![]() | | #41 | ![]() |
Rep Power: 11933 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,951
Groans: 235
| Not Ranked : 0 score
I plan on running the same exact map that I am running now first with meth off, then immediately turning it on and logging the same exact map, so I will have some hard data. My turbo in the cold is only good for 270 g/s, so if I can pick up a few g/s and have lower iat's, I'll be happy. This summer heat killed my HP and I hope to be able to combat that next summer.
__________________ CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R) ● CPE HPFP ● CPE RMM ● CPE FMIC ● CPE TOW PLATE ● CPE TRITON CBE ● HTP 3" TIP ● HTP BATTERY RELOCATE● COBB AP ● GRIMMSPEED 3 PORT BCS ● COOLING MIST / DEVILS OWN METHANOL INJECTION ● DEFI Boost gauge ● TWM FULL REPLACMENT ● TWM M1 ABRAMS ● JBR SSP ● JBR RSB JBR TIG ● H&R COILOVERS● JUMPING JACKSON 3 BAR MAP HARNESS ● STOPTECH STAINLESS LINES ● AKEBONO EURPO 915a ● TANABE STRUT BRACE ● NEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KIT ● GRAM LIGHTS 57 DR ● TOYO PROXES PLUS | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | cld12pk2go (09-20-2012), SLOWHATCH (09-23-2012) |
![]() | | #42 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8417 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,257
| Not Ranked : 0 score cld12pk2go, what is the density increase of air per mass of methanol evaporated? You can probably give us a better idea given your chemistry background. From what I've read for each 1% by mass methanol evaporated you see about a 3% air density increase and the vapor takes up around 1% of the overall volume leaving you with around 2% increase in mass density and thus flow.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Sep 2011 Location: Georgetown, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Turbo "S" - Water Injection installation instructions - Sept '88
Water Injection in Commercial Aircraft Investigated for Increasing Engine Life and Reducing Costs and Emissions
If I may, you want the incoming air to be as cool as possible, independent of whatever safe way you get there. Making the IC less efficient only matters if you are starting with the same incoming air temp. I’ll take a 50C drop in air temps starting at 100C over an 85C drop at 150C everyday of the week. Spray pre-turbo to decrease the amount of heat put into the compressed air, allow the IC to do it's thing, then spray it again after the IC as it gets into the engine. | ||||||||
![]() | | #44 | ![]() |
| can't take out voltron ![]() Join Date: Apr 2012 Location: Wood-Ridge, NJ
Rep Power: 4920 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,178
You have to think about how fast methanol (or alcohol) is being sprayed and then sucked into the compressor housing and then fed off into the intercooler and ultimately the engine. As the methanol evaporates, air is the immediate surrounding. The evaporation of methanol will certainlly do great things to the charged air. But understand that the temperature of the air leaving the turbo is no where near as high as the temperature of the turbine/center shaft of the turbo. cld12pk2go also brought up an excellent point on the torque loading of the impellar but thats a different story. In regards to cooling, spraying methanal pre-turbo is not going to reduce the temperature to any beneficial amount of the moving parts inside the center housing where longevity of the bearings, shaft, and seals are crucial. You also have to think about the differential between the cooling capacity of the methanol being sprayed and the temperature of the turbo at WOT. This is a bit over-dramatic with our k04, but do you think spraying methanol into the compressor side of this turbo is going to help cool the turbo itself by any beneficial amount? The rate at which exhaust gasses are adding heat to the turbo, is much greater than the rate of heat removal that the evaporization of methanol can provide.
__________________ 2009 MS3 GT: Stock HID's and an NJSPEED3 Mani ![]() ![]() "NJ Nator the home of makeshitfit technology" - voltron "I didn't build it hoping for your approval...I built it because it meets mine." Last edited by ms3blackmica; 09-21-2012 at 01:07 AM. | |
| The Following 3 Users Say Thank You to ms3blackmica For This Useful Post: |
![]() | | #45 | ![]() |
Do I think it will cool it beneficially, yes, if you are using "no spray" as a control. Measurable, I don't know what to use to get in there and measure. Using another nozzle after the IC will drop temperatures more, and the water will drop EGTs, which will drop the amount of red you get in the turbo at WOT. MSD sells water methanol for exhausts if you are really worried about a glowing turbo.
![]() | | #46 | ![]() |
![]() Join Date: Mar 2011 Location: Saddle Brook, NJ
Rep Power: 752 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,195
Groans: 56
__________________ | |
![]() | | #47 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,296
Groans: 212
Also remember how quickly methanol can evaporate in heat it's evaporation is an effect of cooling the volumetric air it occupies.To take advantage of pre meth, you want to get as close to the impeller as possible. This also holds true when using it as secondary fueling as well (close to tbody) Placing the nozzle as far back down stream will not yield the best benefits. Now I did some testing in early 2008 with pre turbo but cannot find the dash hawk logs. Here is a breakdown of what I learned. IAT.. My IAT's would climb and climb and climb doing back to back 4th gear pulls without pre turbo injection. Outside temps were 74f and My IAT's were 189f by the end of the run. They started in the mid 160s. What does this tell you? Heatsoak... Even while moving... Granted, it's not the type of heat soak we see with our intercoolers. However, it's the type of heat soak that affects us by losing power... Now.. Once I plugged the pre turbo nozzle in.... I reran the tests... I was using a DO1 nozzle... Same 4th gear pulls back to back placed my IAT's at 162f... And it NEVER climbed. Not once. So, the heatsoak on the hot side stopped immediately. Now I also want to bring up one Important point and result... Boost increased. I picked up 2psi on the top end. Since our tuning was a risk back then, I stopped running pre injection. Granted, your results will vary based on elevation, turbo, type of methanol and its mixture. Some feel water works best for them pre turbo. I feel it's a lot more dangerous due to possible impeller damage. Some like a 50/50 or various mixture. I prefer 100% here. You BT guys may want to just start out with a 2 gallon nozzle right off the bat. Also, if you do not have a large reservoir, now would be a good time to invest in one. This will also allow you to place your pump directly next to the reservoir and run your check valve from there ![]() rfinkle2 Check this out if you truely want dead center impeller injection. I can't say the benefits are worth the effort, but it gives you an idea of the type of fittings and custom hard lines you will need to pull it off. http://www.supraforums.com/forum/sho...tion-pre-turbo
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
![]() | | #48 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2525 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,593
So I ran the numbers on the delta T from injecting straight meth into the turbo using a modified version of my meth fueling calculator sheet (see yellow rows for the calcs relevant to this discussion). Assumptions: 1.) we are starting with 90°F IAT (typical summer condition) 2.) 260 g/s MAF flow (typical of maxed out K04) 3.) All of the meth is vaporized 4.) 200 PSI meth pressure (reasonable for most people's pumps) 5.) Using the ideal gas law assuming P1, V1, P1, and P2 are all the same and simply solving for the ratio of n2/n1 which will be proportional to T1/T2 in absolute temp to acquire the density changes. ![]() Essentially, the 1 GPH nozzle simply isn't injecting enough meth to do a heck of a lot of temp depression (~9°F). It takes a 3 GPH (~26°F) or 5GPH (~42°F) to really start to have an impact on the order of summer/winter ambient temp differences. I doubt anyone will really see much of an impact from simply running a 1 GPH nozzle, but a 3 or 5 GPH would start to get interesting... Lex, my model shows a 3.7% density increase for each 1% by mass methanol evaporated, which is pretty close to the 3% number you referenced. Since the molar mass of methanol isn't much different than air the 1% volume increase per 1% mass fraction meth evaporated is a very reasonable assumption, but I went ahead and corrected for the ratio of molar masses (28.97/32.04 = .904 = meth only takes up 90.4% the volume of as the same mass of air).
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E30 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 09-22-2012 at 01:52 PM. | |
| The Following 11 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #49 | ![]() |
What would 1 gph do with 100% water?
![]() | | #50 | ![]() |
| Not Ranked : 0 score ~23°F temp decrease , ~3.5% Adjusted density increase.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E30 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | leon78 (09-24-2012) |
![]() | | #51 | ![]() |
So one vote for 2gph at 30% meth or less. Last edited by Dust; 09-22-2012 at 05:48 AM. |
![]() | | #52 | ![]() |
| Not Ranked : 0 score ~37°F decrease, ~5.8% adjusted density increase...
![]() | | #53 | ![]() |
Groans: 212
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #54 | ![]() |
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #55 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 1939 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,593
Groans: 297
Groaned at 186 Times in 102 Posts
Why not dual - one pre-turbo, one pre-tb? Pre-turbo to increase turbo efficiency up top, the pre-tb for temperature?
![]() | | #56 | ![]() |
| Not Ranked : 0 score cld12pk2go thanks for the calculator and confirming this! Would the atomization be similar at much higher meth/water flow levels using similar technology nozzles? Since these are not PWM controlled valves/nozzles I assume a higher flowing nozzle simply has a larger opening affecting atomization and droplet size. So would starting to run a D05 nozzle pre turbo be a little much on the ol' impeller blades in terms of droplet size?
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (09-23-2012) |
![]() | | #57 | ![]() |
Lex, I know that all companies but alcohol injection systems that mention pre-turbo say to stay small. AIS tells users to go big, but he sells mostly to the big boys, where parts don't always need to last for 300K miles.
![]() | | #58 | ![]() |
![]() Join Date: Jan 2012 Location: Sutton, Massachusetts
Rep Power: 827 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 241
Groaned at 29 Times in 11 Posts
Dual smaller nozzles perhaps?
__________________ 08.5' MS3 GT www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
![]() | | #59 | ![]() |
Groans: 212
All pre turbo setups are dual miz...
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() Last edited by Haltech; 09-22-2012 at 06:54 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Haltech For This Useful Post: | rfinkle2 (09-23-2012) |
![]() | | #60 | ![]() |
In the end I look at it this way. If you MUST stay on a K04 or flow limited compressor this may be a good solution for you. Otherwise just upgrade the compressor - there are many choices out there and stick with post turbo WMI to cool the charge. If you're doing this for competition where you are under restrictions and/or are trying to get the most out of a particular setup it can give you a leg up but I'd upgrade a lot of other things before and we already have turbos that outflow fueling as is. Multiple nozzles are a good idea dpolseno41 to keep droplet size small.
![]() | | #61 | ![]() |
Groans: 235
I yield to cld12pk2go and Lex as far as the mathematics involved, but here is a video of nozzle types and their output. Also found these custom pre-turbo meth nozzle holders: Pre-Compressor Jet Holder - Howerton Engineering, LLC
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #62 | ![]() |
It is tempting to add my M3 pre-turbo; however, I am getting silly air flows now with the colder ambient temps... Maybe if I miss the 400wtq to redline next summer...lol
| The Following 2 Users Say Thank You to cld12pk2go For This Useful Post: | ms3blackmica (09-25-2012), rfinkle2 (09-24-2012) |
![]() | | #63 | ![]() |
![]() Join Date: Mar 2012 Location: Eagle River, Alaska
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 115
not to revive an old thread but did anyone end up trying this or not on a ko4???
__________________ 08' MS3 Happily Hypno/Hinefied Tuned pauter rods, cp pistons, arp studs, cometic HG, TurboXS catless DP/TP, TurboXS FMIC w/3" blow thru setup, resonators deleted, JBR WP intake/k&n mini filter,3 bar map, SNOW Stage 2 W/Do7 nozzle pre throttle plate, HKS SSQV4, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, SSP, Cylindrical knob W/3"extender, JBR SB, COBB STS, KMD V2, NGK's. awaiting: HTA3076R EWG, |
| going pre turbo meth injection | Joe Isuzu | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 163 | Today 05:02 AM |
| Turbo Life Expectancy | treyclash | 2010 MS3 - Turbo Induction | 75 | 02-16-2011 08:44 PM |
| Turbo Life Expectancy | treyclash | 2010 MS3 - Engine, Transmission & Driveline | 0 | 07-22-2010 06:47 AM |
| Interesting Article on Pre- turbo meth inection. | gsrtype1 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 12-22-2008 09:33 AM |
