 Old 05-16-2012, 06:43 PM   #1
Itchy's Avatar
Posts: 44   (View Stats)
Itchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of lightItchy is a glorious beacon of light
Default Timing Chain Service Interval
I got a strange email from my dealership the other day:
"Our records indicate that your vehicle may have reached or exceeded its recommended interval to have its engine timing belt replaced. We strongly suggest you come in and have this service performed soon, as your vehicle’s engine could suffer severe internal damage should the timing belt break or jump timing."
I couldn't actually find what Mazda specifies as the timing chain replacement interval, but I am assuming it is somewhere around the valve clearance service (@75,000 miles) I am at 20,000 miles.
Did anyone else receive something like this?
Itchy is offline   Reply With Quote
 Old 05-16-2012, 06:56 PM   #2
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
lol wrong car. we use a chain, not a belt.
 Old 05-16-2012, 11:13 PM   #3
intotheice's Avatar
Posts: 85   (View Stats)
intotheice is just really niceintotheice is just really niceintotheice is just really niceintotheice is just really niceintotheice is just really nice
Chain lasts for a long time and are much durable than belt, they usually last the life of the vehicle...
intotheice is offline   Reply With Quote
 Old 05-17-2012, 02:32 PM   #4
Shadow's Avatar
Posts: 430   (View Stats)
Shadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the world
Ya this seems like maybe something bugged on their end. Not only do you not service chains unless problem, but the lowest milage belt I've changed is 60k. Just ignore it, save it as proof that mazder stealerships are dumb.
sent from my phone because computers scare me.
2012 Black Mica MS3 w tech
Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else
Shadow is offline   Reply With Quote
 Old 05-17-2012, 07:24 PM   #5
Itchy's Avatar
I thought this was their nice way of telling me to come in for the VVT & TC Extended warranty. I wonder what car they think I have?
 Old 05-17-2012, 07:25 PM   #6
Shadow's Avatar
03 Honda civic? Lol.
 Old 05-18-2012, 11:45 AM   #7
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Quite the fail on their behalf.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 02-14-2018, 05:49 AM   #8
dillstaaaa's Avatar
Posts: 8   (View Stats)
dillstaaaa has a little shameless behaviour in the past
Did you change it because something went wrong or just preventative maintenance? I'm just asking because mine is at about 52k right now
Sent from my SM-G955U using Tapatalk
dillstaaaa is offline   Reply With Quote
The Following 2 Users Say NO Thank You to dillstaaaa For This Un-useful Post:
Db09ms3 (02-14-2018), Thor Hammer (02-14-2018)
 Old 02-14-2018, 05:51 AM   #9
kTaLgsTo's Avatar
Posts: 538   (View Stats)
This is why we can't have nice things....
Shadow: Last Activity: 05-26-2014 06:47 AM
kTaLgsTo is online now   Reply With Quote
 Old 02-14-2018, 06:58 AM   #10
Amplified's Avatar
Posts: 70   (View Stats)
Amplified has a spectacular aura aboutAmplified has a spectacular aura aboutAmplified has a spectacular aura about
Just a little search and you’ll find out how to check it.
When to check timing chain tension?
2012 Black Mazdaspeed3 w/ Tech
COBB TIP | DM Oil Catch Can | DM Short Shift Plate | DM EGR Delete
need to buy: AT internals, AP v3
need to install: DM RMM, COBB SRI, TS Shifter Bushings
Amplified is offline   Reply With Quote
 Old 02-14-2018, 08:03 AM   #11
flapjack's Avatar
Posts: 107   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
Do some research instead of reviving 6 year old thread to ask a question to a user that hasn't been active in 4 years....
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ COBB SRI & TIP \\ CPE 3.25" TMIC \\ TurboXS 3" Catless DP \\ 3" Resonated Midpipe Back \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Stratified Stage 3 E30 Mix S-OTS \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
 Old 02-14-2018, 08:52 AM   #12
Db09ms3's Avatar
Posts: 211   (View Stats)
Db09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant future
 Old 02-14-2018, 04:29 PM   #13
Fstrnyou's Avatar
Posts: 1,631   (View Stats)
Someone turn on the feature that prevents noobs from posting until they've shown proficiency in searching.
My luck, I'll ask as dumb ass question tomorrow and get flamed.
2006 MS6 GT - 152k Miles
Versatuner, 3-bar MAP, ITV22's
Russian Bushings in Back, Magnaflow CBE
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff & 2618, King Bearings
Other rides:
History:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f436/timing-chain-service-interval-113929/
Does a 2009 Mazda 3 has timing belt or chain This thread Refback 06-29-2013 02:19 PM
Timing chain Boosted Beluga MazdaSpeed 3 - How-To's 10 03-21-2013 10:48 AM
timing chain (almost) dspider CX-7 > Engine, Transmission & Driveline 2 03-07-2011 11:30 AM
Timing chain slack? Thestaplegunkid MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-05-2009 02:47 PM
Page generated in 0.31797 seconds with 30 queries
