![]() | | #1 | ![]() |
| Who's the next viktm? ![]() Join Date: Sep 2012 Location: Texas
Rep Power: 10 ![]() Thanks: 12
(Thread Starter) | Not Ranked : 0 score Two logs attached, one when life was good and one now that life isn't. Except for AFR and Boost they look very similar. Full Stage 2 goodies, 50/50 E85/93 mix, tuned by Dizzy. Been running great, suddenly started running like shit Fri night. Fueled up at my normal place on Thurs night. Saw that I wasn't getting over ~15.6 pounds of boost (usually in the 20-21 range) and AFR's were dropping into the 9's. Popped a P0234 CEL. Bucking and jerking like crazy, then settling down above ~4500 RPM but still sluggish. Air intake sounded odd, more like a hiss than the usual whoosh. Start thinking boost leak. Checked boost path as best I can, tubes and hoses secure. Boost solenoid visually looks OK, everything attached. Disassembled BPV, inspected, cleaned and re-installed. Ends of the spring look a bit worn but I don't know what they look like new. No improvement. Removed neg battery cable, pumped brakes, let sit. Reflashed tune. No improvement. Removed filter from CAI just in case it was dirty (old, but I clean it). No improvement. Cleaned MAF, put stock BPV back on. Noticed the spring on the stocker is a LOT stiffer than the Cobb. No Improvement. What else to check? Last edited by SpeedViktm; 10-14-2012 at 05:18 PM. |
![]() Join Date: Nov 2011 Location: Naperville, IL
Rep Power: 2089 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
Groaned at 46 Times in 31 Posts
O2 sensor would be my best guess if you are SURE there isn't a boost leak Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete. |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | SpeedViktm (10-14-2012) |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 364 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,123
Groaned at 4 Times in 2 Posts
That is definately a boost leak. WGDC way higher, can't hold boost and AFR's are fucked. Keep looking, look for Joe Isuzu's boost leak finder vid if you cannot find something on further inspection.
__________________ Old: 2011 Red Mica Speed 3 w/tech - stocked and traded New: 2013 Dodge Journey - Family CruiserFuture: Another race car, MS6 maybe? |
| The Following User Says Thank You to ASHMS3 For This Useful Post: | SpeedViktm (10-14-2012) |
![]() | | #4 | ![]() |
Cleaning MAF and changing BPV didn't help, not that I was holding much hope they would.... Last edited by SpeedViktm; 10-14-2012 at 12:51 PM. | ||
| The Following User Says Thank You to SpeedViktm For This Useful Post: | ASHMS3 (10-14-2012) |
![]() | | #5 | ![]() |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 932
Groaned at 35 Times in 24 Posts
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
| The Following 2 Users Say Thank You to Fatguy729 For This Useful Post: | ASHMS3 (10-14-2012), SpeedViktm (10-14-2012) |
![]() | | #6 | ![]() |
Thanks to all. Cold boost tube at throttle body was loose, tube came off when I was pulling the IC off and it shouldn't have done that. Clamp was a little far back on the tube and might have been riding on the lip of the TB and eventually slipped down... So the take-aways of this thread are: 1. OP is a dumbass. 2. Don't assume that since the hose was tight when you put it on 6 months ago, and it appears to be where you left it, that it still is tightened. I'm still gonna build one of those testers though, like the shit outta that!! |
| The Following User Says Thank You to SpeedViktm For This Useful Post: | ASHMS3 (10-15-2012) |
![]() | | #7 | ![]() |
Shit happens, you got it worked out so chalk it up as a W.
| My car suddenly hates me | phantom6294 | Mazdaspeed3/6 General Discussion | 13 | 04-27-2011 11:00 PM |
| MSF TOILET PAPER | rodrigo | Mazdaspeed3/6 General Discussion | 8 | 01-21-2011 01:31 PM |
| Gone lean suddenly??? | 08cosmic3 | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 05-30-2010 07:51 PM |
