> 2010 MS3 - Car Audio & Electronics
 Old 02-08-2011, 06:05 PM   #1
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Groans: 24
Default 2010+ Heated Mirrors?
I remember back in the day, that if you bought the first gen mirrors from Canada (with defrost/heated mirrors), they were automatically wired when you pressed Rear Defrost on a US MS3.
Are the 2nd Gen 2010+ MS3's the same way? Where Canada gets heated mirrors and US cars are wired, but not equipped?
Mike
 Old 02-08-2011, 07:01 PM   #2
zatara's Avatar
Posts: 1,499   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
This should get you going, Silver: oem heated side mirrors
zatara is offline   Reply With Quote
 Old 02-08-2011, 07:12 PM   #3
Groans: 24
Pretty sure that's for first gens though, and I have a 2011.
Mike
 Old 02-09-2011, 08:28 PM   #4
zatara's Avatar
For the 2010 model everything is located where it needs to be so if you purchased the heated mirrors from a vendor, they would be a simple plug and play solution. They would just come on with the defroster.
Now I can't say with certainty that it's the same with the 2011, but I don't see why it would have changed since then. If you can find the part # for the Canadian 2011 heated mirrors, they should work in yours without issue.
 Old 02-09-2011, 08:52 PM   #5
Groans: 24
Do I need the entire mirror assembly? Or just the mirror glass themselves?
Mike
 Old 02-09-2011, 08:57 PM   #6
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Just the glass.
 Old 02-09-2011, 09:00 PM   #7
Groans: 24
What's so special about the glass then if canadian glass defrosts but the us glass doesn't? Sounds like if it's just the glass, then there is wiring involved..
Mike
 Old 02-09-2011, 09:04 PM   #8
wolly6973's Avatar
Groans: 386
Yes there is wiring... Did you look at the How-to thread linked? It is the same for genpu.
You don't necessarily need canadian glass, just one that has heaters on it like the 3 GT has.
Here is a link to another write-up that does it a little easier way...
http://mazda3revolution.com/forums/2...r-install.html
heated seats on a 2010.. thenewzolt 2010 MS3 - Car Audio & Electronics 16 11-12-2010 08:41 PM
oem heated side mirrors cosmicspd3 MazdaSpeed 3/6 - Appearance 46 03-12-2009 11:39 AM
Page generated in 0.27415 seconds with 22 queries
