-   JAMES BARONE RACING (http://www.mazdaspeedforums.org/forum/f493/)
-   -   New Product RE-RELEASE! JBR TRU - 3.0 and 3.5” Wide Path Intake Systems!! (http://www.mazdaspeedforums.org/forum/f493/new-product-re-release-jbr-tru-3-a-176267/)
JBR 08-27-2014 05:15 PM
Details:
The New JBR TRU-3.0 & 3.5” Wide Path Full Intake Systems are the only True 3” intake systems that extend from the MAF housing all the way to the transition at the turbo. Currently, all one piece metal intakes that are available from our competitors are 2.87” or 3.37"and all the other aluminum intakes that include a separate billet MAF housing start out at 3” but then quickly neck down to 2.87”. Our one piece design eliminates the need for unnecessary couplers and the joining of multiple sections that increase turbulence and friction which ultimately leads to reduced airflow. The thick, 5-ply, wire reinforced high temperature silicone construction is far superior at insulating the intake air from extreme engine temperatures. This translates in to lower boost air temperatures and more horsepower that no other aluminum intake can accomplish.
http://www.jamesbaroneracing.com/sho...dePath30OE.JPG
Every TRU-3.0 & 3.5" MAF housing has been machined from 6061-T6 to tolerances of +/-.001 and include a factory style air straightener for the most accurate signal to the MAF sensor. The air straightener is integrated in to the wall of the housing eliminating any reduction in ID like those that use honeycomb straighteners. There’s also no way for the straighener to come loose and be sucked in to the turbo like those that use pressed in blades. Our MAF housings are the lightest in the industry weighing in at only 9.1-9.8oz. The lighter housing significantly reduces heat soak, sheds heat quicker which lowers intake temperatures creating more power. Each MAF housing is beautifully anodized for a smooth, long lasting finish resistant to corrosion, even when subjected to the harshest environmental conditions.
http://www.jamesbaroneracing.com/sho...ath30OE_04.JPG
http://www.jamesbaroneracing.com/sho...ath30OE_05.JPG
http://www.jamesbaroneracing.com/sho...ath30OE_06.JPG
All Tru Wide Path Intakes now include a 3.25” or 3.75” Dry-Flow air filter. JBR Dry Flow air filters flow 200% more air than the factory filter while providing superior engine protection. It uses both depth loading, capable of removing extremely fine particles (down to < 0.1 micron), and structural screen wire to enhance airflow capabilities. This design results in a performance air filter capable of increasing horsepower and torque! The three-dimensional synthetic filtering medium is washable and requires no oiling for years of trouble free service.
http://www.jamesbaroneracing.com/sho...ath30OE_08.JPG
The Wide Path Full Intake system is designed to be run in recirc mode but, includes a plug for easy conversion to non-recir mode.
Includes:
  • Tru-3.0 or 3.5 Silicone Intake System and Billet Aluminum (3.0” ID or 3.5”) MAF Housing
  • Stainless T-Bolt Clamps
  • Plug to run in non-recirc mode
  • 3.25 or 3.75 Dry-Flow Filter (Washable uses No Oil)
  • Installation instructions are available in our support section
  • Shipping is free in the US & our Hassle Free Lifetime Warranty is included
http://www.jamesbaroneracing.com/sho...ath30OE_01.JPG
http://www.jamesbaroneracing.com/sho...ath30OE_02.JPG
http://www.jamesbaroneracing.com/sho...ath30OE_03.JPG
[R]usty 08-27-2014 05:20 PM
Perfect timing, I was looking into upgrading to a 3" intake today. I'll be picking up one of these soon! Good stuff Jamie!
xliquidx 08-27-2014 10:31 PM
Out of interest, is the old wide path maf housing made of the same material?
Josegarcia020 08-27-2014 10:54 PM
You guys never cease to amaze!!
KCi 08-28-2014 02:06 AM
Still no love for GT turbo 3" inlet. Please make one!
yourname2221 08-28-2014 03:24 AM
I believe this is what I was sent just recently since I had waited for a redesign. Looks awesome, is there any improvement in fitment around the battery/ecu?
JBR 08-28-2014 06:18 AM
3" requires the outer ecu cover to be removed. 3.5" needs a battery box.
JBR 08-28-2014 06:28 AM
No. Like other big intakes currently available it was made out of either 2.87" ID or 3.37" ID aluminum tube. They are now machined out of billet aluminum and have a an actual 3" or 3.5" ID from the inlet of the MAF and it continues all the way to the transition at the turbo.
JBR 08-28-2014 10:40 AM
Originally Posted by Lex (Post 2688898)
Love the new housings Jamie. Very nicely done and the MAF cals will be very spot on due to the machining consistency. I've been working with Mike on getting those MAF calibrations completed and I like the consistency we are seeing.
That's great to hear Alex. Worked for 7 more months to get these perfect. Thanks for working so closely with us on them.
Jamie
[R]usty 08-28-2014 11:28 AM
I'm excited to buy this. @Lex; I'll be purchasing a top up map once I get this and an EBCS installed.
[R]usty 09-02-2014 04:54 PM
Ordered! Can't wait to install!
igve2shtz 09-02-2014 08:17 PM
Son of a b&#^@. I just ordered a WP 3" from RPM yesterday. Never even saw this was offered.
JBR 09-03-2014 06:13 AM
The MAF calibration for the New JBR TRU 3" intake can now be found here.
@igve2shtz; You WILL be receiving this new TRU intake. RPM has not updated their site yet.
-Jamie
igve2shtz 09-03-2014 06:40 AM
-Jamie
This is fantastic. You guys [JBR] are amazing!
thepatient77 09-03-2014 09:11 AM
GJ @jbarone; It was worth the wait to get the new revision!!! Thanks!
MOCO MS3 09-03-2014 09:56 AM
-Jamie
I was going to ask you if you got this done. You were running the new intake @ Mid-Ohio on Monday, right? I forgot about that until now!
Jamie can truly say that this product, along with everything else on his car was track tested, as he did a great job @ Mid-Ohio on Monday. Even got to work with Mazda Factory Driver and SpeedSource P2 Driver Tom Long..........Spec MIata is on the horizon!
King Scumbag 09-04-2014 07:22 AM
I like that you grooved the MAF housing on the ends. Was having a battle with keeping the filter on the older MAF housing for a while.
Dimenus 09-04-2014 08:11 AM
@jbarone;
What size is the inlet on the new Tru 3.5 WP?
Would love to get this intake for my upcoming BNR :D
JBR 09-04-2014 08:20 AM
Originally Posted by Dimenus (Post 2694462)
@jbarone;
It fits the new BNR, @Mike@Stratified; has confirmed that it fits. It's tight but it does fit.
King Scumbag 09-04-2014 08:22 AM
For what it's worth I've instqlled the previous 3.5 silicone WP on the new BNR as well with minimal problems.
Cevaes_64 09-04-2014 08:45 AM
I have always had JBR intakes, TOP NOTCH PARTS, when i went BNR i went HTP... and have had a leak since then where the intake meets the turbo IDK if i received the wrong coupler but it fits... i love the one piece intakes, i ordered a new and stronger coupler from ebay if that doesnt solve it, i will be selling my HTP and getting this.
Atomic41 09-06-2014 08:35 AM
Must I change my CPE CAI to this ... or the gain will be minimal ...
CAI vs Shortram ... CAI doesn't have the advantage over a shortram system ???
@jbarone;
GARRETHEXTREME 09-06-2014 12:59 PM
No it doesn't have any advantage. Go with any SRI, it's better hands down.
TAPPPPPin
08.5MS3 09-06-2014 02:45 PM
Originally Posted by mituc (Post 2696469)
So the difference between the Tru-3" WP and the previous 3" WP is only the MAF housing or are there differences in the silicone tubing as well? Basically I want to know if I can pair a Tru 3" WP with a GTX30 turbo.
I ordered a 3.0" IAS GT WP after I came across this thread a few days ago, but I now realize I just made a mistake.
The silicon is different as well.
mituc 09-06-2014 02:49 PM
Yeah, asked a 3rd party to place the order for me, so I contacted them to place the order directly on the JBR site when they will get to that, so it's fixed.
And yes, according to the JBR site these intakes can be paired with GT turbos. Looks like I will finally move to a 3" intake, and I'll try to hack the CS air box to make all work together :)
08.5MS3 09-06-2014 03:48 PM
Why not move to a 3.5"?
sidekick 09-07-2014 01:43 AM
Is the new MAF housing compatible with the previous silicone 3" intakes? And is there any reason to upgrade? I take it there is not any huge difference, but this one sure looks nice.
mituc 09-07-2014 01:53 AM
1. Requires a battery box for a smaller battery. The long and relatively harsh winters here and the relatively short trips would kill a <50Ah battery in no time;
2. The ECU needs to be relocated/shifted. This is a 100% failure at the visual inspections done during the smog tests
This is also the reason why I have a CAI box (among others), and I will try to hack the hell out of it and make it fit somehow, as is now or using a different filter (shape/dimension) for the intake. They don't care what I have in that intake box: it may be a panel filter, a cone filter, a squirrel.
Of course I can find "understanding" people for a "small attention", if you understand what I mean, but there are also crews doing random inspections on the road and those can't be convinced. So I don't want to risk having my car towed to some scrap yard 300 miles away from home in the middle of a vacation just because I wanted to cruise around at legal speeds with a whale penis intake.
If it wasn't all this I would have gotten a 3+" intake a long time ago.
Yes, there is a pretty significant difference if you look at the MAF cals. The previous WP intakes are 2.87" ID and the new ones are true 3". Also, speaking of the ones advertised as 3" intakes, the Tru3" and the 3"WP, the newer one maxes out at almost 500g/s while the 3" WP is at 430g/s. That's almost 15%.
However, I'm not sure how much of a difference this would make in real life. Once you move from a stockish intake to a 3", true 3" or 2.85-2.87 the approximately 0.2" difference in diameter is huge and makes the differential pressure drop quite a bit, helping the turbo to make the same boost spooling slower this having a significant effect on the BATs.
JBR 09-07-2014 11:11 AM
No, the new 3" will not fit the precious WP silicone.
And yes, we're seeing a noticeable difference in performance and with the tuning too.
@mituc; well put.
-Jamie
mituc 09-08-2014 02:40 AM
I bit the bullet and ordered. I can't wait to see the differences as well as what I need to fabricate to pair this with the CS air box. I have a feeling that everything is going to be great on the intake side (less the airbox hacking which may need a new top and has nothing to do with the quality of the actual parts).
Sinister_Speed3 09-09-2014 12:04 AM
@mituc; well put.
-Jamie
Will the 3" fit the BNR S3v2 or just the 3.5" @jbarone;?
bonus season is near
Thanks
xliquidx 09-09-2014 12:07 AM
I can't imagine true 3.5" versus the old 3.37 or whatever it was would make a lot of difference for smaller turbos like the bnr as it will run out of puff. Maybe high fueling e85 guys will benefit but is there really that much more flow available from the bnr?
igve2shtz 09-09-2014 08:23 AM
Thanks
Post #20 above from jbarone states that the Tru intakes will fit the BNR.
As he says, "It fits the new BNR, @Mike@Stratified; has confirmed that it fits. It's tight but it does fit"
Either the 3" or the 3.5" will fit, but you must order the OEM Turbo Inlet option (~2.25"). The BNR turbo inlet is about 2.5" so it just has to be stretched. The 3" or 3.5" option only refers to the size of the MAF housing.
Code Monkey 09-09-2014 08:54 AM
Can't see it on the webpage but I assume that the new intakes (just like the old ones) come with a "mounting clamp" that we are supposed to secure to the stock mounting location on the side of the engine? This will not work on the MS6 with a BNR as the BNR is a bit wider than the k04 and pushes the intake out toward the driver side -- as pictured here, I used the mounting clamp on the filter and zip tied the intake to the bottom of the fuse box. This works but I cannot run a bigger filter, I used to run an AEM 7" dryflow, now it is no go. :(
JBR 09-11-2014 09:38 AM
The MAF calibration of the TRU 3.5" intake has been added HERE.
Thanks for all the orders for these new intakes as well. They have flown off the shelves and we're back to making more. Only a few left.
-Jamie
Atomic41 09-16-2014 06:48 AM
My mechanic guy said i waste my money to change my cpe cai to the full 3" intake because my stock turbo can't take more air that he do right now and my cpe cai is already giving way to much ... for the K04
What you think about this ???
08.5MS3 09-16-2014 07:06 AM
http://stratifiedauto.com/blog/a-tec...turbocharging/
Atomic41 09-16-2014 08:49 AM
So let's go 3.5" with a small battery box ... or it's overkill for my little K04 ?
JBR 09-16-2014 08:52 AM
A lot of guys go with the 3.5 on the k04. We sell a lot of them for the stock turbo, not over kill.
[R]usty 09-16-2014 03:22 PM
My new intake was just delivered to my front door. Can't wait to get home!
Atomic41 09-16-2014 05:00 PM
Somebody try a 51R battery in Canada ...
I just want to know if the 51R battery can tough our cold winter -30 to sometimes -40.
Because maybe I wanna try 51R battery tray with a 3.5'' True intake to have the best intake possible to compare to my CPE CAI right now and see how my speed3 will answer to that modification.
Thanks for your help
P.S. Do you have recommendation for a model of 51R that better than other ?
Cevaes_64 09-16-2014 05:16 PM
Relocate the battery to the trunk
Sent from my SM-N900P using Tapatalk 4
speedaholic 09-16-2014 05:47 PM
A 51R has only 500cca average so I guess the only way to make sure you get the cranking power for when the oil turns to molasses is to either relocate the oem size battery (or bigger) to the trunk, or get a block heater to help out.
You are local to me so hit me up if you need a quality replacement. The company I work is a Crown Battery Industrial distributor and I'm the parts manager. [emoji6]
JBR 09-16-2014 07:51 PM
We ship a lot of battery boxes to Canada. The 51R batteries we use in our shop cars are no name 600 CCA batteries and we've never had a problem. Paid about $110 US a piece for them. I would assume a block heater is essential in climates that dip that low.
Atomic41 09-16-2014 08:02 PM
So i already have block heater. So if i pick a maybe 500 at least CCA 51r battery i will ok for sure to start the car without Any problem in a cold climate ?
Envoyé de mon HTC One X en utilisant Tapatalk
JBR 09-16-2014 10:17 PM
From the reading I've done, a block heater is what's being used.
xliquidx 09-16-2014 10:21 PM
Yikes -40 I need to invest in a second pair of testicles
Code Monkey 09-16-2014 10:28 PM
You mean first..... :D
Atomic41 09-17-2014 06:11 AM
If I go 3.5" TRU full ... can I just change the place of the ECU and past in on the fuse box ???
JBR 09-17-2014 08:01 AM
Yes! This is often done.
Starting at step 11 of the instructions for our old aluminum intakes will show you how to do just that!
Thanks,
Jamie
Atomic41 09-18-2014 07:37 AM
Is it possible to have some impression from user that drive with JBR Tru intake 3 or 3.5" versus their older setup SRI or CAI.
How you like it, driving impression, power, sound, etc
mituc 09-18-2014 12:30 PM
Because the intake diameter is larger the intake should be quieter, or at least have a more diminished sound of that suction sound. This is good or not so good depending on what kind of person you are.
Personally I am pleased with the sound of my current intake setup, but on Monday... BUT ON MOONNDAAAYYY..... we will fit the holy mighty whale penis onto the car and I'll tell you more.
http://s3.postimg.org/wjdup7nwf/IMAG1803.jpghttp://s3.postimg.org/y14cxvyyn/IMAG1804.jpghttp://s3.postimg.org/cfzaaa27z/IMAG1805.jpg
http://s3.postimg.org/63k50fz5r/IMAG1806.jpghttp://s3.postimg.org/rna7xinr3/IMAG1807.jpg
First impressions after putting everything together on the floor:
- the shape of the whole intake shows a lot of attention to detail and care for its shape AND for preserving the 3" diameter;
- a very pleasant surprise was that in the package there's a clamp with a mounting ear that you can put there to use the factory mounting tab that's near the fuel pump;
- I wish the hose for the EBCS bleeding was a bit longer. Most of the people who purchase the 4" turbo coupler version will have an aftermarket EBCS which will not be in the factory location;
- the air filter has about the same base diameter as the K&N filter I'm using now with the CObb intake and CS CAI Box. So there's a good chance that I will be able to keep the CAI Box on the car since the MAF housing allows for a decent amount of adjusting;
- basically in the package you will find the maximum number of clamps that you may need;
- the silicone is very stiff and should not have too much play while it will still be able to vibrate a bit to absorb any vibrations from the engine bay/turbo/whatever. But it's stiff enough that you can beat your kids with it and still fit it on the car no problem after that.
- A few years ago when I opened the box with the Autotech internals I first thought the Edge guys played a joke on me and sent me some collection die cast car. Then I found the internals in and they were looking like some jewels. Well, the MAF housing was wrapped in a piece of hard paper but when my fingers finally came in contact with it I had the same impression. This MAF housing looks simply beautiful.
Atomic41 09-18-2014 01:18 PM
Thanks
keep me update please !
igve2shtz 09-18-2014 01:42 PM
I also haven't installed my Tru-3.0" OEM Turbo intake yet. But playing with it in the garage, I agree with mituc with the quality of the product. The MAF is gorgeous with a nice knurl to the edges to have something for the silicone and clamp to grab onto. And speaking of clamps, JBR provided 3 T-bolt clamps for the connections on the turbo and the MAF. After having 3 different intakes on my car and 2 different TIP's, this is the first one that has sent T-bolt clamps. Another nice touch.
mituc 09-22-2014 10:05 AM
Here's the JBR Tru 3" intake fitted with all OEM parts: OEM battery tray, OEM ECU covers, ...and the CorkSport Air Box for the Cobb SRI!
I threw the battery tray in place with the ECU still bolted to it. The tray is a bit kinked but I could screw the bolts nuts in. WIN!
http://s18.postimg.org/6grwrcf79/IMAG1814.jpghttp://s18.postimg.org/40q3dhx4l/IMAG1815.jpg
I thought I was lucky, so I king of forced my luck with the tools I had. the CS air box seemed to be almost perfectly aligned with the MAF location.
We added a rubber grommet (a strut mount from a Smart ForFour) which happened to have the right inner diameter. The idea was to prevent the MAF housing from vibrating against the air box. If it's also sealing it, even better. Epic WIN!
http://s18.postimg.org/4ssrcp1bp/IMAG1816.jpghttp://s18.postimg.org/3k9h4syr9/IMAG1817.jpg
After some time of screwing around with the air box and the air filter we test fit it. Mega WIN!! I was feeling like drinking a beer, even though I drink like 2-3 beers a year.
http://s18.postimg.org/teeogu9dh/IMAG1818.jpghttp://s18.postimg.org/il768bs39/IMAG1819.jpghttp://s18.postimg.org/m8mxee0ad/IMAG1820.jpghttp://s18.postimg.org/jq18dpek5/IMAG1821.jpg
http://s18.postimg.org/vughuorg5/IMAG1822.jpghttp://s18.postimg.org/dlebe4bud/IMAG1823.jpghttp://s18.postimg.org/s21ksp1bp/IMAG1824.jpghttp://s18.postimg.org/5rdpsq41h/IMAG1825.jpg
Time to throw the battery in and put everything together! Galactic WIN!
http://s18.postimg.org/5h679dpf9/IMAG1826.jpghttp://s18.postimg.org/478dubvn9/IMAG1827.jpghttp://s18.postimg.org/6r8m268l1/IMAG1828.jpghttp://s18.postimg.org/n8htnu4tx/IMAG1834.jpg
Job done with all parts. ...out of superlatives... no, wait: Romanian WIN!
http://s18.postimg.org/44oi7hrzp/IMAG1835.jpghttp://s18.postimg.org/588mjgcmt/IMAG1836.jpghttp://s18.postimg.org/f83izcnw5/IMAG1837.jpghttp://s18.postimg.org/y33v3idbp/IMAG1838.jpghttp://s18.postimg.org/g1kq5pjat/IMAG1839.jpg
The intake seems to be a bit kinked after the PCV feed but not by much. The air box is pushing the MAF housing against the softer part of that silicone tube, but when I will work in that area again I know what I have do to.
Also, the air filter has a larger diameter in the smaller cone area so the top of the air box is also pushing that a bit down. But that's rubber and will kink just fine.
The Stratified MAF cal is -3.1% - +1.6% in the range I logged, just like my old MAF cal for the Cobb SRI. i didn't push the car today for a WOT log because the laptop battery was almost done. Thank you @Lex and @Mike@Stratified for your work on this.
RACER_X 11-29-2014 06:36 AM
will my car be ok w/ the 3.0 and internals w/ a cobb OTS stage 1 tune, while i'm waiting on a custom tune.
JBR 11-29-2014 06:42 AM
No, it will run lean. Use the COBB ots, but, apply the MAF cal for the 3.0 which can be found in stratified's section.
Mazdaspeed3KHP 11-29-2014 09:57 PM
Dammit I thought this was the aluminum intake release. Still haven't decided if I'm going to go with the 3.0 or 3.5. It will be mated with a gt3071r. John at Tork convinced me to go iwg even tho I was originally going to get the ewg kit. Power wise im only shooting for 350-360 on pump gas.
Do you think the 3.5 will cause more boost creep issues? I don't plan to port the wg. I'm leaning towards the 3.5 just for future purposes if I want to build the motor.
mituc 11-30-2014 01:15 AM
I made 350whp on a Cobb SRI with the GTX3071. So IMHO the Tru3" should be good for at least that considering that your gen2 will be able to work with a bit more timing advance on the same gas quality. I think the boost creep issues are generated more by the exhaust side, not intake.
However, keep in mind that 340-350whp on pump gas is close to the limit of what the stock internals can take in therms of heat. I'm telling you that because I managed to hurt my motor this spring (also raised the rev limit to 7k which I think may be the main culprit) and now with the lower compression it won't go past 335-340whp.
So I recommend using a WMI kit and aim for even more (360-370whp without raising the maximum torque/load values in the mid range, but keeping the torque at similar values as much as possible in the rev range, like past 5.5k where it really matters for making power).
Mazdaspeed3KHP 11-30-2014 12:15 PM
Thanks for sharing that information. I was never really into meth injection until I started reading more. I might lower my current goal to 340 max until I plan to get a WMI kit. I think your right going with the 3.0 instead.
This will also save me from having to buy a new battery box. I can spend the extra money on a meth kit.
RACER_X 12-15-2014 04:50 AM
ok, got on my 3.0 WP this weekend.
everything went well EXCEPT i couldn;t figure out where to place the mounting bracket (step 20 in your install guide) on the TIP part of the intake.
otherwise, nice piece of kit, makes the car sound like a jet airplane now when the turbo spools up
and very nice HP improvement w/ my @stratified tune
http://i59.tinypic.com/javrqs.jpg
JBR 12-15-2014 10:54 AM
I'm glad you're seeing nice HP gains from the intake!!
Here's a better picture of where the mounting clamp goes.
http://tapatalk.imageshack.com/v2/14...eecd23183a.jpg
RACER_X 12-15-2014 11:23 AM
Oh, I was thinking it bolted to some nut on the firewall, now I have a idea where it goes.
Thanks
JBR 12-16-2014 08:28 AM
Thanks
Yeah, it secures the intake to the same spot as the OEM TIP.
-Jamie
RACER_X 12-20-2014 10:01 AM
So the next dummy like me can see and final product w the condom
Page generated in 0.27455 seconds with 11 queries
