Mazdaspeed Forums Sponsors
> JAMES BARONE RACING
Notices
JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com
Like Tree8Likes
 Old 07-21-2012, 12:59 AM   #121
f-castrillo's Avatar
Posts: 1,379   (View Stats)
Originally Posted by jbarone View Post
Absolutely! You definatley don't want a piece of that crud breakimg loose and finding its way in to the motor. I would get rid of the tube all together or clean it out and put the block off plate on.
OCC is also pretty important on the motors.
Thanks,
Jamie
Ordered
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // CNT Catted DP // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
IN PROGRESS/FUTURE: Not sure
f-castrillo is online now   Reply With Quote
 Old 07-21-2012, 07:09 AM   #122
jbarone's Avatar
Posts: 5,405   (View Stats)
jbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the worldjbarone is the leader of the world
Thanks!!
jbarone is offline   Reply With Quote
 Old 11-18-2012, 11:12 AM   #123
KevMS6's Avatar
Posts: 278   (View Stats)
KevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the world
I installed this but only fitted the plate and did not bother removing the tube and fitting plug... What / if any benefit is there from completely removing tube and fitting plug?
I've tried searching but can't find the answer...
Cpe tmic&sri, 3" HTP tip, 3" downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Sure diff mount, Cpe diff brace, NGK iridium IX plugs, Corksport Mods, JBR catch can, EGR delete... 301whp 341lb/ft
Tuned with by
KevMS6 is online now   Reply With Quote
 Old 11-18-2012, 11:46 AM   #124
OG Pu
wolly6973's Avatar
Posts: 2,327   (View Stats)
Groans: 385
If the other end of the tube is open, your egr valve will be exhausting into your engine bay.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
wolly6973 is online now   Reply With Quote
 Old 11-18-2012, 12:00 PM   #125
KevMS6's Avatar
It's not open, it's untouched... All I have done is fit the plate between block and tube.
What's the benefit of removing tube and fitting plug?
Tuned with by
 Old 11-18-2012, 12:04 PM   #126
I <3 your mom
Dash08's Avatar
Posts: 6,949   (View Stats)
Groans: 293
Groaned at 128 Times in 88 Posts
He installed the plate over the valve opening at the block, but left the pipe attached to the intake manifold without plugging the hole.
Basically, you're gonna have a massive vacuum leak.
KevMS6; You need to install the plug on the intake manifold side. Due to its design, both parts are required for this.
The plate blocks off the egr valve port at the block. The plug blocks the port on the intake manifold.
this forum serves 2 purposes
The Following 2 Users Say Thank You to Dash08 For This Useful Post:
breakfstincluded (11-18-2012), wolly6973 (11-19-2012)
 Old 11-18-2012, 12:42 PM   #127
KevMS6's Avatar
I have no leaks but will look into doing the job right, cheers
Tuned with by
 Old 11-18-2012, 01:13 PM   #128
Sig_Nasty's Avatar
Posts: 323   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
Ordered on sometime last week. Cant wait!
Speed6 Soon...
Sig_Nasty is offline   Reply With Quote
 Old 11-19-2012, 06:32 AM   #129
jbarone's Avatar
What you have done is perfectly fine. There is no need to completely remove the tube. Some remove the tube to clean up how it all looks.
Thanks,
Jamie
The Following 3 Users Say Thank You to jbarone For This Useful Post:
Dash08 (11-20-2012), KevMS6 (11-19-2012), wolly6973 (11-20-2012)
 Old 02-05-2013, 08:30 PM   #130
jdm_mica's Avatar
Posts: 253   (View Stats)
jdm_mica has disabled reputation
Installed this on Sunday but didn't use any sealant. Would it really be worth it to go back and add some??
2009 Metropolitan Grey Speed3
Cobb AP (custom 93 tune), Cobb SRI+TIP, Cobb FMIC (wrinkle black piping), Greddy Type RS, Streetunit Testpipe, Autotech FPI, Grimmspeed EBCS, JBR dogbone RMM+80 PMM, JBR EGR delete+coolant bypass+TB tig, BC coilovers, Dominant Engineering camber arms, Cobb RSB, 18x8.5 Work Emotion CR Kai, Nitto NT-555 235/40, TWM type-r shifter+bushings, JBR stage 2 OCC, Prosport Boost gauge+ventpod, Flex Innovations grounding kit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
jdm_mica is offline   Reply With Quote
 Old 02-06-2013, 04:58 AM   #131
jbarone's Avatar
Yes.
 Old 02-10-2013, 07:20 PM   #132
Jedtgill's Avatar
Posts: 25   (View Stats)
Jedtgill has a spectacular aura aboutJedtgill has a spectacular aura about
Groaned at 3 Times in 1 Post
as minimal as it is I am ordering this and your throttle body tig tomorrow I have a feeling I will be a return customer
jbarone likes this.
Jedtgill is offline   Reply With Quote
The Following User Says Thank You to Jedtgill For This Useful Post:
jbarone (02-12-2013)
 Old 02-12-2013, 10:38 AM   #133
crazyspeed6's Avatar
Posts: 66   (View Stats)
crazyspeed6 has disabled reputation
Just ordered this and the intake mani TIG, cant wait to get these installed and lower my BAT's. Thanks for the quality products!!
2006 Speed 6 - GTX3071, Cobb AP, CPE HPFP, CPE DP, HTP 3" Turbo Inlet, HTP 3" MAF Housing, CX FMIC, Greddy BOV, 3 Port EBC, JBR IM TIG, 3 Bar MAP, Corksport OCC, Stratified Tuned by Lex
crazyspeed6 is offline   Reply With Quote
The Following User Says Thank You to crazyspeed6 For This Useful Post:
 Old 02-13-2013, 09:24 AM   #134
greatdane68's Avatar
Posts: 517   (View Stats)
greatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the world
Groaned at 42 Times in 19 Posts
I already ordered an OCC from you, and would like to get this too, but I don't want to have to deal with the code. I won't be fully bolted until next year though.
Oh well, looks like I'll be ditching the Hypertech and getting an AP next year too, along with this block off plate.
2010 Mazda Speed3
Hypertech Tune, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP,
Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ebay 15mm Wheel Spacers
Soon to come: Fuel Pump internals (On order from Edgeautosports)
1995 Honda Prelude
2003 Chevy S-10
greatdane68 is offline   Reply With Quote
 Old 05-16-2013, 01:48 PM   #135
marianiman's Avatar
Posts: 330   (View Stats)
marianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the worldmarianiman is the leader of the world
just ordered a egr blockoff.
hx35w, steedspeed top mount twin scroll, ksport coilovers, CP 8.5:1 forged pistons, pauter forged rods, 4" whale penis, 5th/6th port, jbr egr delete, 3 angle valve job, cpe hpfp, cpe injector safeseals, cpe fmic, cpe catless 3" dp, cpe single exit 3" cbe with borla muffler, tial sport 44mm wastegate, cobb ap, hks twin power ignition, 3.5 bar map sensor, aem truboost with 75psi sensor, aem wideband, aem oil temp, aem oil pressure, spin on oil filter conversion, r6 rmm, sure juggernaught, sure dreadnaught, whiteline rsb, F&R drilled and slotted rotors
old setup:
Garrett GT3071r
397 awhp, 410 awtq (last dyno)
marianiman is online now   Reply With Quote
Stock Block BT build threads xcoldricex MazdaSpeed 3/6 - Big Turbo Builds 50 07-13-2010 07:37 AM
06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! jbarone JAMES BARONE RACING 4 06-18-2010 06:38 AM
06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! jbarone JAMES BARONE RACING 3 06-18-2010 06:38 AM
AEM Water/Meth Injection Kits In Stock Performance Racing Mazdaspeed3/6 General Discussion 3 04-10-2008 04:09 PM
Page generated in 0.36652 seconds with 30 queries
