![]() | | #1 | ![]() |
![]() Join Date: Sep 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score
I just installed a corksport SRI (awesome by the way) but my auto window roll down is no longer working? does it have anything to do with my install and the battery disconnect? Anyone have this problem? 2010 mazdaspeed 3 | ||||||||
| I AM THE STIG ![]() Join Date: Apr 2009 Location: near Chicago
Rep Power: 454 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,154
Groans: 53
If the 2010 MS3 is anything like the MS6, then most likely disconnecting the bat did it. There should be something about it in your car manual on how to fix it. Other wise, go to each window, with the power up, roll it down a bit with the corresponding window switch, then roll it back up by holding the switch all the way up, release the switch once you hear a click. Repeat on the other windows... that's the MS6 way.
__________________ Current cars: 2006 Mazdaspeed 6 GT DD/Track Toy 1986 Porsche 944 turbo LSD+M030 bits I make OCC kits. For more info, PM me. 2010 EECMM Sponsor | ||||||||
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Mine doesn't work after the initial startup, but starts working after another shutdown and startup. Hope that helps.
![]() | | #4 | ![]() |
| Brooklyn 1st 2010 Red MS3 ![]() ![]() Join Date: Aug 2009 Location: Brooklyn NYC
Rep Power: 26 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
search and you will find answers ..... FYI i had the same problem . Took out battery and no AUTO pwr window
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #5 | ![]() |
![]() ![]() Join Date: Jan 2010 Location: San Antonio TX
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
Heard some one say this before in a diff post it worked for me also when I disc. my battery for my intake. If I remember correctly hold the auto power window switch UP until you hear a click and it should start working. Hope that works for you it worked for me.
![]() | | #6 | ![]() |
Yup that worked on my 2010 ms3 Thanks! | |||||||||
![]() | | #7 | ![]() |
| *masshole* ![]() ![]() Join Date: Sep 2009 Location: Mass.
Rep Power: 85 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 221
I insalled my intake last night and my auto window didn't work after. All I did was roll the window down a bit, then hold the button up, the window went up, kept holding untill I heard a click. Now it works again.
__________________ 2010 Mica black ms3, 35% tint all around with 15% strip on top, 6k hid, red corksport intake+tip, nokya hyper yellow fogs, cp-e towplate,TRZ dogbone rmm | ||||||||
![]() | | #8 | ![]() |
glade you fix your problem
![]() | | #9 | ![]() |
| Team FO ![]() ![]() Join Date: Feb 2010 Location: Houston, TX
Rep Power: 164 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 123
Now if I could only find a way to make the passenger window go Auto, I'd be a happy man!
| Thread Tools | |
| Took out battery and no AUTO pwr window | 2010 MS3 | 2010 MS3 - How-To's | 15 | 02-06-2010 09:27 AM |
| Rear Window Breaks on its own??? | Booster123 | MazdaSpeed 6 - Engine, Transmission & Driveline | 15 | 09-25-2009 11:05 AM |
| back right window wont go down!!! | clos561 | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 08-17-2009 09:10 PM |
| 'Green Garage' Debuts at Washington Auto Show to Roll out EcoCAR Challenge Designs | Haltech | Automotive News | 0 | 02-09-2009 06:20 AM |
| Clear Bra and WIndow Tint | toymachine | MazdaSpeed 3/6 - Appearance | 7 | 10-01-2008 10:02 AM |
