Notices
 Old 09-14-2012, 04:54 PM   #1
punkwrock's Avatar
Posts: 63   (View Stats)
punkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud ofpunkwrock has much to be proud of
Default -14.8 ltft at idle
2012 speed3. Installed cork sport sri+tip a month ago and got the ap yesterday. Just monitored and I idle at -14.8 ltft. Could have a leak in the intake somewhere or a dirty maf sensor? Suggestions?
punkwrock is offline   Reply With Quote
 Old 09-14-2012, 04:58 PM   #2
dantes5823's Avatar
Posts: 6,674   (View Stats)
what map did you flash? check connectoions then do a maf cal if ot all checks out.
 Old 09-14-2012, 05:06 PM   #3
punkwrock's Avatar
I flashed cs sri+tip stage 1 91 oct.
So I will check all connections I guess. If it all looks ok I'll have maf cal.....I'm new at this and it's gona suck. But is it dangerous that it does what its doing? At wot everything is fine. Just at idle
 Old 09-14-2012, 05:12 PM   #4
dantes5823's Avatar
It's not gonna blow your car up. But it's not right. You wanna be with 2 but Cobb says within absolute 8 is fine. Is that the only time you see that trim tho? Is the rest of the breakpoints good?
 Old 09-14-2012, 05:16 PM   #5
punkwrock's Avatar
I'm just starting to read on the breakpoints so not familiar with them. All I know is that when I'm driving my afr is good,fuel pressure is good. I'll have to read up more about it. But it shouldn't be that screwed up with the maps.
 Old 09-14-2012, 05:26 PM   #6
punkwrock's Avatar
If anyone has a link about ltft and stft if you don't mind sharring it
 Old 09-14-2012, 05:36 PM   #7
England15j's Avatar
Posts: 141   (View Stats)
England15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the world
MAF Calibration Tutorial
http://www.mazdaspeedforums.org/foru...e-noobs-83959/
Blacked Out 2010 Black Mica MazdaSpeed 3 // K&N SRI // Corksport TIP // Corksport TMIC // TWM Gun Metal Big Type R // Denso ITV-22 // Cobb AP Tuner // AutoTech Internals // eBay Catless Downpipe // H&R Springs // Corksport Solid Shifter Bushings // FoMoCo Tranny Fluid // JBR SSP // Forge BPV V1 // JBR Stage 2 OCC // JBR 88a RMM // TSW Nurburgring 19x8.5 //Dizzy Tune 293hp and 327trq Pump Gas // Dizzy Tune 4/8 gal E-85 323hp and 364trq //
England15j is offline   Reply With Quote
 Old 09-14-2012, 05:52 PM   #8
dantes5823's Avatar
http://www.mazdaspeedforums.org/foru....php?p=1551450
Post a log and ill take a look if you like.
 Old 09-15-2012, 03:18 AM   #9
punkwrock's Avatar
thx for the help guys. I think i'm just gona go back to stock intake and TIP for now. Got alot of reading and understanding to do. Better to do that than blow my car.
 Old 09-15-2012, 04:01 AM   #10
fastest 3-cyl MS3
btstarcher's Avatar
Posts: 1,663   (View Stats)
You shouldn't blow your car; not on a 91 octane stage 1 map. Check for leaks, make sure connections are tight. If they are, drive it awhile and let the ecu "figure out" that there's been changes to your configuration.
JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD
Dizzy Tuned by Boost_creep in progress
hopefully soon: GTX2867R or GTX3076R
uncorked11 (09-15-2012)
 Old 09-15-2012, 08:35 AM   #11
punkwrock's Avatar
Well i just put back my stock SRI + TIP. With the stock tune. Everything is A-1. I tried using the OTS Stage 1 with stock parts and my LTFT's are -9.4 at idle. So i probably did have everything installed properly. As soon as i use the OTS cobb maps my LTFT go off. So i'm gona keep my stock parts and put stage 1. I'll trial and error to MAF Cal that stage. Once i get the hang of it i'll throw on the sri and tip again. Where i live, i don't know of any shops that tune imports....so i have to learn for myself.
 Old 09-15-2012, 08:53 AM   #12
GODspeed7's Avatar
Posts: 2,609   (View Stats)
Groaned at 46 Times in 31 Posts
Could also be a lose connection on idle but as soon as you are within boost the connection seals itself up. Balloon effect so to speak. I would double triple check all hoses you fucked with and those that you didn't just to be sure.
probably sent from a freight train at work
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
GODspeed7 is online now   Reply With Quote
 Old 09-15-2012, 08:59 AM   #13
punkwrock's Avatar
When i took everything off, all tubes were really tightly fitted and clamped. And like i say, i'm on all stock now and the numbers are all right on. As soon as i put the stock stage 1 map, the ltft's are off.
 Old 09-15-2012, 09:46 AM   #14
dantes5823's Avatar
So start reading the guides and once you feel comfortable enough try it again
 Old 09-15-2012, 09:49 AM   #15
England15j's Avatar
you can always get an E-Tune from one of the many tuners on this site
E-Tuners / Custom Hardparts - Mazdaspeed Forums
 Old 09-15-2012, 12:22 PM   #16
uncorked11's Avatar
Posts: 1,119   (View Stats)
Groans: 156
Every time I flash a new map my ECU reads some ungodly high number, drive the car a bit and allow the trims to be learned.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is online now   Reply With Quote
 Old 09-15-2012, 12:27 PM   #17
punkwrock's Avatar
Yeah...i'm gona go for a drive tonight with just the Stage 1 map and see what happens.
Do you usually have to play around with the maf cal alot? Or does everything kinda settle down on it's own after a while?
Last edited by punkwrock; 09-15-2012 at 12:27 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-15-2012, 12:30 PM   #18
uncorked11's Avatar
Groans: 156
It will settle down, in the past I may have had to do one maf cal to get it with +- 3
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 09-15-2012, 12:36 PM   #19
fastest 3-cyl MS3
btstarcher's Avatar
My LTFT was around -12 before I got my AP, that was with a Cobb SRI (it came with the car). It drove fine for a long time like that, like 80k miles. When I got the AP I flashed the map and after a few days I saw my LTFT was much closer to 0.
 Old 09-15-2012, 12:42 PM   #20
punkwrock's Avatar
Awsome! So basically, by using the OTS cobb maps, after putting abit of mileage on the map, the ECU should learn and set itself based on the values cobb have in the map? Cause when i had my SRI+TIP without the ap, the car felt like something was missing....i was still on stock tune. It was abit jerky and stuff. But when i installed the appropriate cobb map the car felt like new. It had alot smoother throttle response. But i only drove probably like 20 or 30km's and noticed the LTFT which made me freak.....the reason i went back to stock parts. So i'm gona try the Stage 1 stock tune for a few days to see if that levels out. If it does, i will put back my SRI and TIP. Fuel pump has to be next though...suprisingly i was still holding 1650 to 1700psi on WOT.
 Old 09-15-2012, 12:48 PM   #21
uncorked11's Avatar
Groans: 156
yes, it may require a revision it may not.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 09-15-2012, 12:55 PM   #22
punkwrock's Avatar
Cause i've been taking a look at ATR and wow.....i am totally not ready to hop into that one. Gona sit down and have a good read of that tuning for noobs handbook tonight. Thanks for the information guys. Truly helpful!
 Old 09-15-2012, 12:58 PM   #23
fastest 3-cyl MS3
btstarcher's Avatar
Give it 50 miles or so. Or 80 km.
Yeah read up, but as far as MAF calibration is concerned, try the OTS map first and see how close it gets you. Sometimes it's really close. At least with your fuel trims. Give it 80 km and see how they are.
Last edited by btstarcher; 09-15-2012 at 12:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-16-2012, 09:11 AM   #24
Mazda Super Tech
motherfnmonsta's Avatar
Posts: 945   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
+1
Just curious any idea what your stft was during all this?
injen cai,cobb tip,jbr tig,jbr egr delete,jbr heavy shift knob,internals,ur dp,ur tp,maganaflow cbe
jrb rsb,cs lowering springs.
motherfnmonsta is online now   Reply With Quote
High idle LTFT and how to tune it Fobio
Cobb ATR Support
13 02-27-2011 11:00 AM
LTFT -18% at idle Zak MazdaSpeed 3/6 - ECU Computer Tuning 13 03-12-2010 02:22 PM
-10% LTFT at Idle? AFcadet
Cobb ATR Support
9 07-31-2009 05:56 AM
HOW-TO: Adjusting Your Idle LTFT's superskaterxes
Cobb ATR Support
2 04-24-2009 03:57 PM
LTFT 15 idle 7 partial and 3 at WOT Death-From-A-Mile
Cobb Access Port/Maps
7 08-05-2008 04:23 AM
Page generated in 0.42173 seconds with 26 queries
