Like Tree2Likes
  • 1 Post By Rygar
  • 1 Post By Rygar
 Old 12-31-2015, 09:21 AM   #1
Rygar's Avatar
Posts: 21   (View Stats)
Rygar is an unknown quantity at this point
Default 2010 MS3 Power limit/fuel cut
Hi everyone,
I got my 2010 MS3 in November 2014 with 55,000 kms on it, and during the 2014 winter I had one or two occurrences of a power-limiting issue where the car would not rev to 3100 rpm (off boost). It didn't happen again so I just put it to the back of my mind and left it there.
This year once the weather got a little cooler (10°C, east coast of Canada) it started happening more often and is now quite regular so I need some help figuring it out. I don't know the car all that well but am generally a pretty good learner when required.
Symptoms: experienced in all gears expect first (so far) - accelerates normal until just under 3100 rpm and which case it just stops and any more throttle I give it just seems to bog the car down more. This is normal acceleration, I stay out of boost under 3000 rpm. A few months ago, if I experienced this in 3rd gear for example and shifted to 4th, it wouldn't happen, and if I shifted back to 3rd sometimes it would happen again and sometimes it wouldn't. Tuesday I had a 450 km drive and it was happening in 5th and 6th pretty much the entire drive.
I've gotten codes on two occasions (no CEL on either). First time I pulled a P0089 (fuel pressure regulator performance) and EPS U0100 (communication error to PCM).
Second time the codes were P0089 and P2004 (IMRC Intake Manifold Runner Control). The P2004 code didn't cause a CEL so I am not too worried about it being more than a one-off yet.
The car is stock, and I have purchased a V3 AccessPort, changed the plugs and cleaned the MAF. Two local dealerships are clueless about this car and frankly this seems a much better place to figure it out then in their bays for hours on end guessing.
I've attached screen shots and aptly named logs showing what my car is doing when this issue is occurring, and when it isn't (they were logged five minutes apart, good after the bad log, both in 3rd gear).
So in short, car inconsistently limits power/fuel/boost at 3100 rpms and ignores any more throttle. I don't want to throw money at fuel pump internals or other parts without educating myself (and I have searched lots!).
Please help me learn to love my car
2010 Mazdaspeed3
1998 Lancer Evolution
Rygar is offline   Reply With Quote
 Old 12-31-2015, 09:38 AM   #2
JgamB's Avatar
Posts: 2,566   (View Stats)
Dropping to ITFP levels (40-60psi fuel pressure) indicates a defect in the HPFP. I would double check the spill valve harness is clipped in tight / pins aren't bent, and pull and clean the existing HPFP internals, inspect the quad rings, look for scoring, etc.
The Following 5 Users Say Thank You to JgamB For This Useful Post:
cyclist20 (01-13-2016), littleloogy (12-31-2015), robbspeed (12-31-2015), Rygar (12-31-2015), WetzMS3 (01-06-2016)
 Old 01-06-2016, 07:41 AM   #3
Rygar's Avatar
While I haven't had time to pull the pump out yet (or the resources, as my DIY garage membership has expired and I need to be responsored to renew), would it be more worth my while just to get the Corksport/Autotech HPFP internals and do this all at once?
2010 Mazdaspeed3
 Old 01-13-2016, 09:31 AM   #4
Rygar's Avatar
Based on code P0089 and this post, I took the spill valve/fuel pressure regulator out of the pump on the weekend and cleaned it. It looked pretty clean, some gunk on the outside/bottom but nothing on the piston itself, but the car has run like a champ ever since (knock on wood).
2010 Mazdaspeed3
 Old 04-14-2016, 12:12 PM   #5
Rygar's Avatar
So after cleaning the "spill valve" three months ago the car has run great. It just takes a long time now to start unless I give it some gas.
Dommo14 likes this.
2010 Mazdaspeed3
 Old 04-14-2016, 12:16 PM   #6
Dommo14's Avatar
Posts: 685   (View Stats)
Dommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the world
Groaned at 9 Times in 4 Posts
I dont know what causes that but you get a like from me for owning an EVO 5!
I'm stock bro.
Dommo14 is offline   Reply With Quote
 Old 04-14-2016, 12:20 PM   #7
Rygar's Avatar
I am not sure either why it would solve one issue but create another. I thought it might be gravity related, but if the fuel pump primes when the car is in the on position (not started) that isn't the case. Pressures are good while it is running, at least, so there's that.
Thanks, the V is awesome. If I find an 8 MR for sale I'm replacing the Mazda!
2010 Mazdaspeed3
 Old 04-14-2016, 12:22 PM   #8
Dommo14's Avatar
A GTiR is a dream car of mine...
I'm stock bro.
 Old 12-16-2016, 07:44 AM   #9
Rygar's Avatar
Bumping my own dormant thread...
Slow starts are noticeably worse in the cold weather. Today was a good test day as it was -16°C and by far the coldest morning this winter. I primed the car 3 times (Ignition to on for few seconds, off, repeat x2) and the car started immediately.
I was thinking to clean the EGR valve, but this issue of long cranks only really started (or got much worse) after taking the 'spill valve' out of the top of the HPFP and cleaning it, which solved my issue under boost...
Any thoughts?
2010 Mazdaspeed3
 Old 12-16-2016, 09:06 AM   #10
Vitamin M's Avatar
Posts: 87   (View Stats)
Vitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these parts
Any thoughts?
Today was a very cold day indeed i am in waterloo ontario however i have never experienced issues with my 08 starting in cold. What do you exactly mean by long cranks ? Ofcourse the cranks will be longer in cold weather usually. I always notice a difference between cold weather start and warmed up engine start. I have never cleaned my EGR car has 150k. I dont think your EGR has anything to do with this.
Vitamin M is offline   Reply With Quote
 Old 12-16-2016, 09:11 AM   #11
Rygar's Avatar
I am in Halifax. Screw winter. 12° forecast for Sunday :S
By long crank I mean it will just turn over for a long time (far too long). Seems if I give it a little throttle it will start faster, and today with priming it a few times it started right away. It happens regardless of temperature, but the colder it is the worse it is.
My thoughts on the EGR came from searching in the forums for similar issues with slow starts.
It hasn't warmed up any so I see if the priming works consistently.
2010 Mazdaspeed3
 Old 12-16-2016, 09:37 AM   #12
Vitamin M's Avatar
Okk i see you def still have some fueling issues. Which also can be dangerous if on the high pressure side. I would def look more into this by inspecting the high pressure pump and everything associated with the system. You need to go through the mazda service manual and inspect everything associated with your previous codes.
Sent from my D6603 using Tapatalk
 Old 12-16-2016, 09:46 AM   #13
Rygar's Avatar
Good advice. I've been avoiding replacing the pump but it might be a good idea to upgrade it.
I also haven't logged for a while, I'll do that too.
2010 Mazdaspeed3
 Old 12-16-2016, 09:50 AM   #14
Vitamin M's Avatar
Yes loggs mught tell you alot. However i highly advise against replacing parts without finding a root cause. See the upgraded fuel pump is a good thing however you could still be back to square one if that wasnt the issue. Its just my school of thought lol
The Following User Says Thank You to Vitamin M For This Useful Post:
Rygar (12-19-2016)
 Old 12-16-2016, 09:54 AM   #15
Rygar's Avatar
Definitely agree. The only benefit is that the HPFP upgrade is one of those borderline-necessary upgrades haha
Vitamin M likes this.
2010 Mazdaspeed3
 Old 12-16-2016, 11:30 AM   #16
Rygar's Avatar
There was a new code waiting for me from sometime within the last week...
P0172, Fuel system too Rich (Bank 1). I wonder if that's from excessive throttle during ignition lol
2010 Mazdaspeed3
 Old 12-16-2016, 12:00 PM   #17
Vitamin M's Avatar
That could be from your extra priming... I could be wrong though.
 Old 12-16-2016, 12:03 PM   #18
Rygar's Avatar
Could be if it was from this morning. I will keep looking for codes over the next little bit as well, see if it comes up again.
2010 Mazdaspeed3
 Old 12-20-2016, 05:12 PM   #19
Rygar's Avatar
I had read that after shutting the car off the fuel pressure should stay around 200 PSI? I can't find it again, naturally.
Did some logging, pressure is dropping off quite a bit after shut off.
Numbers look good under operation, at least.
2010 Mazdaspeed3
 Old 01-20-2017, 06:24 AM   #20
Rygar's Avatar
I took the spill valve out and cleaned it, and the car was starting immediately for a week and is now starting to go back to poor starts.
2010 Mazdaspeed3
Power cutting out? fuel? mxrider518 2010 MS3 - Troubleshoot/Diagnostics 13 07-02-2013 02:29 PM
Fuel gauge and power windows go out at once sxyspeed6 MazdaSpeed 3/6 - ECU Computer Tuning 3 03-13-2013 12:40 AM
Stock Fuel Cut Limit campbell MazdaSpeed 3 - Engine, Transmission & Driveline 32 04-13-2010 08:45 AM
2010 Lexus HS250 Hybrid vs. 2010 BMW 335 Diesel 390-Mile Fuel Economy Comparison Test Drive Haltech Automotive News 0 08-05-2009 06:40 AM
First Drive: 2010 Ford Shelby GT500, Part 1 - Living on the (live axle) limit Haltech Automotive News 0 04-06-2009 10:20 AM
Page generated in 0.40755 seconds with 24 queries
