 Old 07-17-2013, 07:03 AM   #1
greek_dressing's Avatar
Posts: 13   (View Stats)
greek_dressing will become famous soon enough
Default Fuel pump noise?
Hey everyone. I have a '13 speed3. Since last month when I got it, I'm hearing a noise in the engine bay after I shut the car down. Almost a high pitched squealing sound. I've heard it could be one of the fuel pumps de-pressurizing. Has anyone experienced this or have any input?
Thanks!
greek_dressing is offline   Reply With Quote
 Old 07-17-2013, 07:05 AM   #2
PPD369Speed3's Avatar
Posts: 785   (View Stats)
PPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the world
Groaned at 97 Times in 19 Posts
Get used to it, our cars have very loud fuel pumps.
Sent from my HTC One using Tapatalk 2
2011 Speed3
BNR S3 / HTP 3" Intake / Grimspeed EBCS / AT Internals / Cobb AP / UR Catless TBE / ETS TMIC / Forge V1 BPV / JBR 88 Duro RMM / Eibach Pro kit / SPC Camber Arms
Freektune in progress
PPD369Speed3 is offline   Reply With Quote
 Old 07-17-2013, 07:14 AM   #3
ms6mil's Avatar
Posts: 4,972   (View Stats)
ms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the world
Groans: 307
Groaned at 6 Times in 6 Posts
like this Weird Mazdaspeed3 noise - YouTube
https://www.google.com/url?sa=t&rct=...,d.dmg&cad=rja
like he said above, normal. If not the same post a vid of your noise.
"Here am I. Send me!"
____________________________________________
Columbus, GA 2006 MazdaSpeed 6
EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel
GT3076 - 393/380 3/9 e85
GT3076 - 426/400 E85/DO10 Meth
PTE5862 - TBD
ms6mil is offline   Reply With Quote
 Old 07-17-2013, 07:31 AM   #4
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
The sound you are hearing is probably the throttle plate adjusting.
The only high pitched sound the HPFP makes is when the rail valve releases excess pressure.
ms6mil (07-17-2013)
 Old 07-17-2013, 07:48 AM   #5
JgamB's Avatar
Posts: 2,566   (View Stats)
I have the stock TMIC, so I put a lobster on it when I leave work. *Poof* gourmet meal when I reach the house. It usually stops squealing after the first mile or two.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
bob^3 (11-20-2013), ms6mil (07-17-2013), rfinkle2 (07-17-2013)
 Old 07-17-2013, 09:41 AM   #6
That high pitched sound is what mine sounds like
 Old 07-17-2013, 09:58 AM   #7
ms6mil's Avatar
Groans: 307
Normal.
Correct me if I'm wrong but I believe its the drive by wire throttle control system shutting down. (throttle plate motor noise maybe).
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
rfinkle2 (07-18-2013)
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 08:44 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
Is this noise the fuel pump? gsrtype1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 01-02-2009 08:01 AM
Page generated in 0.28680 seconds with 24 queries
