 Old 01-14-2013, 07:45 AM   #1
maikell77's Avatar
Posts: 5   (View Stats)
maikell77 is an unknown quantity at this point
Default Long Crank at cold start
Background, car has 77k. It is stock engine wise except for RP gear oil and a K&N. The issue started suddenly, as in Thursday the car fired up after about 1 revolution. Then Friday it took 5-8 revolutions. I took it in to the dealer, had the intake cleaned (first time). They also replaced the battery. The car then started right up as normal at the dealer. Later that night the long crank returned and a tip out surge from 1000-1500 started. I had about 1/4 of tank, filled up and the issue remained.
I then pulled the K&N, cleaned the MAF, disconnected the battery, replaced spark plugs reconnected battery. The car then drove as normal no surge, and it started normally when warm. After it cooled off it took longer than normal to crank again.
Any ideas what could be the issue? My guess at this point is an EGR valve that is not closing all the way.
maikell77 is offline   Reply With Quote
 Old 01-14-2013, 08:04 AM   #2
Sid3wayS's Avatar
Posts: 6,789   (View Stats)
Groans: 97
Had same issue, cleaned the egr and problem solved. There's a how to here somewhere preaty easy to do. Its a common issue especialy in the colder months.
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
 Old 03-11-2013, 08:42 AM   #3
maikell77's Avatar
Just wanted to post a quick update. Cleaned the EGR valve as suggested, using the how-to. Problem fixed car lights off like it should.
82,000 miles and a dirty EGR valve, set of front brakes, 2 sets of tires and the Speed3 is still going strong.
 Old 03-13-2013, 07:48 PM   #4
celestial_MS3's Avatar
Posts: 1   (View Stats)
celestial_MS3 is an unknown quantity at this point
I was having the same issue recently, cleaned the EGR and good to go
celestial_MS3 is offline   Reply With Quote
 Old 03-13-2013, 07:54 PM   #5
Tommy's Avatar
Posts: 2,308   (View Stats)
Groans: 155
EGR as mentioned.
Want to win a v3 Cobb Access Port? Enter the raffle and help a good cause.
http://www.mazdaspeedforums.org/forum/f510/cobb-accessport-v3-raffle-good-cause-190013/
Tommy is offline   Reply With Quote
noise on cold start 07blackms3 MazdaSpeed 6 - Engine, Transmission & Driveline 10 07-27-2011 12:43 PM
Misfire on Cold Start superskaterxes MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 07-03-2011 08:30 PM
Cold Start up PapaSmurf Gen2 MS3 General Discussion 16 03-29-2011 03:30 PM
cold air for long island? LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 16 05-19-2009 03:23 PM
Page generated in 0.26399 seconds with 23 queries
