 Old 03-06-2011, 04:11 PM   #1
Silverado2's Avatar
Posts: 7   (View Stats)
Silverado2 has a little shameless behaviour in the past
Default Suspension squeak in cold weather
I was wondering if anyone else was having this problem. During fairly cold weather (20 deg or less) the suspension squeaks pretty good when going over a bumb at a decent spead. Not sure if it is coming from the front or read but am leaning towards the rear. Had it in the dealer yesterday and of course they were not able to reproduce the condition (it was around 50 deg...of course they couldn't). Thanks.
Let's Drive!
Silverado2 is offline   Reply With Quote
 Old 03-06-2011, 04:19 PM   #2
R.MS3's Avatar
Posts: 987   (View Stats)
It's normal on these cars, not an issue really.
R.MS3 is offline   Reply With Quote
 Old 09-01-2011, 12:31 AM   #3
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
I have been having a weird squeak coming from what I believe is the front drive side. It only happens when I go over a bump in the road such as an uneven section. It has started within the last 100 miles and I cant figure it out. The squeak is similar to the sound a gerbil wheel going around. That is the best way I can describe it. Any ideas??
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
 Old 09-01-2011, 03:04 PM   #4
Kris Speed3 CWP's Avatar
Posts: 303   (View Stats)
Kris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond reputeKris Speed3 CWP has a reputation beyond repute
Groans: 32
Groaned at 80 Times in 41 Posts
yeah the car Squeaks from all four corners its the bushings, at -15 Celsius you hear the car creak over bumps. At -22C it squeaks over every expansion joint or just plain anything on the road!! All Northern dealers know about this but their is no current solution to it.
As one person said in another thread upgraded to grease-able bushings, or if your Mazda Canada just say that their is no defect in Mazda materials or workmanship and deny any sort of warranty claim without even looking at the problem.
p.s I think this will be my next fight with MCI as its annoying as fuck when driving up north to go snowboarding with the wind chill at -38C at times. Its relentless!!! LMAO
Street Unit RMM 62 durameter 2-piece, solid shifter bushings, TWM short throw shift kit,Amsoil synthetic gear lube, Corksport Metal Skid Plate,6,000K philip Ultinon bulbs, 3,000K Le Mans yellow Fog light H.I.D's
Kris Speed3 CWP is offline   Reply With Quote
Cold weather suspension noise Stew-o MazdaSpeed 3/6 - Suspension & Brakes 33 03-21-2011 02:20 PM
2010 speed3 Suspension creaking in cold weather v277480 2010 MS3 - Suspension & Brakes 22 03-06-2011 04:57 PM
Squeak from the left front suspension. 9900rpm 2010 MS3 - Troubleshoot/Diagnostics 2 01-20-2010 03:17 PM
cold weather mmv3 2010 MS3 - Engine, Transmission & Driveline 3 12-07-2009 12:33 PM
Cold weather cut wassup61 MazdaSpeed 3/6 - ECU Computer Tuning 15 02-10-2009 03:04 PM
Page generated in 0.25140 seconds with 23 queries
