  • 1 Post By Thor Hammer
 Old 11-10-2017, 04:08 PM   #1
tmaiorca's Avatar
Posts: 192   (View Stats)
tmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of light
Default Sway Bar Bushing Noise
I've had a pretty bad annoying clunking/rattling sound coming for the rear for quite some time, so I decided to replace my sway bar end links with MevoTech ones since the OEM ones were shot.
Unfortunately, the clunking has gotten worse and its driving me insane. I suspect it is the sway bar bushings, but what do you guys think? On the most level roads without and cracks/potholes, the noise is extremely loud.
Link to vid (really starts to be present at 10 seconds): https://www.youtube.com/watch?v=Tt8pV6--A5E
RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG
2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR
tmaiorca is offline   Reply With Quote
 Old 01-12-2018, 06:26 AM   #2
Rygar's Avatar
Posts: 21   (View Stats)
Rygar is an unknown quantity at this point
Did you replace the bushings?
Mine sounds like this and from some internet sleuthing the likely culprit is the sway bar bushings. I have OEM replacements but haven't done the work yet.
When it gets particularly cold (around -5°C or less) the clunking turns into squeaking.
2010 Mazdaspeed3
1998 Lancer Evolution
Rygar is offline   Reply With Quote
 Old 01-12-2018, 06:43 AM   #3
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Sounds like your end links aren't tight to me....
 Old 01-12-2018, 07:24 AM   #4
Rygar's Avatar
That's also been a common thing I've read in relation to these noises/bushing blame.
2010 Mazdaspeed3
 Old 01-12-2018, 10:55 AM   #5
Thor Hammer's Avatar
Posts: 1,788   (View Stats)
Groans: 203
If you spray some lubricant into the bushings they will quiet down. It works for me and many others.
Rygar likes this.
How-To: Front Sway Bar Bushing replacement w/o dropping subframe DeadWayt MazdaSpeed 3 - How-To's 66 11-29-2018 08:40 PM
Easy OEM Front Sway Bar Bushing Replacement spl 2010 MS3 - Suspension & Brakes 7 12-30-2017 07:42 PM
How-To: MS6 Front Sway Bar Bushing TiGraySpeed6 MazdaSpeed 6 - How-To's 44 08-23-2017 09:16 AM
MS6 driver-side sway bar bushing removal wdautrem MazdaSpeed 3/6 - Suspension & Brakes 16 06-01-2012 10:44 PM
Page generated in 0.30277 seconds with 23 queries
