 Old 07-16-2017, 09:33 AM   #1
tmaiorca's Avatar
Posts: 191   (View Stats)
tmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of light
Default AP Boost Reading 98.9?
I've noticed this happening more often, almost once every other day. At first it was completely random - crushing in 6th or 5th at 2k rpms, not building boost whatsoever, and the AP would randomly for 2 seconds read 98.9PSI.
Now it's occurring when I go over a large hill, bump, or pothole. Where is the AP reading psi from? Is it possible a sensor is loose? I've never heard of this before.
The turbo builds / holds boost fine, and does not have any significant KR.
Sent from my Nexus 6P using Tapatalk
RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG
2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR
tmaiorca is offline   Reply With Quote
 Old 07-16-2017, 11:05 AM   #2
Shwa's Avatar
Posts: 321   (View Stats)
Shwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the worldShwa is the leader of the world
Sounds like a connection is loose or maybe the map is going out. Haven't heard if this before
"Keep your head clear and suffer like a man"
Shwa is offline   Reply With Quote
 Old 07-17-2017, 07:12 AM   #3
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I've had it happen too. I think it was the connection coming loose at the AP side, IIRC. It was a while back though.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 07-17-2017, 09:54 AM   #4
qtrmile beast's Avatar
Posts: 2,402   (View Stats)
i have had this as well.. I just look at my boost gauge. Never seen this on the logs though..
track weight 3220
street weight 3370
 Old 07-17-2017, 11:07 AM   #5
Djohns's Avatar
Posts: 3,883   (View Stats)
Groans: 105
It happened to me, my map sensor was just a little loose. Tightened it up and it was good to go.
2010 black mica speed3
Soon:built motor
 Old 07-17-2017, 11:36 AM   #6
tmaiorca's Avatar
Interesting, I'll try and Tighten up all connections again. Thanks
Huh... Would make sense. Dumb question - where is the MAP sensor located? Maf is obviously on the intake. I'd like to check mine for sure
Last edited by tmaiorca; 07-17-2017 at 11:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-17-2017, 04:46 PM   #7
Djohns's Avatar
Groans: 105
Located on the passenger side of the intake manifold. Right under runner 1.
Soon:built motor
 Old 07-17-2017, 04:47 PM   #8
tmaiorca's Avatar
Perfect, thanks for the info. Will check back with results
Accessport not reading boost? pastry00 MazdaSpeed 3/6 - ECU Computer Tuning 10 10-16-2016 06:22 PM
Scangause 2 Boost reading is off? cjanota 2010 MS3 - Car Audio & Electronics 1 05-02-2012 06:26 PM
Help Not Reading Boost Lakespeed6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 06-16-2011 06:17 AM
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 04:41 PM
DH boost reading k0m MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-08-2009 05:49 AM
Page generated in 0.28739 seconds with 24 queries
