-   2010 MS3 - Troubleshoot/Diagnostics (http://www.mazdaspeedforums.org/forum/f436/)
-   -   Sway Bar Bushing Noise (http://www.mazdaspeedforums.org/forum/f436/sway-bar-bushing-noise-214786/)
tmaiorca 11-10-2017 04:08 PM
I've had a pretty bad annoying clunking/rattling sound coming for the rear for quite some time, so I decided to replace my sway bar end links with MevoTech ones since the OEM ones were shot.
Unfortunately, the clunking has gotten worse and its driving me insane. I suspect it is the sway bar bushings, but what do you guys think? On the most level roads without and cracks/potholes, the noise is extremely loud.
Link to vid (really starts to be present at 10 seconds): https://www.youtube.com/watch?v=Tt8pV6--A5E
Rygar 01-12-2018 06:26 AM
Did you replace the bushings?
Mine sounds like this and from some internet sleuthing the likely culprit is the sway bar bushings. I have OEM replacements but haven't done the work yet.
When it gets particularly cold (around -5°C or less) the clunking turns into squeaking.
kTaLgsTo 01-12-2018 06:43 AM
Sounds like your end links aren't tight to me....
Rygar 01-12-2018 07:24 AM
That's also been a common thing I've read in relation to these noises/bushing blame.
Thor Hammer 01-12-2018 10:55 AM
If you spray some lubricant into the bushings they will quiet down. It works for me and many others.
Page generated in 0.24787 seconds with 11 queries
