #1
f-castrillo's Avatar
Posts: 1,342   (View Stats)
Default Alternate meth controller locations?
Those running a meth kit with an in-cabin controller: where do you have your controller mounted? Mine is currently on the steering column, almost right up against the gauge cluster. I am trying to figure out alternate spots to mount the controller, as it blocks my fuel gauge from time to time, prevents me from using the telescoping steering wheel, and glares when the sunlight hits the controller just right.
Also, would I be screwing up voltage readings from the controller wires to their corresponding parts by lengthening the existing wires with new soldered-on wire? Relocation is something I want to do, but fuck fishing the wires through the firewall again lol
 Old 08-17-2012, 02:27 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
I never really understood the need for an 'in-cabin' meth controller, as it's usually a pre-dialed in scenario based on tuning accommodations etc
Regardless, what about the cubby under the headlight tilt to the left of the steering column?
The Following User Says Thank You to helmetface For This Useful Post:
f-castrillo (08-17-2012)
 Old 08-17-2012, 02:31 PM   #3
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Youre welcome
and make your wires as long as you want
rfinkle2, SLOWHATCH and Sid3wayS like this.
The Following 5 Users Say Thank You to TWOptSL0W For This Useful Post:
f-castrillo (08-17-2012), jdmage_mx5 (10-03-2013), Pointless (01-14-2013), rfinkle2 (01-14-2013), Vader (01-14-2013)
 Old 08-17-2012, 02:34 PM   #4
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
I dont remember what the Genpu dash looks like near the shifter but mine was mounted in the ash tray. It was nice because when i wasnt spraying meth for whatever reason or if i got pulled over i would just close the ash tray door and it was out of sight completely.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
 Old 08-17-2012, 03:15 PM   #5
helmetface's Avatar
Groans: 219
Cop: Sir, your car smells of marijuana, would you mind showing me your ashtray?
You: Um, there's no weed there sir...Just Meth...
Cop: %&#*#(#&$
The Following 12 Users Say Thank You to helmetface For This Useful Post:
ASHMS3 (01-14-2013), atvfreek (01-14-2013), bhamitgeek (09-11-2013), BigjohnB20 (01-14-2013), f-castrillo (08-17-2012), K7addict (08-23-2012), mtnrunner (08-18-2012), myt_tuf1 (01-14-2013), Pointless (01-14-2013), rfinkle2 (01-14-2013), Rich990 (11-25-2012), sidekick (06-24-2013)
 Old 01-14-2013, 11:12 AM   #6
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
I put my controller in the glove box at the back section. Its a snow performance controller and I made a holder for the injection and low level leds so that I didn't have to drill my dashboard.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 01-14-2013, 11:14 AM   #7
Posts: 7,290   (View Stats)
@rfinkle;
Or just ditch the controller and use a pressure switch. k.i.s.s.
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
atvfreek (01-14-2013), gigliotti175 (06-24-2013)
 Old 01-14-2013, 11:27 AM   #8
Voltwings's Avatar
Posts: 3,713   (View Stats)
@rfinkle;
well a pressure switch has its ups and downs as well. Im on a big turbo with a pressure switch but basically to need 400 whp worth of meth on an "on/off" scenario is a bit less than ideal.
For those wanting a 52mm in cabin controller such as this piece ill be picking up to replace my switch:
CMGS Progressive Controller (boost/vacuum)
It will fit in the vent on your drivers side where i currently have my boost gauge. (will be swapped out for 52mm controller)
Edit: Sorry, huge picture is huge -_-
coasttime likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following User Says Thank You to Voltwings For This Useful Post:
f-castrillo (01-20-2013)
 Old 01-14-2013, 03:15 PM   #9
atvfreek's Avatar
Posts: 7,787   (View Stats)
@rfinkle;
I run just a boost switch. 400+ worth of meth too. D10 nozzle and 100% meth. You can't even feel it come on and I have it come on at about 11psi
I've been debating about getting a controller, but at this point, my meth system has been bullet proof for me, so why switch it up.
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 6 Users Say Thank You to atvfreek For This Useful Post:
f-castrillo (01-20-2013), helmetface (01-14-2013), kritz (01-14-2013), p057 (03-28-2013), smr87 (01-17-2013), Voltwings (01-21-2013)
 Old 06-24-2013, 03:11 PM   #10
coasttime's Avatar
Posts: 163   (View Stats)
coasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond repute
Groaned at 19 Times in 8 Posts
Does your air still come out good right where your guage is? I know the GEN1 has a insert for there air ducts it looks awesome. Wish they had it for the Gen2
VentPod Single Gauge Pod for Mazda 3 / Mazdaspeed 3 #EHP-MZ3-VP - Revolution Performance Motorsports!
coasttime is offline   Reply With Quote
 Old 06-24-2013, 03:19 PM   #11
Voltwings's Avatar
Sure does ... and goes right over my shoulder haha
Past:
-Sold-
-Sold-
Current:
 Old 06-25-2013, 01:16 PM   #12
I have been contemplating switching my DO controller to the CMGS one, but I haven't determined if the new controller would be a direct replacement of the DO progressive controller, or if extra wiring would be required. The CMGS would look nice with a defroster vent gauge pod IMO
Sent from my Note II
 Old 06-25-2013, 01:31 PM   #13
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Next to the lighter!
 Old 06-25-2013, 04:07 PM   #14
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
The CMGS can use the same amount of wires. But I have to warn you. The CMGS has alot going on in the back, and no way of disconnecting the wires from the back of the gauge. I had it in a DIN pod and didn't like having to mess with it. Make sure that you have ample wiring behind it. It also has a boost hose for those that want to feed it the old fashioned way.
f-castrillo likes this.
Dust is offline   Reply With Quote
The Following User Says Thank You to Dust For This Useful Post:
f-castrillo (06-25-2013)
 Old 06-25-2013, 05:30 PM   #15
Not too different from the DO controller then, right? It has wires that come out of the side of the unit, and it's fed through the firewall, so I'm thinking install difficulty will be more or less the same for both controllers
 Old 06-25-2013, 06:11 PM   #16
Dust's Avatar
There are at least 2 times as many, and twice as thick.
Meth 4 quart locations? bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 11 04-12-2009 07:04 PM
cpe meth controller and wi system johnac08 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 01-15-2009 03:25 PM
CPE Meth Controller with Custom Kit and Dyno TiZi Custom Performance Engineering (cp-e.com) 30 11-26-2008 05:01 PM
Page generated in 0.38070 seconds with 31 queries
