> 2010 MS3 - Car Audio & Electronics
Like Tree3Likes
  • 1 Post By bioevolve
  • 1 Post By Jzen16
  • 1 Post By tom clement
 Old 03-16-2014, 01:01 PM   #1
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Default Backup Camera from ebayz
Easy install, just head unit takes some time to get behind.
Buncha wires an stuff.
Drilled in the bumper, above the license plate. Was thinking under the wing, but didn't know if it was hollow all the way to the mount points. That would have gotten a higher view range. (I know it's dirty, but that is the way I like'em!)
Drain plug from drivers side rear quarter panel area, cut some slits.
The wire thru it.
just kept slipping the wire along the paneling fast.
Plastic putty knife works just as good as a more costly dash removal tool lol.
Pain the ass two screws to finally release the head unit from the dash, glove box had to come out to get to them screws.
Shove all the extra wire behind the unit's housing resting point.
Tested everything before putting it back together.
All done. Now I can see who I'm running over.
Rob@Freektune likes this.
The Following 9 Users Say Thank You to bioevolve For This Useful Post:
ABOSWORTH (04-17-2014), AllLostThings (04-18-2014), Block8head (03-16-2014), bstover17 (04-18-2014), Ferdball (05-22-2014), JgamB (03-16-2014), nighthawk358 (03-16-2014), Rob@Freektune (05-22-2014), white'swhiteMPS (03-16-2014)
 Old 03-16-2014, 01:59 PM   #2
Block8head's Avatar
Posts: 4,345   (View Stats)
Block8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the world
Groans: 206
Is that the factory head unit?
Link to the camera..
O4 350z "Money pit"
06 MS6 "Gone"
BOSTON STRONG
Block8head is offline   Reply With Quote
The Following 2 Users Say Thank You to Block8head For This Useful Post:
bioevolve (03-16-2014), curving_edge (05-22-2014)
 Old 03-16-2014, 02:09 PM   #3
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
how well does it work at night?
ebay link?
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
 Old 03-16-2014, 02:13 PM   #4
Spinnbait's Avatar
Posts: 188   (View Stats)
Spinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the worldSpinnbait is the leader of the world
Groaned at 11 Times in 2 Posts
I really like that camera. The one I bought for my 5 series is way too big due mostly to the mount.
Spinnbait is offline   Reply With Quote
The Following User Says Thank You to Spinnbait For This Useful Post:
 Old 03-16-2014, 02:42 PM   #5
Alittle Faster
bioevolve's Avatar
Yes Factory Tech Package.
2013 2014 Mazda Back Up Camera System | eBay
ebay link?
Will take a picture at night today.
See above for link.
I like it too, small and compact.
The Following 2 Users Say Thank You to bioevolve For This Useful Post:
alphasaur (03-16-2014), Block8head (03-16-2014)
 Old 03-16-2014, 06:09 PM   #6
white'swhiteMPS's Avatar
Posts: 639   (View Stats)
white'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the world
i need this to work with the 2012
2012 MS3 CWP- Cobb AP, CS CBE, CS SRI/TIH, UR testpipe, Corksport Downpipe, JBR 88 duro RMM, NGK step colder plugs, Autotech HPFP, ETS TMIC, Koni Yellows, Swift Spec-R Springs, Forge V1, Corksport Hoodscoop (cooler BATs, yo)
Enkei RPF1 (gold) 17x9 +45 w/ Conti procontacts 245/45
Freektuned- E85 4/8gal mix
white'swhiteMPS is offline   Reply With Quote
The Following User Says Thank You to white'swhiteMPS For This Useful Post:
 Old 03-16-2014, 07:12 PM   #7
someguy's Avatar
Posts: 914   (View Stats)
someguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the world
Groans: 24
Groaned at 166 Times in 32 Posts
My head came equipped with dual back up cameras...they have direct neural interface too.
(why anyone would need a backup camera on a MS3 is beyond me)
That said, well done on the install, can respect that part lol
- 2010 Mazdaspeed 3 Black Mica -
- Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 -
- SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace -
- CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint -
someguy is offline   Reply With Quote
The Following User Says Thank You to someguy For This Useful Post:
 Old 03-16-2014, 08:46 PM   #8
Alittle Faster
bioevolve's Avatar
This should work with the '12.
LoL, Cuz it's fun to MOD (functional or not, it's enjoyable!). Besides, gotta watch out for those garden gnomes, they are really small people to spot.
Night shot is good and clean with bright backup lights.
 Old 04-16-2014, 10:06 PM   #9
JMONTI's Avatar
Posts: 27   (View Stats)
JMONTI has a spectacular aura aboutJMONTI has a spectacular aura about
WILL THIS CAMERA WORK WITH EONON HU?
JBR SRI // TIP // RMM 88 DURO // AT INTERNALS // AP V3 // STRATIFIED OTS STAGE 1 // NGK SPARK PLUGS // 50% 93 OCTANE 50% E-85 // H&R SPRINGS // SPC REAR CAMBER ARMS // 5000K DDM HID'S // 35% FRONT 15% REAR CERAMIC WINDOW TINTS // CPE TOW PLATE // ZAPTEK PAINT PROTECTION //
JMONTI is offline   Reply With Quote
The Following User Says Thank You to JMONTI For This Useful Post:
bioevolve (04-17-2014)
 Old 04-16-2014, 10:55 PM   #10
Jzen16's Avatar
Posts: 166   (View Stats)
Jzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond reputeJzen16 has a reputation beyond repute
Groaned at 4 Times in 1 Post
omg just saw this thread....I always keep finding places to dump my money... >_< this will def be on my list along with heated seats and homelink lol
'13 BM w/ tech
Autotech HPFP - Cobb AP v3 - CP-E Catted DP -OBX Cat-back - CS SRI/TIP - UR FMIC - HKS SSQV4 - JBR RMM - Stratified Tuning
Eibach Springs - SPC RCA- Ralliart MF - Mugen Visors - 06-07 STI lip - MZ sides/rear - Glowshift A-Pillar Pod/Gauges - DDM 6k low/3k fog - Lamin-x yellow fog light cover - Bluebatmobile red tail light overlay - CS led kit - BLOX Neochrome shift knob - 20% all around
Jzen16 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jzen16 For This Useful Post:
bioevolve (04-17-2014), Rob@Freektune (05-22-2014)
 Old 04-17-2014, 05:26 AM   #11
ABOSWORTH's Avatar
Posts: 455   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
Pretty sweet! I'd look into this but I don't have the Tech package head unit.
What mount are you rocking for the AP?
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
The Following User Says Thank You to ABOSWORTH For This Useful Post:
 Old 04-17-2014, 07:14 AM   #12
Alittle Faster
bioevolve's Avatar
Not sure about the hook up plugs, but you sure can make it work!
LoL.
Scosche Vent Mount.
Installed the Scosche Vent Mount w/ COBB APV3
 Old 04-18-2014, 06:51 PM   #13
steevieg's Avatar
Posts: 155   (View Stats)
steevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond repute
my jaw literally dropped when i saw this.
but i don't trust myself with doing something like this anyways lol, nice job.
2013 Mazdaspeed3 CWP + Tech Package
CPE Catback | Cobb Downpipe | JBR SRI | JBR TIP | JBR RMM
steevieg is offline   Reply With Quote
The Following User Says Thank You to steevieg For This Useful Post:
bioevolve (04-19-2014)
 Old 04-21-2014, 10:13 AM   #14
05cyclone's Avatar
Posts: 95   (View Stats)
05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world05cyclone is the leader of the world
That looks really good. Just added this to my list.
Traded in 7/31/142013 LSM MS3 w/tech
Autotechs-Cobb AP Stage II Map
CS Stage II Intake-CS Hood Struts-CS Interior Leds
JBR Heavy Knob, SSP, Bushings and RMM
UR Test Pipe-Custom Cat-back
OEM Visors-Yellow Fog Overlays
Prosport Boost Guage in a Block8head pod
Waiting to be installed: JBR spacers and mudflaps
05cyclone is offline   Reply With Quote
The Following User Says Thank You to 05cyclone For This Useful Post:
bioevolve (04-21-2014)
 Old 04-25-2014, 03:34 PM   #15
MMApex's Avatar
Posts: 61   (View Stats)
MMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud ofMMApex has much to be proud of
Thanks for the write up, I am going to do this soon, because why not
2013 MazdaSpeed3 - Silver w/Tech
CS SSP | JBR SSB | GW1 DashCam | Euro Rear Fog
MMApex is offline   Reply With Quote
The Following User Says Thank You to MMApex For This Useful Post:
bioevolve (04-25-2014)
 Old 04-25-2014, 05:40 PM   #16
steevieg's Avatar
does the dash come off by just prying? never done it before and don't wanna mess anything up
 Old 04-25-2014, 05:45 PM   #17
Alittle Faster
bioevolve's Avatar
IT's a mod lol.
The vent part does. You'll see screws, just take your time.
 Old 05-22-2014, 01:56 PM   #18
curving_edge's Avatar
Posts: 32   (View Stats)
curving_edge is a glorious beacon of lightcurving_edge is a glorious beacon of lightcurving_edge is a glorious beacon of lightcurving_edge is a glorious beacon of lightcurving_edge is a glorious beacon of lightcurving_edge is a glorious beacon of light
I almost cant believe my eyes! ^_^ I have a 13 Speed3 with Tech pack and it seems all I have to do is run the damn wire to the HU and plug it in?! Hit reverse and it pops up automatically?
Well now... major props to you OP.
2013 Speed3 Tech - (JBR RMM, JBR Shifter Bushings, Voodoo Shift Knob, MS6 Horn Upgrade, Fog Light Mod, RallyArmor Flaps, Mazda Rain Gaurds, 65% Xpel Coverage, and 15% Tint)
2006 Speed6 GT - Wife's car (Stock until she notices...)
2002 Miata (lots of mods) Purchased: 8/2010 --- Sold: 2/25/2014
curving_edge is offline   Reply With Quote
The Following User Says Thank You to curving_edge For This Useful Post:
bioevolve (05-22-2014)
 Old 05-22-2014, 02:42 PM   #19
attomica's Avatar
Posts: 169   (View Stats)
attomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond repute
Groaned at 14 Times in 5 Posts
Originally Posted by curving_edge View Post
...all I have to do is run the damn wire to the HU and plug it in?! Hit reverse and it pops up automatically?
Same questions. That looks great!
attomica is offline   Reply With Quote
The Following User Says Thank You to attomica For This Useful Post:
 Old 05-22-2014, 04:12 PM   #20
Alittle Faster
bioevolve's Avatar
Basically it.
 Old 07-21-2014, 02:05 PM   #21
verbalparachute's Avatar
Posts: 23   (View Stats)
verbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud ofverbalparachute has much to be proud of
I just did the same install this weekend.
The wire is a direct plug in to the back of the head unit. Run the cables to the back (this takes the most work of the whole process), mount the camera and voila. The way it all comes together looks like a BU camera was part of the original idea for the car but tossed late in the process. It all works seamlessly.
As for why? Because I have dark tint and visibility sucks at night. Now, I have no problems.
2013 MAZDASPEED3
COBB SRI / COBB TIP / FORGE RECIRC VALVE / AUTOTECH HPFP INTERNALS / COBB AP V2 / ULTIMATE RACING CATLESS TEST PIPE / FREEK OTS MAP / JBR TRU TORSION 125 REAR SWAY BAR
verbalparachute is offline   Reply With Quote
 Old 12-26-2014, 09:28 AM   #22
MMApex's Avatar
Does anyone know the name of the adapter (or part #) that plugs in the back of the head unit with the rca adapter/power wires? I bought a camera and of course it did not include that.
 Old 12-28-2014, 12:47 PM   #23
Oni
Oni's Avatar
Posts: 565   (View Stats)
Oni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the world
Search youtube. I'm pretty sure I saw a how-to vid for this mod up there that had a parts list.
Sent from my iPad using Tapatalk HD
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
 Old 01-07-2015, 09:22 PM   #24
insain's Avatar
Posts: 15   (View Stats)
insain has a spectacular aura aboutinsain has a spectacular aura about
Bioevolve, from the second install pic, after drilling the bumper was it hard to fish the camera's wiring through the styrofoam in between?
insain is offline   Reply With Quote
 Old 04-02-2015, 10:29 AM   #25
Ksky90's Avatar
Posts: 1,026   (View Stats)
Ksky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the world
Hate to necro this thread but I just saw it and now I'm really intrigued. I bought the camera a few minutes ago, what I wanna know is is it possible to make it so the wire is completely hidden from the camera to the head unit? A stray wire would drive me crazy.
Had a Big Turbo '13 Speed3 WMI and 400 ponies.
Now I have a '13 WRX and zero ponies
Ksky90 is offline   Reply With Quote
 Old 05-06-2015, 03:02 PM   #26
steevieg's Avatar
yea, just hide it in the panels/weather stripping and run it through the glove box.
just a side note, i wouldn't trust the lines for parallel parking if you put it in the same spot as op.
 Old 05-06-2015, 03:04 PM   #27
Ksky90's Avatar
I actually got this in about a month ago. All hidden. The camera is OK I suppose. Does it's job of showing me what's behind me but I wouldn't use it for parking like you said. Its really hard to get it angled correctly so the lines aren't precise.
 Old 01-27-2017, 06:58 AM   #28
tom clement's Avatar
tom clement is a jewel in the roughtom clement is a jewel in the roughtom clement is a jewel in the rough
Did you get this? Does it work?
2013-2015 Mazda CAR Back Up Camera System Rear View Camera Kit INCLUDING HARNESS | eBay
El Beaner likes this.
tom clement is offline   Reply With Quote
Pioneer Backup camera issue jpshotya 2010 MS3 - Car Audio & Electronics 5 03-14-2014 03:23 AM
HOW-TO: Rearview/Backup Camera skeurton 2010 MS3 - How-To's 26 07-15-2013 06:53 AM
Backup camera on CX-7 Uther CX-7 > Car Audio & Electronics 6 07-11-2012 10:41 AM
backup camera help dgillie CX-7 > Car Audio & Electronics 0 04-15-2012 09:12 PM
Page generated in 0.51199 seconds with 38 queries
