![]() | | #1 | ![]() |
![]() Join Date: Apr 2011 Location: Johnson City TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score I am going to take the plugs out and check them, do a compression test, and measure the piston heights. I was curious if anyone else may know anything else to check other than just looking around in tight places to see if something would be in a friction point that would cause this sound. I am attaching the only log I stayed into long enough (because I am worried even though it pulls like normal wot) I am also attaching a video that the sound is kind of faint...but you can hear it right before I let out.
__________________ 2010 Celestial Blue MazdaSpeed 3 1/09/2013 ![]() Cobb Accessport (self-tuned w/meth), Cobb SF, HTP tip, AutoTech HPFP internals, Greddy Rz Bov, Jbr 88duro rmm, Ebay Catless DP, Corksport Testpipe, Badlanz 3" Electric Exhaust cutout on testpipe, , DDM 55w 8,000k HID's, tenzo 18 x 7.5 w/ Bfgoodrich g-force kdw ta. 2008 Black MS3= Totalled 12/21/2012 |
| The Following User Says Thank You to ThaKing For This Useful Post: | clete (07-28-2014) |
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Did you check the plug in cylinder two?
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score you most likely need colder plugs with those mods and you don't have them listed. Pull the plugs and check. Is the pop an afterfire sound? If so a misfire explains a lot there
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
![]() | | #4 | ![]() |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1703 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
| Not Ranked : 0 score @atvfreek; @phate; @rfinkle2; cj, if you want to come down this week one day we can check everything out.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() |
| The Following User Says Thank You to 865ms3 For This Useful Post: | atvfreek (10-07-2013) |
![]() | | #5 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score You can see the misfire right when you get into boost. Definitely don't drive the car hard until you can check it out. Check plugs, do a compression and piston height check, that will give you a direction to go in.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | 865ms3 (10-07-2013), BigBoostMS3 (10-07-2013) |
![]() | | #6 | ![]() |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score In b4 blown injector seals. Does it sound like pop corn cookin?
__________________ TEAM LUXURY ![]() |
| The Following User Says Thank You to Sid3wayS For This Useful Post: | Agent_Orange (10-13-2013) |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have njk 1 step colder plugs...they were above gap I wanted..and looked bad..so I replaced them today and did a piston height check...1/4 are almost identical...and 2/3 are almost identical...when I say almost I mean you couldn't tell the difference on the dowl rod i was using from the marks...I guess ill see about doing a compression test....Has no one listened to the video? Is there a video with blown injector seals as a sound so I can compare?
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score After reading a thousand or so pages of threads it completly seams like it is injector seals....Although when looking through the IM I can't see anything that would look like a leek...but I will see about doing it and a compression test. I think I have decided the toyota injector seals fix will be tried.... Hopefully they can do next day...
![]() | | #9 | ![]() |
Groans: 97
| Not Ranked : 0 score You wouldnt really be able to tell from the top like that unless it was VERY bad. Every pic ive seen shows the blowout shooting down
![]() | | #10 | ![]() |
| Not Ranked : 0 score ding ding ding. we have a winner! @ThaKing; @BigBoostMS3; and myself pulled the car down today. Compression test was good. pulled the injectors.......only injector 2 wasnt blown. 1,3, and 4 all blown seals with number 3 being the worst. threw some toyota seals in and car runs good now. ill let @ThaKing; post up the pictures he has.
| The Following 4 Users Say Thank You to 865ms3 For This Useful Post: |
![]() | | #11 | ![]() |
Groans: 97
| Not Ranked : 0 score Glad I could help.
| The Following 2 Users Say Thank You to Sid3wayS For This Useful Post: | 865ms3 (10-13-2013), Agent_Orange (10-13-2013) |
![]() | | #12 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sorry for just getting to this as it was sunday when it was done, but as he said it did end up being the injectors. I am not glad to be back to power and gas mileage again!!! Went ahead and ported the one runner, and painted the intake manifold while it was off. Thank you again Brent and Scott!! Sorry for the shitty pictures....I took them with a toaster.
| The Following 2 Users Say Thank You to ThaKing For This Useful Post: | 865ms3 (10-16-2013), ChimmyChong (10-16-2013) |
![]() | | #13 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score At first I thought your thread said "large pooping sound" lol Id be scared if my car made a pooping sound. sent from my peepee
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
| Motor makes big popping sound only when under boost | tinboi479 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 07-10-2013 12:04 AM |
| Lack of power with popping sound. | eksces | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 47 | 12-12-2012 01:46 PM |
| popping sound after changing spark plugs | supersswa | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 35 | 08-22-2012 06:18 AM |
| Clicking / Popping Sound from Steering Wheel | black leaf | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 01-05-2009 10:54 AM |
| Popping sound from intake manifold | pbblaster | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 12-10-2008 03:19 PM |
