Like Tree3Likes
 Old 04-11-2014, 07:37 AM   #1
bshotts422's Avatar
Posts: 183   (View Stats)
bshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond reputebshotts422 has a reputation beyond repute
Default white smoke after e85 mix
whats up guys. so monday i decided to put in a 3 gallon mix of e85 on monday, the car is running fine if not better. so i decided to fill back up the same way yesterday. this morning the car is smoking at idle for a few mins then stops. everything on my ap seems to be ok from what i can tell (i aint no expert). i did a datalog yesterday if someone can see if they see anything or what the smoke could be from. mods are cobb downpipe, autotech fuel internals, speed daddy catback, k&n sri
bshotts422 is offline   Reply With Quote
 Old 04-11-2014, 07:38 AM   #2
bshotts422's Avatar
running the stratified stage 2 ots map
 Old 04-11-2014, 07:49 AM   #3
manila's Avatar
Posts: 1,767   (View Stats)
manila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the world
Groaned at 30 Times in 17 Posts
So you're running a OTS map and just decided to throw in some corn?
Did you do this to test for knock or...?
trancehead likes this.
'12 MS3 Black Mica w/ Tech
COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >>
JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >>
HYPNOTIC TUNED: tehmadscientist & senor finkle
manila is offline   Reply With Quote
 Old 04-11-2014, 07:49 AM   #4
Voltwings's Avatar
Posts: 3,713   (View Stats)
Umm the incredibly lean AFR's could have something to do with it... you cant run E85 on an OTS map, you must be tuned for it. id consider 12.4 the leanest i would go on an E85 blend (tuned my own car on that for several years), but even still most people i tune on a 12.2... you're damn near 13 the entire pull.
DoMiNic likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following User Says Thank You to Voltwings For This Useful Post:
Ireland (04-11-2014)
 Old 04-11-2014, 07:56 AM   #5
bshotts422's Avatar
yea i was seeing a little knock here and there nothing major, so someone said drop a couple gallons of e85 to see if it goes away or not. they said if it doesnt go away to its probably just engine noise. im stilling getting about the same knock. so what should i do? just run my car easy or maybe dump some low octane in it. whats causing the smoke?
The Following User Says NO Thank You to bshotts422 For This Un-useful Post:
emag remrofni (04-20-2014)
 Old 04-11-2014, 07:58 AM   #6
danlaroe's Avatar
Posts: 756   (View Stats)
danlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the worlddanlaroe is the leader of the world
Groaned at 7 Times in 4 Posts
White smoke comes out of mine too. From the weed
danlaroe is offline   Reply With Quote
 Old 04-11-2014, 08:00 AM   #7
Ireland's Avatar
Posts: 1,419   (View Stats)
Ireland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the world
Groaned at 119 Times in 22 Posts
2013 Tech Package // NVS tuned // 35% e85
DYNOCOM eddy current chassis dyno @ 332hp 400lbft
Ireland is offline   Reply With Quote
The Following 2 Users Say Thank You to Ireland For This Useful Post:
ms6mil (04-11-2014), SofaKingAwesome (04-11-2014)
 Old 04-11-2014, 08:04 AM   #8
DoMiNic's Avatar
Posts: 571   (View Stats)
DoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the world
Groaned at 8 Times in 7 Posts
You can add a gallon for knock.. like one. You HAVE to change the fuel trims to run 3 gallons. Smoke could be from partially fucked rings, these cars don't like going lean... how long have you been beating on it like this? 2 tanks? do you drive the car hard normally?
TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned
Sold
08 FJ Cruiser Expo build in progress...
DoMiNic is offline   Reply With Quote
The Following 2 Users Say Thank You to DoMiNic For This Useful Post:
El_Diablo (04-11-2014), Voltwings (04-11-2014)
 Old 04-11-2014, 08:05 AM   #9
bshotts422's Avatar
here is a couple logs from last week before i put in the e85. why is the afr so high at the end?
 Old 04-11-2014, 08:10 AM   #10
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
You better baby the shit out of it tell the tank is empty and fill up with just gas and hope the smoking goes away
timmcc02 is offline   Reply With Quote
The Following User Says Thank You to timmcc02 For This Useful Post:
bshotts422 (04-11-2014)
 Old 04-11-2014, 08:23 AM   #11
bshotts422's Avatar
would it help if i add a lower octane fuel or just keep topping it off with 93 to try and dilute the mix?
 Old 04-11-2014, 08:33 AM   #12
DoMiNic's Avatar
I would go top off with 91 or whatever the map calls for, its not about the octain and baby it. Then get e-tuned asap. You could always just contact an etuner and grab a base map for 3 gallons of E. This is what I would do, I know I love me e map!
Sold
The Following User Says Thank You to DoMiNic For This Useful Post:
 Old 04-11-2014, 08:33 AM   #13
Dimenus's Avatar
Posts: 2,825   (View Stats)
Dimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the world
Groans: 33
Why would you add a lower octane fuel?
2012 Velocity Red Mica
Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC
Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps
Dimenus is offline   Reply With Quote
 Old 04-11-2014, 08:46 AM   #14
bshotts422's Avatar
do you have a turner to recommend so i can get a base map asap while im at work? and i figured lower octane might would help. guess i didnt read enough on e before putting some in, i thought 3 gallons wasnt that much
 Old 04-11-2014, 09:04 AM   #15
Voltwings's Avatar
The octane of E85 isnt what causes issues, its the fact that its alcohol instead of petroleum. What this means, is its less volumetrically effecient than normal gasoline / Meaning you need to run more of it at any given time to achieve the appropriate stoich ratio of air to fuel.
You need to scale your fuel injectors to add more fuel so the car can accurately compensate for E85. Also, looking at your knock. While it is consistent, anything under 1* is likely just noise. The computer's logic is to pull 2x the "knock event detected," in timing. Basically a "knock event" of 1* will pull 2* of timing. Anything under 1* i'd brush off as chatter, between 1*-2* is something to keep an eye on to see if it repeats, over 2* needs to be addressed. Your first step however should be a compression test to determine the health of your motor.
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
bshotts422 (04-11-2014), Easter Bunny (04-11-2014), El_Diablo (04-11-2014)
 Old 04-11-2014, 09:16 AM   #16
Ireland's Avatar
LTFTs are at 15, I'd also be doing a MAF
trancehead (04-11-2014), Voltwings (04-11-2014)
 Old 04-11-2014, 09:27 AM   #17
Dimenus's Avatar
Groans: 33
That has nothing to do with his MAF cal. It's because of the E content.
The Following 2 Users Say Thank You to Dimenus For This Useful Post:
Ireland (04-11-2014), Voltwings (04-11-2014)
 Old 04-11-2014, 09:41 AM   #18
The car is running lean because the injector scalar is not set correctly for the E85 blend. However this is not causing the white smoke and while not ideal it is not dangerous to run until the tank is empty. So run the tank out, put in 93 pump fuel and then decide if you want a map done for E85. You don't need to rush into getting a base map for the fuel you are running ASAP. Doing things in a rush usually has poor results.
Also if you are running JUST an OTS map from us they are made for the JBR intake, not the K&N intake and that will skew your AFRs as well to the lean side since the K&N is a bigger intake. If you want to run an S-OTS PLUS map, this is going to be setup correctly for your intake.
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune [Stratified Mazda S-OTS+ Tune] - $25.00CAD : Stratified Automotive Controls
Last edited by Lex; 04-11-2014 at 09:41 AM. Reason: MSF Database - Automerged Doublepost
kby (04-11-2014), trancehead (04-11-2014), Voltwings (04-11-2014)
 Old 04-11-2014, 09:41 AM   #19
bshotts422's Avatar
if i just take it easy over the weekend should i be ok? im working doubles everyday. having to do this at work now. car has about 14,000 miles. this is really freaking me out! didn't think 3 gallons would hurt. what gauges should i set my ap on to keep an eye on? current is hfhp, boost, rpm, knock, and mass air
 Old 04-11-2014, 09:44 AM   #20
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
Listen to Lex...he is a god!
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
 Old 04-11-2014, 09:45 AM   #21
bshotts422's Avatar
ill get the ots map when i get home tonight. and try to do the custom tune in a few weeks after a finishing installing my last upgrades.
 Old 04-11-2014, 09:50 AM   #22
Sergeant_M's Avatar
Posts: 504   (View Stats)
Sergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the world
Is the smoke coming from the exhaust or the engine bay? What kind of oil are you running?
Catted or Catless DP?
Sergeant_M is offline   Reply With Quote
 Old 04-11-2014, 09:55 AM   #23
bshotts422's Avatar
coming from exhaust, engine bay nothing, downpipe in catted, oil is catrol 5w20 i think. The exhaust has only been on about 6 weeks.
 Old 04-11-2014, 09:57 AM   #24
Dimenus's Avatar
Groans: 33
5w20?
Wrong oil sir.
The Following User Says Thank You to Dimenus For This Useful Post:
Gr8Speed (04-11-2014)
 Old 04-11-2014, 09:59 AM   #25
Definitely run a 5W30 in there.
Pennzoil Platinum 5W30 is a good oil that is fairly affordable for these cars.
 Old 04-11-2014, 10:00 AM   #26
bshotts422's Avatar
ok i cant remember the number but its what mazda dealership put in
 Old 04-11-2014, 10:07 AM   #27
Sergeant_M's Avatar
How does your coolant look? If your coolant looks fine, then there is a decent chance that the thinner oil is leaking through turbo seals.
 Old 04-11-2014, 10:13 AM   #28
bshotts422's Avatar
ok i just went to check is is 5w30
 Old 04-11-2014, 10:52 AM   #29
Ireland's Avatar
For sure, but I wouldn't think that much.
 Old 04-11-2014, 10:57 AM   #30
Sergeant_M's Avatar
It's possible that without the injector scalar and specific gravity calibrated for the e85 that it could skew his LTFTS by quite a bit.
The Following User Says Thank You to Sergeant_M For This Useful Post:
 Old 04-11-2014, 11:04 AM   #31
speed_freak91's Avatar
Posts: 1,189   (View Stats)
speed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the world
Groans: 34
If your not doing oil changes yourself, ALWAYS check what they put in. When I bought my car, they changed the oil and put 5w20 in. I argued with them that it wasnt correct and actually had to pull the owners manual out and show them. They thought it would be fine with 5w20 just like the mazda 3.
speed_freak91 is offline   Reply With Quote
 Old 04-11-2014, 11:56 AM   #32
bshotts422's Avatar
ok i just went on lunch break and still smoking pretty bad at idle afr is idling a 14.5. i still have a full tank. is it serious enough to go have a tank emptied?
 Old 04-11-2014, 12:04 PM   #33
The smoke is NOT from the fuel you are using. The smoke is there from a different source. You have to identify where it's coming from. Is it oil, coolant, or just water evaporation?
If you have very thin oil in the car it could be the turbo seals.
mxlplx71 (04-11-2014), Sergeant_M (04-11-2014)
 Old 04-11-2014, 12:05 PM   #34
Sergeant_M's Avatar
Like Lex said, e85 isn't going to cause what you are describing. Can you take a video of the smoke? The color and smell of the smoke will give you a good idea of what is getting burned up.
 Old 04-11-2014, 12:10 PM   #35
NCspecV81's Avatar
Posts: 2,867   (View Stats)
NCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the world
Groaned at 32 Times in 17 Posts
This. Essentially;
E85 has less specific gravity meaning you need more of it to equal the same energy output as 91/93.
NCspecV81 is offline   Reply With Quote
The Following User Says Thank You to NCspecV81 For This Useful Post:
 Old 04-11-2014, 12:10 PM   #36
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
I LOL'd
The Following User Says Thank You to SofaKingAwesome For This Useful Post:
 Old 04-11-2014, 12:22 PM   #37
bshotts422's Avatar
man i feel so stupid for doing this. last thing i need is to fuck up my car. ill take a video when i get off, it might be late tonight before i can post it. the smoke doesn't really have an usually smell. it was drifting about to my passenger door then gone.
 Old 04-11-2014, 12:23 PM   #38
danlaroe's Avatar
You didn't get out and smell it?
 Old 04-11-2014, 12:27 PM   #39
bshotts422's Avatar
Yea smells like exhaust no burnt oil or anthing
BNR S3 V2, Cork Sport TMIC, Cobb Down pipe, Speed Daddy Cat Back, Auto Tech fuel internals, Cobb AP V3, Cobb TIH, K&N SRI, Cobb RMM, Cobb 3 port, Bosch 3 bar, Cork Sport BPV, Cork Sport hood struts, MD SSP, NGX one step colder plugs, Nitto Invo 235/40zr18, and Guarded by an Angel.
Stratified tune with 3/9 E85 mix.
Waiting to install MD OCC
Up next: Cork Sport 3" intake and WMI
 Old 04-11-2014, 12:35 PM   #40
Sergeant_M's Avatar
Did you look for a source? It could be a bad DP install if you are getting smoke underneath the car and it's not going out of the back...
white smoke Dslatch4 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 11-12-2013 10:06 AM
White smoke aldekei 2010 MS3 - Troubleshoot/Diagnostics 7 07-22-2013 12:26 PM
White Smoke Soriku1489 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 07-08-2010 05:25 PM
White smoke? PLEASE HELP Fallenvoices MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 01-06-2010 03:39 PM
finally got the white smoke bombdotcom MazdaSpeed 3/6 - Turbo Induction 3 01-29-2009 04:53 PM
Page generated in 0.56473 seconds with 34 queries
