 Old 07-09-2016, 03:58 PM   #1
boatis's Avatar
Posts: 257   (View Stats)
boatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond reputeboatis has a reputation beyond repute
Default fuel pressure dropping to 200psi
my car threw a P064D code. i took a 3rd gear log (WOT from 3500-4500RPM) and fuel pressure is dropping really low (~200psi) and AFR is pegged at 14.85. i've had CS internals for ~20-30k miles now and never cleaned them. i occasionally run an e30 blend but have mostly been running 93 lately. any help would be much appreciated
edit: the P064D code usually goes away after a day or so if i dont go WOT, but immediately returns once i go WOT
File Type: png Screen Shot 2016-07-09 at 6.51.46 PM.png (942.5 KB, 21 views)
2013 Black Mica MS3 w/ Tech
Cobb AP V3 - JR TUNED - E85 - ST coilovers - CS hpfp internals - CS sri - CS tip - CS rsb - CS short shifter - CS shifter bushings - UR axle-back - ATP catless dowpipe - CP-E rmm - Denso ITV22
rice : Rally Armor mud flaps - Deep Red powder coated pu wheels - 20% tint
boatis is offline   Reply With Quote
 Old 07-09-2016, 07:35 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
With the AFR not changing, sounds like a bad O2 sensor.
As far as the fuel pressure, you could try cleaning the spill valve and see if that helps. To me it doesn't look real. You are getting over 2 load with no KR. I would think if the pressure was that low, you would knock
Have you don't anything to the car recently? Forgot to plug something back in? Forgot to reattach that ground by the HPFP?
The Following User Says Thank You to sheston For This Useful Post:
boatis (07-11-2016)
 Old 07-11-2016, 03:03 PM   #3
boatis's Avatar
haven't done anything recently. the last thing i did was a catless downpipe and dyno tune last summer.
here's a log of when the check engine light turned on. no CEL before the pull and it turned on halfway through the log which is what makes me doubt that its an o2 sensor problem, because it was working fine until i went WOT
 Old 07-11-2016, 05:24 PM   #4
sheston's Avatar
That log looked better, until you get about half way thru it. AFRs go to straight line. The P064D code does look like it might be related to O2 sensor, but....
Did a quick search and saw where someone changed their spark plugs when they were having this issue and it cleared up. Might be worth a try. Otherwise, check your wiring harness, most likely around the ECU, and look for rubbing or shorted wires.
boatis (07-13-2016)
 Old 07-13-2016, 08:53 AM   #5
boatis's Avatar
i'll be doing the spark plugs today. we'll see what happens
 Old 07-13-2016, 02:46 PM   #6
boatis's Avatar
spark plugs fixed it !
File Type: png Screen Shot 2016-07-13 at 5.45.32 PM.png (988.1 KB, 12 views)
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 03-15-2019 07:27 PM
Fuel Pressure dropping when slowing. MazdaBoy2.3 2010 MS3 - ECU Computer Tuning 5 10-11-2012 06:17 PM
Fuel PSI dropping during WOT frodaddyweez MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 71 05-11-2012 02:56 PM
Fuel Pressure dropping during WOT My FIX crazyp MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 03-26-2012 06:05 PM
Fuel Pressure still dropping shnouz MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 8 03-23-2012 05:39 PM
Page generated in 0.26744 seconds with 22 queries
