Notices
Like Tree8Likes
  • 1 Post By manilaMS12
  • 1 Post By Mizzle
  • 1 Post By rfinkle2
  • 1 Post By atvfreek
  • 1 Post By Lex
  • 2 Post By Mizzle
  • 1 Post By Tokay444
 Old 07-29-2012, 08:31 AM   #1
rfinkle2's Avatar
Posts: 12,563   (View Stats)
Groans: 235
Default Vibration under > 10 psi boost
Raider / MOD? could you change thread title to vibration > 10 psi boost?
Msf peeps,
Drove through some very heavy rain last night and now have a heavy vibration / studder @ > 10 psi.
Car drives fine under vacuum and up to when bcs starts to activate.
All searching leads me to believe it is a bad coil pack, but could use opinions.
-Pulled plugs,
-no condensation / water,
-blew out maf and ecu connections with no luck.
-cleaned maf sensor
-replaced air filter (in case one was wet / moist)
-started crying a little
Could use a hand diagnosing.
EDIT: received p0300
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
rfinkle2 is online now   Reply With Quote
08.5MS3 (07-29-2012), atvfreek (07-29-2012)
 Old 07-29-2012, 08:38 AM   #2
rfinkle2's Avatar
Groans: 235
Also, did not attempt much boosting, but boost seems limited somehow...i.e. boost seems low.
 Old 07-29-2012, 09:04 AM   #3
rfinkle2's Avatar
Groans: 235
Sweet! Just got a p0300 fml.
 Old 07-29-2012, 09:29 AM   #4
Mizzle's Avatar
Posts: 2,578   (View Stats)
Groans: 297
Groaned at 186 Times in 102 Posts
Lame.
Think it's still water somewhere or something got eff'd up?
The Following User Says Thank You to Mizzle For This Useful Post:
rfinkle2 (07-29-2012)
 Old 07-29-2012, 09:31 AM   #5
rfinkle2's Avatar
Groans: 235
I do. Something got wet. Log attached.
 Old 07-29-2012, 09:38 AM   #6
Mizzle's Avatar
Groans: 297
lol that was an either-or question sir.
or are you saying something got wet AND then got permanently fucked up?
( I can't decipher logs. )
 Old 07-29-2012, 09:41 AM   #7
rfinkle2's Avatar
Groans: 235
Still wondering wtf is going on tbh. LOL.
The rain is suspect #1, although my logs are lean and the wgdc that is in the log usually produces much higher boost levels.
 Old 07-29-2012, 09:46 AM   #8
Mizzle's Avatar
Groans: 297
I'm gonna saaaaay you sucked up some water, it went all the way thru to your throttle plate, collected like in the Abyss and the back-pressure blew a line off that involves boost somewhere.
 Old 07-29-2012, 09:51 AM   #9
rfinkle2's Avatar
Groans: 235
Could be Mizzle. @ this point, I have, p0300, low boost, an erratic afr..
and the fact that I drove through heavy rain last night...
The car was fine last night, sat overnight and went to get gas today, on the way to get gas, this pleasant surprise brightened my day!
 Old 07-29-2012, 09:53 AM   #10
Mizzle's Avatar
Groans: 297
lol
WD40 everything except your exhaust and your belt.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
atvfreek (07-29-2012), rfinkle2 (07-29-2012)
 Old 07-29-2012, 09:54 AM   #11
manilaMS12's Avatar
Posts: 1,015   (View Stats)
manilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the world
Groaned at 17 Times in 11 Posts
rfinkle2 Not sure what's going on man, but hope you get this sorted out!
'12 MS3 Black Mica w/ Tech
Power: COBB AP > HTP 3.5" > ATP DP (CATLESS) > AUTOTECH INTERNALS > GFB RESPONS > NGK PLUGS
OTHER: JBR 88DURO RMM > SSP >BUSHINGS > KNOB > RSB
VOODOO TOON in progress (Thanks to fortressofcomfort)
manilaMS12 is online now   Reply With Quote
The Following User Says Thank You to manilaMS12 For This Useful Post:
 Old 07-29-2012, 09:57 AM   #12
rfinkle2's Avatar
Groans: 235
If there is water in the plug well, how would I clear that?
 Old 07-29-2012, 10:08 AM   #13
Mizzle's Avatar
Groans: 297
WD40 to displace it (loosen it's grip from the metal,) and then canned air, dry-fire paintball gun, compressor blast, shop-vac as a blower, twist paper towels up into cones and stuff them in there, heat-gun to evaporate, halogen lights just making everything hot under the hood, aquarium air-line used as a siphon...
 Old 07-29-2012, 10:12 AM   #14
atvfreek's Avatar
Posts: 6,311   (View Stats)
Groans: 31
Groaned at 19 Times in 16 Posts
Typically with an ignition misfire, the afr goes rich. The car can't build boost, because not enough exhaust flow to spool it up due to the misfire. I think the maf may be the culprit. Can you unplug it and see if the car will drive. Some cars hate this, but others seem to drive ok with it unplugged.
Freekn tappin
2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS
Perm Tune by the Freek
417hp/395tq
12.903@117.33 Street tires and shitty 2.25 60ft
atvfreek is online now   Reply With Quote
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
rfinkle2 (07-29-2012), SLOWHATCH (07-29-2012)
 Old 07-29-2012, 10:14 AM   #15
rfinkle2's Avatar
Groans: 235
Freekn tappin
I'm pretty sure it will drive that way, but do you want me to boost / try to recreate the issue?
 Old 07-29-2012, 10:14 AM   #16
atvfreek's Avatar
Groans: 31
Was there water in the coil holes?
Freekn tappin
417hp/395tq
The Following User Says Thank You to atvfreek For This Useful Post:
 Old 07-29-2012, 10:32 AM   #17
rfinkle2's Avatar
Groans: 235
I looked @ the outside of the rubber coil surrounds (not wet / oxidised), but it looks as if it is time to look deeper down.
The car ran without the maf sensor plugged in, but must have some sort of failsafe, as it turned off the bcs and every light in my car was on. LOL.
Last edited by rfinkle2; 07-29-2012 at 10:32 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-29-2012, 12:01 PM   #18
rfinkle2's Avatar
Groans: 235
Got it sorted. There was water in the plug wells of the inner two cylinders. Hit it with the shopvac (thanks Mizzle) , pulled the plugs, sprayed with maf cleaner, wiped threads and reinstalled.
Everything is fine now. Thanks Mizzle (as usual) and atvfreek for all of the help (as usual) and to manilams12 for the well wishes.
I have to figure out some way to seal the coil pack to the valve cover a bit better.
SLOWHATCH likes this.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
08.5MS3 (07-29-2012), atvfreek (07-29-2012), SLOWHATCH (07-29-2012)
 Old 07-29-2012, 12:04 PM   #19
atvfreek's Avatar
Groans: 31
Sweet! Good to hear it was something easy to fix.
Freekn tappin
417hp/395tq
 Old 07-29-2012, 12:20 PM   #20
Posts: 9,612   (View Stats)
MAF seems to read correctly. If suspecting coil packs, swap them from cylinder to cylinder or unplug them 1 by 1.
EDIT: Nice ninja fix glad it's good.
 Old 07-29-2012, 12:40 PM   #21
anavrinIV's Avatar
Posts: 2,086   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
I was hoping this was the turning point in you actually installing that 2867...I'm still wanting to see what it can do (as it's looking like my turbo of choice). But I'm glad you got it figured out. I know this test wouldn't have worked on my car because with the maf unplugged the car will barely start...
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
anavrinIV is online now   Reply With Quote
 Old 07-29-2012, 02:19 PM   #22
rfinkle2's Avatar
Groans: 235
I'm getting close. I have the parts and NJspeed3's experience (he has been poking me to get started, and is always down to help me wrench), so it won't be too long now.
I've been sketchy on the oil and water hoses and fittings, but have to man up @ some point and just get into it.
 Old 07-29-2012, 04:53 PM   #23
Mizzle's Avatar
Groans: 297
Honestly, WD40 does a pretty good job of sealing things, but you have to re-treat from time to time. Fun fact: WD means Water Displacement.
Another is white lithium grease spray. Beyond that, I can't think of many other ways.
Off-topic: The American woman who won skeet shooting (giggity,) also has a Shelby Cobra kit car that she built herself.
rfinkle2 and SLOWHATCH like this.
rfinkle2 (07-29-2012), Tokay444 (07-29-2012)
 Old 07-29-2012, 05:03 PM   #24
rfinkle2's Avatar
Groans: 235
Crazy that she has been a medalist in something like 7 straight games. 99 out of 100.
Insane.
 Old 07-29-2012, 05:11 PM   #25
SLOWHATCH's Avatar
Posts: 2,064   (View Stats)
Groans: 202
Groaned at 33 Times in 18 Posts
Glad you got this sorted out. I was starting to lean toward bad gasoline. Funny thing is when I had bad gas in the car a few weeks ago I never even got a cel.
2010 CBM W/ Tech, Cobb AP Tuned by rfinkle2, PTP HPFP, Ported IM,
HTP 3.5" Intake, CS DP, CS TP w/QTP E Cut out, ETS TMIC, D.O WMI D07,
NGK Iridium Ix, JBR EGR Delete, Coolant Bypass, JBR IM TIG, GS EBC 3 Port Mode
JBR TMM 70, JBR RMM 88, JBR SSB, JBR AP Holder, Sure SSP
Swift Springs, Koni Yellows, GC Bump Stops, CS RSB, Ebay Adj. Camber Arms, Sonic Tuning ST8'S 18x8.5 on 245/40/18 NT-05
The Following User Says Thank You to SLOWHATCH For This Useful Post:
 Old 07-29-2012, 05:14 PM   #26
rfinkle2's Avatar
Groans: 235
I hear you on that. The strange thing is the car ran normally @ anything less than 12-15 psi. It took 7-10 instances of the misfire to cause the cel to light.
Thanks btw.
 Old 07-29-2012, 05:17 PM   #27
(Toe-kay)
Tokay444's Avatar
Posts: 9,552   (View Stats)
Groans: 503
Fun fact.
WD-40 invented in Canada.
This is my contribution since the problem has been resolved.
Demodded.
Mwho?
Last edited by Tokay444; 07-29-2012 at 05:17 PM. Reason: MSF Database - Automerged Doublepost
Tokay444 is online now   Reply With Quote
atvfreek (07-29-2012), rfinkle2 (07-29-2012), SLOWHATCH (07-29-2012)
Vibration on MS6 Sal's_MS6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 01-27-2012 11:48 AM
Vibration under acceleration needforspeed6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 12-11-2011 10:00 PM
Vibration help!! Crazyspeed3 Mazdaspeed3/6 General Discussion 36 12-10-2011 06:25 PM
Mystery Vibration turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 03-03-2010 05:58 PM
Vibration between 55 and 70 Switters MazdaSpeed 3 - Engine, Transmission & Driveline 12 01-10-2010 08:35 AM
Page generated in 0.51063 seconds with 28 queries
