![]() | | #1 | ![]() |
| USMC Shooting Team ![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 383 ![]() Thanks: 2,117
Groans: 38
Groaned at 18 Times in 11 Posts
(Thread Starter) | Not Ranked : 0 score It has a sloppy idle, and at first it even burned a little oil (smoke for the engine bay). After some modest driving, it won't even go past 4000 RPM's. I am getting codes P0089, P0171 (Lean) P0191(Fuel Rail Sensor Circut Range/Performance) and U0100. I was very meticulous when installing the Fuel Pump internals, but I am thinking that is probably where my issue lies? I can not find any exhaust leaks any where… Any input is appreciated. |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 932
Groaned at 35 Times in 24 Posts
Logs? Are you monitoring fuel pressure? What map did you load? Check all electrical connections. Maf/o2 sensor (could have been damaged during dp install)/ electrical connection to the fp.... This is why its wiser to do things 1 at a time Wow... Just realized this is your first post... Guessing you've never even read up on any of thus, and now you want the best online support available, for free. You were told this was the best forum ever, but you didn't utilize it until it was too late.
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 Last edited by Fatguy729; 08-04-2012 at 03:13 PM. Reason: MSF Database - Automerged Doublepost |
Groans: 38
Fuel pressure is where it should be at, my map was OTS from Cobb Stage 2+ CS intake with TIH+HPFP 91. All connections are good, O2's are good. I installed my intake first, ran good, then Cobb, ran good, then HPFP internals and down pipe and that's when I ran into issues. I however did fuck up royally and realize now that I know what happened. I started it up after finishing the Fuel Pump and DP with the MAF disconnected, from working on the fuel pump. Then, as it was running, I plugged in my MAF and a little smoke cane out from the Sensor side of the harness. I'm thinking I blew my MAF sensor, however I can still get readings through my AP. So that doesn't make sense. I have no boost or vacuum leaks either, I've checked for all that. If it is my MAF, where (besides the dealer) can I get a new one? Searching this forum or googling isn't really coming up with narrowed results. And I'm not familiar with blow through MAF setups. |
![]() | | #4 | ![]() |
![]() Join Date: Nov 2011 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 13 Times in 3 Posts
OEM Mass Air Flow Sensor: MAZDASPEED 3, MAZDASPEED 6 | |
| The Following User Says Thank You to ThizSpeed3 For This Useful Post: | ABolewski (08-04-2012) |
![]() | | #5 | ![]() |
I'm thinking your primary o2, but I'm no expert, especially since you did so much at once. Take a log. What do your trims look like?
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
![]() | | #6 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 1187 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,971
Groans: 153
What are your fuel pressure, afr and fuel trims like at idle. Tapa |
![]() | | #7 | ![]() |
Groans: 38
With some googling I found one at AutoZone, $120 in exchange for my fucked up one. All I did at once was fuel pump and down pipe. I thought AFR was fuel trims? Cause my AFR reading was 14.7, fuel pressure was Act: ~65 Des: 450/470. I've read about cleaning O2 sensors. I'll look into that and try it tomorrow before I go buy my MAF sensor. Cause it was installed for 3 and a half days (started on Down Pipe Tuesday night. Finished Saturday morning) do you think that it may have gotten dirty while out? Possibly damaged? What should I look for when I take it out tomorrow? |
![]() | | #8 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 6457 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,843
Groans: 58
Long Term Fuel trims (LTFT) But you say that when you plugged in the MAF a puf of smoke appeared from the harness? Where are you located?
__________________ Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu! |
![]() | | #9 | ![]() |
| NATOR IN - First 9 ![]() Join Date: Mar 2010 Location: Indy
Rep Power: 458 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
~65psi is the in tank pump. You should be getting around 450 at idle and >1600 at WOT.
__________________ 2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR 70D TMM, SSB, EGR Plate 2008 Silver MS3: Sold | |
| The Following 3 Users Say Thank You to kabobulate For This Useful Post: |
![]() | | #10 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, Illinois
Rep Power: 6792 ![]() Thanks: 10,658
Did you plug in the HPFP when you put it all back together? Two prong plug on the top of the HPFP.....I'd almost bet it isn't plugged in, lolol. P0191 is the code that pops when you unplug it. If not that, your internals could be seized, as kabobulate mentioned.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold |
| The Following User Says Thank You to phate For This Useful Post: | skeeter149 (08-05-2012) |
![]() | | #11 | ![]() |
Groans: 58
What does this mean "Act: ~65 Des: 450/470." 65 degrees That plug is the spill valve, But still interested in the puff of smoke.
![]() | | #12 | ![]() |
His actual pressure is ~65psi and is desired pressure is 450/470 because he is looking at it at idle.
![]() | | #13 | ![]() |
References, lol: me jumpering the spill valve solenoid: E85 Discussion - HPFP lubrication and Flow issues And an explanation of the spill valve operation: E85 Discussion - HPFP lubrication and Flow issues
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold | |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #14 | ![]() |
...and the references were not necessary, jerk. lol
| The Following User Says Thank You to kabobulate For This Useful Post: | phate (08-04-2012) |
![]() | | #15 | ![]() |
Groans: 38
Ok so I'll check the plug again. It's worth a shot. I'm in San Diego, CA. If my internals are messed up, I could take them out, clean them with non chlorinated brake cleaner and put them back together again, right? So it does make sense that my fuel pump may be fucked. I thought I did it perfect, according to te write up in the How to collection on here. I guess I'll redo it tomorrow? I was careful reinstalling it too, ensuring the spring was straight. EDIT: Connection was good on the plug. So my internals are seized most likely? I have no idea what went wrong then. Luckily I met a few guys that have done it before on this forum so maybe I can get their help tomorrow. I should be able to take it out and rebuild it just fine right? Or do you think it has been damaged already? |
![]() | | #16 | ![]() |
| Not Ranked : 0 score LOL, tis why I posted them! Edit: and I just wanted to reference myself
![]() | | #17 | ![]() |
Groans: 38
Any way this is what happened With the smoke Kritz. I had just finishined installing the down pipe and HPFP and started her up. I noticed quickly that the MAF was unplugged, I plugged it in and a puff of smoke (like when you attatch the negative to a the battery) puff up from the female (sensor) of the connection. Didn't hear anything, or smell burning really, but that's what happened. I'm still getting a reading from it though. I think you all narrowed it down to the pump.
| The Following User Says Thank You to ABolewski For This Useful Post: | kritz (08-04-2012) |
![]() | | #18 | ![]() |
. Did you disconnect your negative battery cable while doing the installs?
![]() | | #19 | ![]() |
| highest hp speed6 in cali ![]() Join Date: Nov 2010 Location: Nator San Diego, CA
Rep Power: 3193 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 191
Groaned at 326 Times in 194 Posts
My god, call me when you get a chance, don't drive the car, ill come by and see if I can give you a hand tomorrow
| The Following 7 Users Say Thank You to Joe Isuzu For This Useful Post: | Easter Bunny (08-06-2012), Fatguy729 (08-04-2012), kabobulate (08-04-2012), kritz (08-04-2012), lilred (08-04-2012), phate (08-04-2012), smoogs12 (08-05-2012) |
![]() | | #20 | ![]() |
Groans: 38
Yes the battery was actually out the whole time. But I know, not thinking, and excited to put it all together. However I think it's the pump, I'm still getting all my info from my MAF sensor. Hopefully rebuilding the pump tomorrow fixes it all.
![]() | | #21 | ![]() |
Groans: 58
Always good to have a few knuckleheads around who have some installs under their collective belts to help keep the fail away!
![]() | | #22 | ![]() |
Groans: 191
| Not Ranked : 0 score |
![]() | | #23 | ![]() |
Groans: 38
Haha yea I didn't know the community was so big. I didn't think there's be other people so familiar with these cars around! Thanks everyone for the help.
![]() | | #24 | ![]() |
Groans: 58
| Not Ranked : 0 score Yes, it is a good start! LOL
![]() | | #25 | ![]() |
![]() Join Date: Apr 2012 Location: irving,Texas
Rep Power: 122 ![]() Thanks: 91
Please tell me that you. Oiled your internals before install and cycled your pump 3 times before actually starting it? If not, DOIT!
__________________ 08 sunlight metallic |
| The Following User Says Thank You to rolanblack For This Useful Post: | ABolewski (08-05-2012) |
![]() | | #26 | ![]() |
Groans: 38
I did oil them all with fresh motor oil. How are you supposed to cycle the pump? I mean it's too late now, but I'll do that tomorrow after we take it apart tomorrow and rebuild it.
![]() | | #27 | ![]() |
Groans: 38
So last night the car drained my battery somehow. Totally shot. AP was not even plugged in over night. Had to get AAA to come unlock it. $53, fun stuff. Idled it back to the garage I'm working on it at, and took out the fuel pump, took it all apart, it all was correct (looked at every instruction and how too) and cleaned and re oiled it all. Put it back in, back together, started car, same problems as before, as far as I know. I can't tell what the fuck is going on cause now my AP won't even fucking turn on when I plug it in! What the hell does that mean? Now there's electrical issues from a down pipe and fuel pump install? $25,000 paper weight. Fantastic.
__________________ 2010 Alternative Lifestyle Blue Pu 2006 Suzuki DRZ400 SuperMoto |
![]() | | #28 | ![]() |
Check fuses?
![]() | | #29 | ![]() |
| Track Fiend ![]() Join Date: Jan 2012 Location: Canada
Rep Power: 161 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 586
Relax. Check your connections, youve obviously got an electrical problem, and you JUST worked on the car.. Coincidence ? No.. Start diagnosing. |
| The Following User Says Thank You to Standsideways For This Useful Post: | ABolewski (08-05-2012) |
![]() | | #30 | ![]() |
Groans: 38
Checked all fuses. Passenger mirror fuse was oddly damaged, replaced even though it wasn't burnt. Didn't fix anything, not I saying I expected it too, it was just weird. Running through all my connections now. Am I missing a fuse box somewhere? I figured there'd be more in this car. The one to the left of the steering wheel, and the one next to the battery is all I have found. Just trying to make sure I'm not missing anything. O2 connections are all good, fuel pump, MAF. I don't know what else to go over. I checked all the other miscellaneous things I could see. No apperent issues. What I'm mostly concerned with is the fact that my field pump is still not working. It's all put together perfectly. I know that's my problem. I just have to figure out why my AP isn't getting power now. Does the connection with the male pins go bad often? And is it warrantie since I just purchased it a month ago?
__________________ 2010 Alternative Lifestyle Blue Pu 2006 Suzuki DRZ400 SuperMoto Last edited by ABolewski; 08-05-2012 at 12:34 PM. |
![]() | | #31 | ![]() |
Groans: 153
Dude, take Derek (chinkus) up on his offer if you haven't already. Give him a call. He'll set you straight. Tapa |
| The Following User Says Thank You to smoogs12 For This Useful Post: | ABolewski (08-05-2012) |
![]() | | #32 | ![]() |
Groans: 38
Really confused as to why my AP stopped working.
__________________ 2010 Alternative Lifestyle Blue Pu 2006 Suzuki DRZ400 SuperMoto | |
![]() | | #33 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 879 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 389
Subbed in before epicfail Sent from my dizzLe using RaWr powers!
__________________ 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Next: TMIC(WTB PM me); meow DP Official 60-100mph Times Official Youtube Channels | |
| The Following 2 Users Say Thank You to ms3rick For This Useful Post: | ABolewski (08-05-2012), rolanblack (08-05-2012) |
![]() | | #34 | ![]() |
Groans: 153
So I was thinking about this issue a little bit, and I have a theory but I need to validate it with a few questions first. a. Does the spill valve rely on a relay? (if not disregard the other questions, my theory is blown lol) b. If it does use a relay is it normally open or normally closed? c. When the spill valve receives the signal from the relay (if there is one), does it build pressure or bleed it away? phate or anyone who knows the answers. |
![]() | | #35 | ![]() |
See above references for spill valve operation, lol. Without powa, it is open and "spills" fuel. With powa, it closes and allows pressure to build.
![]() | | #36 | ![]() |
Groans: 153
Was thinking maybe it was a stuck relay draining the battery and causeing fuel to spill. Theory blown. | |
| The Following User Says Thank You to smoogs12 For This Useful Post: | phate (08-05-2012) |
![]() | | #37 | ![]() |
Groans: 38
I did not prime the pump before I started it. No write up said anything about that, so I wasn't familiar with how to do that. Where is the relief valve located? How do I check it? Another note, plugged in Cobb AP to computer, nothing happened. So somehow that thing is fried I guess. Guess I'm making some calls and getting it warrantied. My packaging for it is 100 miles north though. So I gotta get that mailed to me first.
![]() | | #38 | ![]() |
The relief valve is located on the end of the fuel rail. Sorta above the starter...but on the fuel rail. At 65psi, I really doubt that's the problem, though. Without the ability to see fuel pressure it's tough to diag things. BUT, once you can monitor it, I would jumper the spill valve solenoid to verify operation. Edit: I've pulled my pump probably upwards of 50++ times, and there were a few re-assemblies where I forgot to prime the pump, lol. Never did anything, so I wouldn't worry much about it, especially if you oiled the internals.
| The Following User Says Thank You to phate For This Useful Post: | ABolewski (08-05-2012) |
![]() | | #39 | ![]() |
Groans: 58
The relief valve is easy to test correct me if I am wrong phate once the engine is warmed up keep the AP on and set to FP, turn the car off and leave the key in the on position what you should see is the FP increase if it drops the relief valve has failed. superskaterxes has a how to on replacement.
![]() | | #40 | ![]() |
Groans: 38
I'll check on that tomorow night probably. I have a button start so I'd have to figure out a different way to test that. My internals were oiled, I'm confident they are fine. Tomorrow I'm probably replacing my MAF sensor. Although that doesn't explain my fuel pressure, I feel that it is damaged from the smoke. I'll call Cobb tomorrow and thanks for the heads up about not need packaging. Hopefully that all goes smoothly. Thanks everyone for the advice. I want this thing to run so bad!
| having trouble, help please! | neptune03 | MazdaSpeed 3/6 - Suspension & Brakes | 12 | 09-12-2012 06:07 AM |
| whos done a diy vvt instal? | 2006MS6 | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 01-02-2012 01:54 PM |
| HPFP internals or new HPFP? | JAGspeed6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 11 | 11-26-2011 01:34 PM |
| Is this right(meth instal) | wisniaPl | Devils Own Alcohol Injection | 9 | 03-04-2009 06:41 PM |
