  • 1 Post By zrob88
 Old 06-19-2013, 10:58 PM   #1
zrob88's Avatar
Posts: 52   (View Stats)
zrob88 is just really nicezrob88 is just really nicezrob88 is just really nicezrob88 is just really nice
Default Random fuel cut development
So I developed this random condition whilst driving to work today, did a 3rd gear pull and right around 5000 rpm i hit some wicked fuel cut, same condition on the drive home... Im running an SRI, TIH, OCC, forge bpv, ltr7ix plugs gapped to 032 and the stage 1 SF+TIH 93 tune on my ap... havent had this problem since i flashed to this tune back in january.
didnt do a log but i monitored the fuel pressure and right before it cut i was running around 1600.
I was planning on installing my autotechs this weekend, should i get a fresh set of plugs as well? Any insight as to what my be causing this problem? Also Im running with my egr unplugged but i dont see this causing an issue with fueling but who knows.
2011 MS3 with some bolt ons and other shat...
zrob88 is offline   Reply With Quote
 Old 06-19-2013, 11:12 PM   #2
Plugs are not going to resolve an ECU cut. The first thing to do is to get a WOT log in 3rd gear using the following parameters:
Accel. Pedal Pos.
Actual AFR
Boost
Boosted Air Temp
Calculated Load
Coolant Temp
Engine Speed (RPM)
HPFP Actual Pressure
Injector Duty Cycle
Intake Temp
Intake Valve Adv.
Knock Retard
Long Term FT (LTFT)
MAF Voltage
Mass Airflow
Spark Advance
Throttle Position
Vehicle Speed
Wastegate Duty Cycle
 Old 06-20-2013, 07:04 AM   #3
zrob88's Avatar
did 2 logs and 3 pulls, first log i wasnt able to go past 4k rpm, 2nd pull went awesome from 3k to redline, 3rd pull and log did the same...
Really scratching my head on this one... I appreciate the help Lex hope its nothing serious as im really looking forward to doing my internals and fmic install this coming week.
 Old 06-20-2013, 07:53 AM   #4
cshunter's Avatar
Posts: 1,312   (View Stats)
cshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the world
Groans: 28
Well if you have the internals, put them in as soon as possible, and no wot till then.
In the datalogs you can see your fuel dip below 1600 to just several hundred.
2013 CWP That's slow
2012 LSM Totaled by an asshole red light runner
Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )
Previous: MILTUNED E85 K04
cshunter is offline   Reply With Quote
 Old 06-20-2013, 08:01 AM   #5
zrob88's Avatar
figured that was the problem, ugh. Should have them in this weekend, then ill do a couple logs on the proper OTS tune and see what happens.
 Old 06-20-2013, 08:17 AM   #6
cshunter's Avatar
Groans: 28
Originally Posted by zrob88 View Post
f Should have them in this weekend
That is good.
I know someone who that had happend to before also. They only had an intake and tih.
Thats just the thing with stock internals, is you never know how long they will last till they stop holding.
Good luck with the install, if you have any questions on that there are several "How to" guides on here for those.
 Old 06-20-2013, 08:29 AM   #7
zrob88's Avatar
I have them bookmarked, thanks for the help.
cshunter likes this.
 Old 07-03-2013, 11:57 PM   #8
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
So feeding off this - no AP, but I have something similar to the original description less the RPM - it's not RPM-limited. Any time I get into it, it's cutting.
Any other possibilities? I only have an intake.
 Old 07-04-2013, 11:14 AM   #9
zrob88's Avatar
get some pump internals! and an AP would help to, at very least, do some datalogs
The stockers are a major fail, just with a TIP, SRI and stage 1 flash mine started taking a shit at 35K
 Old 07-04-2013, 02:06 PM   #10
Mizzle's Avatar
Groans: 324
Well, any other reasons it would randomly start cutting? This is literally a one day ok, next day wtf situation.
 Old 07-04-2013, 02:50 PM   #11
zrob88's Avatar
thats what mine started doing, its gonna be hard to pinpoint the cause since you dont have an AP to datalog.
But honestly even without doing a single other mod the autotechs or KMDs will help you out, youll never have to worry about running lean again.
thats about as much as I know someone may be able to help further but all i can say is that its probably time to upgrade your pump internals
Report: General Motors, BMW to shack up on fuel cell development Haltech Automotive News 0 12-12-2011 07:40 AM
Random Raw Fuel Smell labikesrcool Mazdaspeed3/6 General Discussion 5 07-05-2011 08:53 PM
Report: Toyota and Daimler planning "extensive cooperation" on fuel cell development Haltech Automotive News 0 05-27-2010 02:40 PM
Obama kills development of hydrogen fuel cell vehicles Haltech Automotive News 0 05-08-2009 03:20 PM
Page generated in 0.30692 seconds with 24 queries
