  • 1 Post By JSmith
 Old 05-02-2018, 08:14 PM   #1
Mini Franki's Avatar
Posts: 25   (View Stats)
Mini Franki is an unknown quantity at this point
Default Impossible to get my boost target
Hi,
I actually have a strange problem about my boost target and meth injection. Just for the info, my boost target are 16psi/3000rpm and 21psi/3500rpm(gtx2867r). Forget IAT compensation, i dont have it at this temperature. And, all my 2018 logs were done in the same day
Last year, all was good about my boost target and i had a stable boost on WOT(20.5-21psi). But this year, its impossible to get target and stability. The map is exactly the same. The difference with last year is a new pump(exact same pump) and a catless downpipe(i had a high flow cat)
Now, boost target are very worst. Its pretty hard to get my 21psi. I get my 1st 20psi at 4500rpm and after that still between 19.5-20.5psi(big variation). And i begin to peak over 21-22psi at +5800rpm. Its like ECU trying to compensate the WGDC for get the right boost target and that finish to peak too much at high rpm. So, i tried to climb up my WGDC of +10%. Result, no real difference
At the start, i was sure i had a leak or maybe the catless changed something. So i tried a leak test where my injection is, no leak. So i decided to try my old 20psi map without meth injection(i unpluged my meth controller. Nozzle and check valve still there). Strangly, all my target are good and boost are very stable(19.5-20psi). So, its not because a leak or the catless
Im out of idea, i really dont know what is the problem. I post here my log for help you to understand. There is clearly a problem
Thx for the help!
Wot 4 21psi meth 2017(high flow cat and 500cc): https://drive.google.com/open?id=1qa...o-kwSbVeGjFbA9
Wot 4 21psi meth 2018(catless and 500cc): https://drive.google.com/open?id=1FD...-VFZGwSNA_jY66
Wot 4 21psi meth 2018(catless, 500cc and +10% WGDC): https://drive.google.com/open?id=1To...KXEWsMJtPa1z8Q
Wot 4 20psi meth unpluged 2018(catless): https://drive.google.com/open?id=1tr...lsfx19dweivqja
Mini Franki is offline   Reply With Quote
 Old 05-04-2018, 03:50 PM   #2
I put new link for read files directly on internet
 Old 05-07-2018, 02:48 PM   #3
No idea?
 Old 05-07-2018, 04:29 PM   #4
JSmith's Avatar
Posts: 672   (View Stats)
Groans: 90
Groaned at 6 Times in 6 Posts
So...you removed a cat and didn't retune?
The Following User Says Thank You to JSmith For This Useful Post:
Vansquish (05-07-2018)
 Old 05-07-2018, 04:56 PM   #5
My downpipe had a high flow cat, now im catless. That dont need a retune. That still, im hitting my target when i unplug my meth controller on my 20psi map
 Old 05-07-2018, 08:46 PM   #6
Police - Grammarhead
Vansquish's Avatar
Groans: 1,816
Actually, it probably does.
 Old 05-08-2018, 05:01 AM   #7
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Why reomove a high flow cat anyways? What did that gain you? 5 hp at best, or currently, just a bunch of problems...
 Old 05-08-2018, 09:14 AM   #8
Tuner said that dont change anything to run catless. And i have 3port boost controller so its easy to.control the boost. I changed catless because its less expensive. Like i said 2 times, my boost target are good without injection. So its not because im catless
 Old 05-08-2018, 10:14 AM   #9
Thor Hammer's Avatar
Posts: 1,692   (View Stats)
Groans: 178
Sounds like you should be talking to your tuner.
Did you port the wastegate on your turbo? The Garret turbos are known to boost creep for some. Porting the wastegate hole solves the issue. Or going with an external wastegate. Might be worth looking into.
 Old 05-08-2018, 03:46 PM   #10
I tried, but seem to be too busy for answer me
Anyway, that dont come from the map. Just need people here who know enough about tuning for read my log and see something i didnt. That will help me to find the problem.
I run gtx2867r since 100 000km and i never got problem about boost creep
Ill do another test later, ill try again to do a log with and without injection but now, with the same map. If the problem only appear again when im injecting, the hypothesis of catless or leakage is no longer valid
 Old 05-08-2018, 05:10 PM   #11
Fstrnyou's Avatar
Posts: 1,915   (View Stats)
If hybrid tuned...might be hitting the load limits?
2006 MS6 GT - 161.5k Miles(Forged@157,116)
Manley Pistons & H-Tuff Rods, King Bearings
Versatuner, 3-bar MAP, NGK6510, CP-e TMIC
Russian Bushings in Back, Poly FSB Bushings, Magnaflow CBE, ACT sprung 6-puck/Streetlite
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC/PCV Plate
AWR TMM on stand-by
Other rides:
History:
 Old 05-08-2018, 05:37 PM   #12
Its boost based map, load limits are 3.0
After a test on my 20psi map with and without meth injection, logs are exactly the same. So its finally not the injection fault!
So catless seem to be the problem because all log describe that. It's probably not restrictive enough so it cant hit target in low/medium rpm and try to compensate and finally peak in high rpm. I dont search anymore, ill put back a cat high flow
 Old 05-12-2018, 12:56 PM   #13
After added i high flow cat, problem still there. The only thing changed is, i peak less than before
So last hypothesis is, probably have a leak somewhere. I tried a leak test directly on the silicone tube of the intercooler to TB for see if my injection leaking. At 23psi, no leak from the nozzle
My question is, its normal the psi drop in 15-20 sec? Maybe a have a leak somewhere
thx
 Old 05-15-2018, 03:55 AM   #14
That can be the corksport bpv, i heard some bad review about the wave spring broke. Ill check if it leak too
 Old 05-16-2018, 04:50 PM   #15
Bpv is top shape, wave spring is good. All o-ring are good and greased. Boost leak test is good at 23psi. Im piss offff!!!!
Im totally out of idea
 Old 05-16-2018, 05:47 PM   #16
JSmith's Avatar
Groans: 90
So, you have placed the catted DP back in and now peak (boost pressure) less than before? Thats good.
If you connected at the throttle body (TB) then yes, you should expect pressure to drop, as you are flowing air through the engine. Try checking the TB silicone connection in the direction of the turbo outlet to check for piping leaks? Or get an air compressor w/ a pressure regulator and test at the turbo inlet through the entire intake track.
Adam99l likes this.
 Old 05-16-2018, 07:20 PM   #17
I tested directly on my tb silicone for my nozzle, no leak(check valve removed and nozzle blocked). After i tested all the boost side(blocked the bypass hose), no leak. Yeah I lose maybe 1psi seconde when i test but i put air back in for maintain 23psi the most possible and i dont heard any leak
But the fact is, bpv is like a big hole leak no? If all the boost air go through it and go in the intake , how the motor can handle the boost? How a micro leak can change anything versus bpv
 Old 05-19-2018, 06:16 AM   #18
For info, i have a upgraded tmic, so i dont have a lot of coupler. When i wot, i feel the unstable power caused by the big variation of the pressure(19-21psi)
 Old 05-19-2018, 06:20 AM   #19
Fstrnyou's Avatar
You may need to adjust your boost correction table.
AWR TMM on stand-by
Other rides:
History:
 Old 05-21-2018, 07:09 AM   #20
Boost compensation are the same than all OTS map. But the problem dont come from the map...
 Old 05-21-2018, 07:18 AM   #21
Fstrnyou's Avatar
Your wastegate actuator may be more sensitive to changes in wastegate duty cycle because drive pressures are different. Your boost correction table might now be considered too agressive if you see boost fluctuating trying to hunt the target.
BTW: OTS tunes are cookie cutter junk that are typically only good enough to get your car to run "okay".
AWR TMM on stand-by
Other rides:
History:
 Old 05-21-2018, 07:25 AM   #22
Fstrnyou's Avatar
You lose (leak) 1psi per second and you think it's not a leak? GTFO! I don't believe it's a huge leak, but it's not helping anything.
AWR TMM on stand-by
Other rides:
History:
 Old 05-21-2018, 09:53 AM   #23
I already have 10% of wgdc compensation. Its a BT custom tune and my tuner didnt touch the boost correction table
I dont heard a audible leak if i have one but losing 1psi second seems normal according to the guys of the forum. Because pressure leave by the motor valves, this is not perfectly sealed
The think i dont understand is, all the pressure leave by the bpv hose is like a leak no? So why a little leak somewhere else can play on that?
Since i disassembled, cleaned and greased my bpv, i think that helped. I need to do a log again. Ill maybe buy a new oring kit for it just for be sure
 Old 05-21-2018, 11:38 AM   #24
Fstrnyou's Avatar
The BPV isn't open when you're boosting, so no its not a leak...or at least it shouldn't be leaking.
Your valves should seal pretty good. I'd hate to think it's normal for combustion to blow past the valve into your intake...even if it's a miniscule amount.
During a cylinder leakdown test, ideal would be 100% of the leaking is going past your rings and nothing going past your valves.
AWR TMM on stand-by
Other rides:
History:
 Old 05-21-2018, 12:59 PM   #25
Ok i understand
I didnt do a leakdown test, only a boost test for check leak between turbo and motor. You suggest to me to do a leakdown test?
 Old 05-21-2018, 01:20 PM   #26
Fstrnyou's Avatar
I only made a reference to leakdown test because that is the test to check for leaky valves, injector seals, or excessive piston ring leakage. If your valves are leaking, you've got other problems.
Now, during a boost leak test, you are applying pressure to the back side if the valve. Valve springs are only so strong and excessive pressure in the intake can push them open and leak. I believe that value for our stock springs is near 30psi, plus or minus a few.
AWR TMM on stand-by
Other rides:
History:
 Old 05-21-2018, 03:55 PM   #27
Ok ,ill do a last log for see if problem still there. If yes, ill do a check up at my speed garage
Another thing, when i did my boost leak test, that smelled a bit gaz, this is normal?
 Old 05-22-2018, 06:33 AM   #28
Jeff23spl's Avatar
Posts: 1,446   (View Stats)
When i told him about the leak test pressure and internal drop, i was referring to 1out of 4 cylinders always have open valves so i would be surprise you can inflate turbo inlet side and not lose air inside the engine.
I mentionned the bov leak after he checked the 2 hose of the tmic setup...BTW ....The BPV valve should remain sealed closed under boost. (It should only open under vaccuum)
The o-ring on mine was shot and i had a leak from the top so the piston may not hold the boost correctly just by the spring...
So if you replace your filter by a boost tester and you don't get leaks outside of the engine...That point is good.
Running bt with all sort of mods, i don't think you can expect the tune to react like a clock with always the same exact level and response time you had the week before. Some days it is colder and boost rise faster, some warmer days make it harder for the engine to flow....All the parameters has a margin factor....
I did notice last month that if i ran out of meth, it takes about 10-15sec of pump running full speed to bleed air out of the system....The car will react differently under that condition.
Checking corrections tables could be a good place to confirm the tune allow enough error factor...
Checking the maf cal and fuel trim could be another way to find out if there is something wrong.
Mini-Franki may try to fine tune it with his tuner and probably would need to give a little more room to the error margin...
For the smell, it could be some oil mix from the piping but make sure you don't have a fuel leak around the hpfp/injectors if it really smell like a clean fuel spill...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-22-2018, 07:15 AM   #29
Fstrnyou's Avatar
I want to shoot myself now. I see now that the pressure drop he was seeing wasn't leaky valves, but air sneaking past the rings on the cylinders that had open intake valves.
AWR TMM on stand-by
Other rides:
History:
 Old 05-22-2018, 11:50 AM   #30
@fstr
I cant hate you, you tried to help me and i appreciate it
Car seem to running good since i do a bpv tune up. Grease the oring help to seal and to reduce chance to leak
New orings are coming. Ill give news soon
Thx for help
 Old 06-09-2018, 10:14 AM   #31
Problem still there after new orings
 Old 08-06-2018, 07:34 PM   #32
Solved, changed my 3 way boost solenoid fixed the problem. Very strange, the old one had 2 years...
 Old 08-08-2018, 02:55 AM   #33
mituc's Avatar
Posts: 3,473   (View Stats)
Groans: 111
What brand was it?
2008 Cosmic Blue Mazda 3MPS
SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS
GTX2867R gen2, stock spark plugs, stock intake, stock cats and stock exhaust FTW
self-Versatuned to 22PSI
 Old 08-08-2018, 03:11 PM   #34
That was the Cobb one. But cobb use MAC. I directly bought it from MAC, less expensive when you already have the plug and the fittings
Just got a AP V2. Not hitting target boost. DasItMane MazdaSpeed 3/6 - Turbo Induction 3 07-12-2016 05:42 PM
Car not reaching target boost Pacmonk Mazdaspeed3/6 General Discussion 19 10-16-2015 11:22 AM
Not hitting my target boost TheProYodler 2010 MS3 - ECU Computer Tuning 26 08-11-2014 08:02 PM
Boost based tuning with VersaTuner impossible? EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 15 12-05-2013 09:41 PM
stage2 boost target myslow1 2010 MS3 - ECU Computer Tuning 6 12-12-2011 02:16 PM
Page generated in 0.48001 seconds with 27 queries
