![]() | | #1 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score
Did anybody install the Mazda Homelink mirror 0000-8c-z27. I would like to buy one as long as the install isnt to difficult.
| Certified Mazda Nut ![]() Join Date: Jan 2009 Location: Goffstown, NH
Rep Power: 72 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 199
Groans: 28
Groaned at 8 Times in 7 Posts
Sorry had mine installed in port before delivery.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Chuck Norris puts the FUN in funeral. | ||||||||
![]() ![]() Join Date: Mar 2009 Location: Phoenix, AZ
Rep Power: 19 ![]() ![]() ![]() Thanks: 2
I might be interested in installing one of these in my car since it did not come with it. Keep looking and let me know how the install goes! Good LUck!
__________________ 2008.5 BlackMica Mods: - Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it. AZ Status! | ||||||||
![]() | | #4 | ![]() |
I contacted Cardinaleway Mazda and they said they sent me the instructions (twice) but for some reason Im not getting them. I gave the parts guy my email on the phone and he sent it while I was talking to him and nothing. I just got them. Its 8 pages long. Last edited by MarMugMot; 12-23-2009 at 02:16 PM. Reason: MSF Database - Automerged Doublepost | ||||||||
![]() | | #5 | ![]() |
| The Enemy (Car Salesman) ![]() Join Date: Sep 2009 Location: Los Angeles
Rep Power: 383 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,836
Groans: 77
Groaned at 27 Times in 24 Posts
__________________ 2010 Rocket Ship Black Mica w/ Tech Package 18x8.5 Hyperblack Rota SVN 48mm Offset - 235/40/18 Nitto Invo - JBarone Short Shift Plate - E4Performance Shifter Base Bushings - CP-E Turbo Inlet - CP-E CAI With Prefilter - CP-E HKS SQV Kit - Ultimate Racing Catless Test Pipe - CP-E Rear Motor Mount 75 Durometer - Spare Tire Delete | |||||||||
![]() | | #6 | ![]() |
I just skimmed over them. You need to remove drivers side scuff plate,kick plate, door seal,A-pillar trim and of course the mirror. Then run the wire, tap into the harness, connect the ground. Now you have to drive around in a slow circle 3 times to calibrate the compass. It seems easy enough. I might try it because I hate having the garage door opener on my visor.
![]() | | #7 | ![]() |
![]() ![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 27 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
The only other caution I'd offer is that if you have rain sensing wipers, be very careful when you put the new cover on (mine had a different cover than the original). I had trouble getting the wires into the channel and pulled it back off-breaking one of the clips. The original cover (the black box that surrounds the mirror mount/rain sensing wiper sensor) clips to the mirror itself. The new mirror cover clips to the rain sensing wiper box mounted on the windshield. If you pull too hard to remove it, you'll break the clips holding the sensor together. Not trying to freak you out-just be careful and patient... Let me know if you have questions-I'm pretty sure that if you have rain-sensing wipers, the install is the same. You also will most likely NOT have to drive around in 3 circles. I installed mine at work during lunch and drove home after work. By the time I got home, my compass was calibrated...I live a mile from my office. | |||||||||
![]() | | #8 | ![]() |
Did the installation kit come with the fiber stick to remove the OE mirror? If not what did you use? I ordered it for $224.50 Ill keep you posted on the install. Last edited by MarMugMot; 12-25-2009 at 06:21 AM. Reason: MSF Database - Automerged Doublepost | ||||||||
![]() | | #9 | ![]() |
I installed it yesterday.There were only two real hard parts. The A-pillar trim has a little black Knob inside around the airbag that you have to turn and push to release. Then connecting a wire connector up under the dash. When I say up under the dash , its UP under the dash. It works great. It auto dims and has Homelink , so no more garage door opener on the visor. You do need to drive around in a circle 3 times at 5 mph to set the compass or it will just stay in calibration mode. | ||||||||
![]() | | #10 | ![]() |
| Knock Retard ![]() Join Date: May 2009 Location: Duarte, CA
Rep Power: 60 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 77
can you send me the instructions on how to do it. if possible, i'm planning on removing the one on my wife's mazda3 and install it on my car. we dont need the homelink but i want it for the compass. she has a gps, i use a map.
__________________ -John minor mods | ||||||||
![]() | | #11 | ![]() |
I will scan the instructions tomorrow. Do you want me to email them to you ?
| The Following User Says Thank You to MarMugMot For This Useful Post: | TwisteDcLoWn (01-08-2010) |
![]() | | #12 | ![]() |
yeah please. johnprey@gmail.com
![]() | | #13 | ![]() |
![]() ![]() Join Date: Dec 2009 Location: Dublin, OH
Rep Power: 172 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
Groans: 46
Anyway you could just post them?
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #14 | ![]() |
![]() ![]() Join Date: Feb 2010 Location: Houston, Texas
Rep Power: 17 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score | ||||||||
| Thread Tools | |
| Broken mirror | timbowman1 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 12-12-2009 06:38 PM |
| Apartment Homelink | dasmikechen | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 11-09-2009 09:45 PM |
| Homelink/auto-dimming mirror w/rainsensor installation? | ncpaladin | MazdaSpeed 3 - How-To's | 11 | 05-26-2009 10:04 PM |
| WTB: Mirror/Assembly | Speed3Max | MazdaSpeed 3/6 - For Sale / Trade | 2 | 02-19-2009 04:43 PM |
| Autodim and homelink rearview mirror | 06kr | MazdaSpeed Forums - Lounge/New Member Welcome | 4 | 08-14-2008 07:21 AM |
