Notices
 Old 10-24-2012, 12:21 AM   #1
wills_mazda's Avatar
Posts: 5   (View Stats)
wills_mazda is an unknown quantity at this point
Default Unknown hole, please help?
We have a brand new block built by CPE that we just finished getting put together and installed in my 2011 MS3. We went for first start and started gushing oil. We located the source and here is a picture. We can fix it, but we are curious what it is for. It is located beneath the passenger side engine hoist hook behind the idler pulley. See pics. Please help and thank you very much.
wills_mazda is offline   Reply With Quote
 Old 10-24-2012, 12:24 AM   #2
dantes5823's Avatar
Posts: 6,674   (View Stats)
Um. Gen1 cars have their power steering pump there. Gen2 have a tensor for the belt. In which case there is either a pump or a plate there. Not the two threaded holes beside it. If you started the motor.... What do you have as far as a belt? I know nothing of what the cpe motors come with. But oods are you probably need to reuse accessories from old motor.
Edit:read fail. You have the plate there. I don't think anything is hooked up there normally. So plug it up I guess. Or call cpe in the morning.
 Old 10-24-2012, 12:28 AM   #3
That hole has oil pressure seeming that it was designed to supply oil to something external, an accessory of some sort but not used? Does just a bolt go there, or can a sensor go there?
Also, the tensioner is at the bottom of the engine. This is behind the idler pulley located on the upper end of the engine. Under the engine hoist hook.
Last edited by wills_mazda; 10-24-2012 at 12:28 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-24-2012, 12:29 AM   #4
dantes5823's Avatar
This is the hoist to the left of the intake manifold correct?
 Old 10-24-2012, 12:31 AM   #5
Yes it is. The one towards the front of the car, passenger side. Right beside the intake manifold.
 Old 10-24-2012, 12:32 AM   #6
dantes5823's Avatar
Look for the shop manual on the site. I'm on Tapatalk and can't see if your brown or not. If your brown and just swapped a motor then wtf. I would imagine it's plugged tho. Anyways its late. Best of luck. Get the manual or call cpe.
 Old 10-24-2012, 12:37 AM   #7
I don't understand what you mean by if I am brown or not? I am new to this forum. When we got the engine, it was not plugged. That's why we are concerned. We want to know what should or can go there so we stop gushing oil.
Appreciate the advice though. We will look for the manual.
 Old 10-24-2012, 12:41 AM   #8
dantes5823's Avatar
Christ you are brown. Your gonna need to donate to get those shop manuals. Guess your calling cpe. But seriously donate. I doubt this is gonna be your only issue.
The Following 2 Users Say Thank You to dantes5823 For This Useful Post:
amggilly305 (10-24-2012), Cujo (10-31-2012)
 Old 10-24-2012, 01:14 AM   #9
Stangcobra's Avatar
Posts: 587   (View Stats)
Groans: 51
Put your dick in it.
Kevin is a huge faggot
The Following 19 Users Say Thank You to Stangcobra For This Useful Post:
86azms3 (10-24-2012), adlpb (10-24-2012), breakfstincluded (10-24-2012), Crarrs (10-24-2012), Cujo (10-31-2012), CWP_MS3 (10-24-2012), dantes5823 (10-24-2012), Dralphy (10-24-2012), Easter Bunny (10-24-2012), easy (10-24-2012), gearhead750 (10-24-2012), I_Heart_Haters (10-24-2012), Kamaril (10-24-2012), motherfnmonsta (10-26-2012), Pointless (10-24-2012), Raider (10-24-2012), Roddiy (10-24-2012), silvapain (10-24-2012), tddvrrn (10-24-2012)
 Old 10-24-2012, 01:26 AM   #10
86azms3's Avatar
Posts: 3,000   (View Stats)
86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world
Groans: 242
Groaned at 70 Times in 36 Posts
Right!...that's what holes are for.
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP,
Turbosmart Hybrid bpv, SURE TIG's + coolant bypass,
ITV24's, CP-E 75d RMM, Medefail Tranny mount,
DDM 35W 6000K HID's, SURE Counterweight,
18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's
390whp/400wtq
86azms3 is offline   Reply With Quote
The Following 9 Users Say Thank You to 86azms3 For This Useful Post:
Crarrs (10-24-2012), Cujo (10-31-2012), dantes5823 (10-24-2012), easy (10-24-2012), gearhead750 (10-24-2012), Pointless (10-24-2012), silvapain (10-24-2012), Stangcobra (10-24-2012), zkrick (10-24-2012)
 Old 10-24-2012, 06:31 AM   #11
Scammer Hunter
Raider's Avatar
Posts: 15,031   (View Stats)
Groans: 449
Groaned at 105 Times in 88 Posts
OP, call CPE.
If you want the MS3 manual, it is in VIP. In order for VIP access, you need to donate $25 for the forum to get VIP access.
MSF Moore OK Tornado Recovery Donation Thread
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
 Old 10-24-2012, 06:37 AM   #12
Posts: 5,628   (View Stats)
Groans: 121
It's an unused port. Just plug it and you're golden.
 Old 10-24-2012, 08:34 AM   #13
@ silvapain - appreciate it! Exactly what we needed
 Old 10-24-2012, 09:01 AM   #14
tddvrrn's Avatar
Posts: 2,572   (View Stats)
Groans: 103
wait, you trust what he's saying just because it's what you wanted to hear. you crazy.
silvapain does know what he's talking about, though. i just question your method for analyzing sources of info.
edit: went and looked, my gen 1 has the power steering pump in front of that hole, but the hole is plugged with a bolt.
The Following User Says Thank You to tddvrrn For This Useful Post:
Keko (10-24-2012)
 Old 10-24-2012, 09:44 AM   #15
dantes5823's Avatar
I said like three times to plug it. And then wtf is the point for that whole?
 Old 10-24-2012, 09:52 AM   #16
supertubesocks's Avatar
Posts: 356   (View Stats)
supertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the world
Dicks!
Sent from my PC36100 using Tapatalk 2
supertubesocks is offline   Reply With Quote
The Following 6 Users Say Thank You to supertubesocks For This Useful Post:
86azms3 (10-24-2012), Cujo (10-31-2012), dantes5823 (10-24-2012), Keko (10-24-2012), silvapain (10-24-2012), Stangcobra (10-24-2012)
Help.. Unknown vibration nebolskeetskeet MazdaSpeed 3/6 - Suspension & Brakes 26 08-26-2012 12:00 PM
Unknown reason for knocking SoFla_Speed6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-17-2011 09:05 AM
My MS6 vs 2010 GTI (unknown mods) greg08 Street Racing Stories ( Bench Racing ) 3 12-13-2010 07:44 AM
Page generated in 0.37372 seconds with 28 queries
