 Old 10-09-2017, 02:02 AM   #1
Tomas Novak's Avatar
Posts: 9   (View Stats)
Tomas Novak will become famous soon enough
Default Fan does not blow at all
After solving one issue, another is on again!
Fan is not blowing any air at all.
I have checked 7.5A and 40A fuse, under hood, named FAn1 and A/C
A/C compressor does not start, but maybe that is due to fan not blowing? Sometimes it seems that the compressor even start (RPM goes a bit up), but then does not for the second time, maybe because it was 52F outside. But temp can be even 0F, comp should start?
Anyway, it is an overnight issue, I'm sure last driving day it was OK, not it is not, no idea why.
Possible:
- low fluids or something with A/C system ?
- simply some blower died ?
I can set the temp, or intensity, on screen everything seems usual, I can even hear the click when changing air direction, or in/out circulation. But can' hear the fan itself, nor feel the air.
Any thoughts please ?
Thanks
2011-2012 MS3 , 140k miles
Tomas Novak is offline   Reply With Quote
 Old 10-09-2017, 06:03 AM   #2
GroceryGtr's Avatar
Posts: 472   (View Stats)
Do you mean the engine fan or the blower fan(blows the a/c in the cabin).
 Old 10-09-2017, 06:11 AM   #3
Spectrix's Avatar
Posts: 303   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
This is sometimes due to the blower resistor / fan speed resistor. It varies the current to the fan. I've not changed it on the MS3, but on other cars it was as simple as unscrewing it and swapping the part with another from a wreck.
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
 Old 10-09-2017, 11:31 AM   #4
Blower fan...
Hm, I heard on MS3 its like giving a birth, to replace it.. because its somewhat between glowebox and gas pedal..
Most likely its the blower motor.. but cant be sure, hm.
 Old 10-09-2017, 01:36 PM   #5
SaveMelMac's Avatar
Posts: 467   (View Stats)
SaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the world
Usually if the resistor is bad the fan will only blow highest speed setting, I would test the blower motor with 12v directly the it, then work back from there.
SaveMelMac is offline   Reply With Quote
The Following User Says Thank You to SaveMelMac For This Useful Post:
Tomas Novak (10-09-2017)
 Old 10-12-2017, 03:52 AM   #6
Hm, and that blower motor is the BL same as BK model, or are they different? I can get BK model from local eshop, but they dont have the BL.
Solved - dealer who did freewheel replacement (rattling sound), did not plug something back tightly enough. Funny. Shit happens..
 Old 10-12-2017, 12:34 PM   #7
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Kinda wrong thread but can explain what this freewheel is / pics ? And what the replacement was? Personally curious
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 10-12-2017, 09:30 PM   #8
It was alternator pulley - that's better word for it (dont have pic, as dealer only told me, did not show what was wrong)
Was not sure how to translate, so used wikipedia for it, that's why freewheel came up...
Hm, but dealer also changed oil, and oil filter, but now im not sure, if also cabin filter - if cabin, maybe thats where he forgot to plug something in... , - he was in kinda hurry, and rush can cause such errors..
Blow Through MAF Mid_Life_Crisis MazdaSpeed 3/6 - Turbo Induction 44 10-31-2012 10:14 AM
Blow Through MAF Voltwings 2010 MS3 - ECU Computer Tuning 88 10-05-2012 04:14 AM
Blow through MAF ESB Jiu JItsu MazdaSpeed 3/6 - Turbo Induction 84 09-14-2012 06:57 AM
blow through maf help mrkdspd MazdaSpeed 3/6 - Turbo Induction 10 08-13-2012 12:59 PM
How much can the K04 blow? sallyspeed3 MazdaSpeed 3/6 - Turbo Induction 26 03-30-2012 11:15 AM
Page generated in 0.28530 seconds with 24 queries
