 Old 09-22-2017, 12:56 AM   #1
Tomas Novak's Avatar
Posts: 9   (View Stats)
Tomas Novak will become famous soon enough
Default Rattling noise after BOOM
Hello!
I am new, though, i have been reading your forum for quite some time, as I love to get new info about any kind of MPS and simply stare at them. But today. I got a Problem
Long story short. STOCK GenPu 2011, 141k miles, mostly highways, back then - 25k miles back, timing belt changed, so it should be alive today, but WHO KNOWS. So to the story: one day, two days back, have been driving around at speed of 30-40mph, normal acceleration, when strange sound, out of passenger side came, it was for like 7 or 8 seconds, and the sound was like when some fan is messed with something, so I let the engine go down in RPM, not touching gas, when I did, after this 7 seconds or so some "boom" came just like that imaginary fan would stop OR speed up again, after this, no sound, car was normal, but never hit gas on 100% again since then. The thing is, since this event, strange noise is coming from engine area. First thought was a TURBO, but it is not turbo. Dealer told me, it COULD be alternator, but he was not sure based on that noise and they have time for this only in like 2 weeks, which is a killer year for me, no one can go sleepless for 2 weeks, err... Second closest dealer is 40miles away. But what if it is belt or something? Anyone here, please, for speedGOD's sake, can identify the problem from this MP3 made with smartphone?
Thank you a lot!
EDIT: it does when IDLE, but very hard to hear, best possible RPM to hear it is 1300-1900 for example, but can be heard anywhere from IDLE to 3K (so nonstop rattle), did not go higher yet. If it would be alternator, RPM would drop up or down? RPM is steady. Maybe ALT is not fully dead, IF it is the ALT. Found some vid on youtube, to disconnect the ALT to see, if the sound is still there, but I feel it wouldn't solve much, and not sure if I can start it without ALT plugged in. Maybe the one who did the timing bolt did it wrong, or simply wrong bolt. I sent him email with recordings (200miles away), so waiting for reply. It does not eat oil, only like half of quart since oil change (7-8k miles). Hm.
File Type: mp3 GOTO 64second for engine OFF - closed hood.mp3 (2.49 MB, 2 views)
Tomas Novak is offline   Reply With Quote
 Old 09-26-2017, 12:35 PM   #2
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Passenger motor mount (PMM) blown out is my guess. The noises you hear is likely the mount being lose.
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
The Following User Says Thank You to Bexar For This Useful Post:
Tomas Novak (09-26-2017)
 Old 10-09-2017, 01:56 AM   #3
It was the freewheel.
Hope that helps someone with same issue...
Odd Rattling/Grinding Noise bryancregger 2010 MS3 - Engine, Transmission & Driveline 4 05-14-2014 06:46 AM
Rattling noise when clutch disengaged nero 2010 MS3 - Engine, Transmission & Driveline 13 10-03-2013 05:48 AM
Help with a rattling noise Massh0le MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 04-18-2013 07:38 AM
MS3 Front End rattling Noise HElP racersir MazdaSpeed 3/6 - Suspension & Brakes 1 12-02-2012 01:58 PM
Rattling Noise!?!? Plz help?!?! mazdaspeed619sd MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 01-30-2009 01:08 PM
Page generated in 0.24098 seconds with 22 queries
