  • 1 Post By Fstrnyou
 Old 04-12-2018, 07:44 AM   #1
Thebroha's Avatar
Posts: 11   (View Stats)
Thebroha will become famous soon enough
Smile First post. THROTTLE ISSUES
Hey guys. Looking for your help and knowledge. I jut bought my second ms3 and I've run into a dilema. IN NEUTRAL I can't get the rpm higher than 4K. In all the other gears I cannot give it 100 percent throttle without the turbo spiking if that makes sense.The guy who owned it before me put various mods on it and I will list them to the extent of my knowledge. Ultimate Catback exhaust. Downpipe but info unknown. Cobb intake. Cobb bov. I'm unaware if he did hpfphf internals. I apologize for this ignorant post but I'm not sure how to approach this. I'm buying a v2 this Friday to possibly solve this problem. Thanks boyos.
Thebroha is offline   Reply With Quote
 Old 04-12-2018, 10:21 AM   #2
Fstrnyou's Avatar
Posts: 2,231   (View Stats)
Codes?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 04-12-2018, 10:32 AM   #3
Db09ms3's Avatar
Posts: 296   (View Stats)
Groans: 66
A, B, A, C, A, B, B, hit Start.
I jest, you're on the right path.
Stockish
 Old 04-12-2018, 12:03 PM   #4
Fstrnyou's Avatar
Up, up, down, down, left, right, left, right, B, A, B, A, Start
Db09ms3 likes this.
Other rides:
History:
5doorsoffury (04-13-2018)
 Old 04-12-2018, 01:25 PM   #5
Thebroha's Avatar
Originally Posted by Fstrnyou View Post
Codes?
No codes whatsoever. I tried L3 to sprint but that was a no go.
 Old 04-12-2018, 02:19 PM   #6
CleverOne's Avatar
Posts: 48   (View Stats)
CleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of light
was/ is it tuned? could have a limiter set.
CleverOne is offline   Reply With Quote
 Old 04-12-2018, 06:07 PM   #7
Thebroha's Avatar
Not sure man. Couldn't get in contact with the previous owner. I'm hoping the access port will help me out?
 Old 04-12-2018, 06:50 PM   #8
CleverOne's Avatar
Yea, the access port will def help. Just make sure you download the right one for your mods.
 Old 04-13-2018, 06:12 AM   #9
Thebroha's Avatar
You think I should just flash it and start from scratch?
Thanks.
 Old 04-13-2018, 06:50 AM   #10
Fstrnyou's Avatar
Without knowing what tune is on there, start from scratch.
Load a crappy OTS map that best fits your build and go from there or load what's called a base map and REALLY start from scratch.
Other rides:
History:
 Old 04-13-2018, 07:14 AM   #11
CleverOne's Avatar
Yea, you really need to get a good inventory of mods. Check your plugs are at .026, do you have a TIP installed? Not sure if cobb intake comes with that part or not.
https://www.cobbtuning.com/maps/
You should be able to handle the stage 2 map if you have fuel internals, you will be able to tell from a log; just dont go to redline. So flash the map, then do a very short WOT log in 4th gear and then check your HPFP actual and make sure it maintains above 1600.
 Old 04-13-2018, 01:49 PM   #12
Thebroha's Avatar
Just got the tuner! Gonna do what you've recommended. I'll let you know what I find out. Thanks guys!
 Old 04-13-2018, 02:51 PM   #13
Thor Hammer's Avatar
Posts: 1,821   (View Stats)
Groans: 205
You don't need to gap as low as 0.026. With your mods 0.028 is fine.
 Old 04-13-2018, 04:10 PM   #14
Thebroha's Avatar
Hey guys. Connected the AP. It had a previous tune. Which was trash obviously. Is it safe to bring back to stock with the mods I mentioned?
 Old 04-13-2018, 04:35 PM   #15
Groans: 205
If you do your MAF cal might be off. I don't know how much bigger than stock the Cobb intake is. Try it though. Wont hurt anything.
I would take off the fuel pump and find out if it has internals. I would certainly hope so as you said you have an aftermarket downpipe.
Search right here on this forum for procedure. There are pictures in here in various posts of what stock and aftermarket look like so you will know for sure.
Once you get all that done, and if you have internals, load the map that is the closest match for the mods you have that came on the AP. Then go take a data log. Again, search on here on how to properly take a data log.
 Old 04-13-2018, 07:04 PM   #16
Thebroha's Avatar
Thanks! Good advice. Running a stage 2 91 octane with sf. It's idling at a little under 1k. I actually have a full intake so I'll switch it up. Thanks guys. Super appreciate all the info.
 Old 04-14-2018, 07:14 AM   #17
Thebroha's Avatar
So guys. This morning I decided to load the stage 3 93 octane map with sf and Cobb tih with upgraded cdfp and upgraded intercooler. Which I forgot to mention I have. In going to do a data log and post my findings. It's currently idling at a hair under 1k. Thanks in advance for your input.
 Old 04-14-2018, 08:18 AM   #18
Thebroha's Avatar
okay guys. this is the 4th gear catalog I took as suggested. Let me know if you guys see anything out of the ordinary in your opinion. Ill take one of the stock tune if you guys think i need too. Im officially scared of the car. GG
 Old 04-14-2018, 01:14 PM   #19
Fstrnyou's Avatar
Did you verify the fuel pump?
Other rides:
History:
 Old 04-14-2018, 03:42 PM   #20
Thebroha's Avatar
Yes I did. Just got a code for misfire 2 cylinder so I'm definitely gonna change the plug's hopefully tomorrow if I fiND the time.
 Old 04-16-2018, 09:24 AM   #21
Groans: 205
Don't load the stock tune.
The log looks good. No KR (knock retard) showing at 19 psi. AFR and HPFP Actual look good. However, as has been discussed so many many times; just because your fuel pressure is maintaining above 1600 psi at WOT doesn't guarantee you have upgraded internals.
 Old 04-16-2018, 10:39 AM   #22
JakeMS3's Avatar
Posts: 1,161   (View Stats)
JakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the world
Groaned at 7 Times in 5 Posts
Is this not launch control? Does it do this if you have it in 1st gear clutch disengaged like you’re about to launch? Mine won’t go past 3500 rpm, but that’s what I have my LC set at.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
Corksport Catted DP/HPFP Internals
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
JakeMS3 is offline   Reply With Quote
The Following User Says Thank You to JakeMS3 For This Useful Post:
Vansquish (04-16-2018)
 Old 04-16-2018, 11:21 AM   #23
Thebroha's Avatar
Perhaps. But it also had issues in all other gears. It still has slight turbo spike at 100% throttle but significantly less
[QUOTE=Thor Hammer;3142771]Don't load the stock tune.
The log looks good. No KR (knock retard) showing at 19 psi. AFR and HPFP Actual look good. However, as has been discussed so many many times; just because your fuel pressure is maintaining above 1600 psi at WOT doesn't guarantee you have upgraded internals.[/QUOTE
Gotcha. I'll double check to make sure but to my knowledge they are upgraded. Thanks
Last edited by Thebroha; 04-16-2018 at 11:21 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Thebroha For This Useful Post:
Thor Hammer (04-16-2018)
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 12:50 PM
Unsettling hesitation under part throttle and full throttle at first track day dachtler 2010 MS3 - ECU Computer Tuning 0 10-01-2012 01:49 PM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 01:37 PM
Throttle Log fjames
Cobb Access Port/Maps
2 11-12-2008 09:54 PM
CP-E Full Throttle flash pre-post dynos... AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 174 09-18-2008 07:05 AM
Page generated in 0.41070 seconds with 26 queries
