 Old 08-05-2018, 07:01 AM   #1
Tru3's Avatar
Posts: 44   (View Stats)
Tru3 is on a distinguished road
Default ECM Fuse keeps blowing?
2 times within probably the last 3 weeks my ECM fuse keeps blowing and when that happens this puts the car into anti theft / immobilization mode which doesn’t allow you to drive it and it don’t recognize the advanced key. Once I replace the fuse everything is back to normal and ready to go?
Any thoughts on why this one particular fuse keeps going?
Tru3 is offline   Reply With Quote
 Old 08-05-2018, 07:58 AM   #2
Bingo's Avatar
Posts: 735   (View Stats)
Groaned at 9 Times in 7 Posts
Check the wiring that goes to the ECU clips next to the intake. They can rub their insulation and cause all sorts of issues.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
2013 keeps blowing fuse ltoddiv 2010 MS3 - Troubleshoot/Diagnostics 6 08-17-2017 11:35 AM
Engine IG Fuse keeps blowing dawgincustoms MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-15-2017 04:01 PM
What is the "P Outlet" (15A) fuse in the engine bay fuse box TWOptSL0W MazdaSpeed 3/6 - Car Audio & Electronics 18 10-23-2011 11:07 AM
Eng Bar fuse keeps blowing after water splashed into engine bay Dawey1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-28-2011 01:19 PM
Need your help! Fuel Injector Fuse keeps blowing flz33 MazdaSpeed 3 - Engine, Transmission & Driveline 7 12-23-2008 09:09 AM
Page generated in 0.24026 seconds with 21 queries
