New Product Release - JBR Tru-Torsion Billet Sway Bar Brackets and Bushings Details: All aftermarket large diameter sway bars that include yellow zinc plated brakets occasionally suffer from broken sway bar brackets, even our own! Well, we now have the solution for owners of all 1.25” sway bars regardless of manufacturer. These brackets are guaranteed to be trouble free for a lifetime. Constructed out of 6061-T6 aluminum with a tough anodized finish. Equipped with grease fittings to allow for easy maintenance of the included 80a durometer bushings. The JBR Tru-Torsion brackets also eliminate the clunking often heard with worn bushings and brackets. Theses are the last set of sway bar brackets and bushings you will ever need. The JBR Tru-Torsion Sway Bar Bracket Kit Includes:
Available online now! http://www.jamesbaroneracing.com/sho...onBrackets.JPG http://www.jamesbaroneracing.com/sho...rackets_01.JPG http://www.jamesbaroneracing.com/sho...rackets_02.JPG http://www.jamesbaroneracing.com/sho...rackets_03.JPG http://www.jamesbaroneracing.com/sho...rackets_04.JPG http://www.jamesbaroneracing.com/sho...rackets_05.JPG http://www.jamesbaroneracing.com/sho...rackets_06.JPG |
Badass Jamie! |
Damn, those are beautiful! |
Nice |
Will we have to sourse out own bolts? Your photos don't show the sway bar collars installed. I assume we still use them or are these wider and take up the space on you RSB? |
wow those look beeeffyy |
Those are nice! May have to look at these at some point to go ahead and beef up the ones that you send with your RSB. |
I'd buy these just to stare at them! Fancy set of paperweights, Jamie. |
They are also now an option when buying our sway bars. Save $10.00 on them too. |
Ordered. Just got home and my RSB is clunking. |
They look awesome! Definitely getting these when I get me a sway bar from you. |
Order placed, I never did trust those little straps. Do you provide bolts or do I need to source my own? If so, what size please? Nevermind - bolts *are* included per Jamie's Facebook post. |
Yes OP updated to reflect included mounting hardware. You still use collars if applicable with these. |
this is completely badass! |
I just came |
Yeah yeah, now lets see the dyno charts. |
Will get these in due time. Very nice product |
You all asked for these so we got them done! |
Do want, now to come up with the extra cash to pick them up. Any option for getting the bushing in an 88a to match the rest of my mounts from you? |
Those brackets look amazing! |
I could kiss you... no, you're getting tongue the next time I see you. |
They're so pretty, I can think of another use for the 1.250" Dia. Now all I need to do is figure out how to get KY in a grease gun. I haven't broke mine, I'm sure as hell going to try. |
I just went from 6 to midnight when the pictures loaded... I assume they'll work on the front end, or rear only? Just tapa it in. |
Those are NICE! I was just reading a thread about broken mounts the other day. O.T. Looking forward to my shift weight. Unbelievably quick response on my order. Thank you. |
Does this work on the ms6? |
Is this something you would recommend as a preventative measure for people who purchased your rear sway bar? Or is this the sort of thing you wait to replace? |
1.25" for those of us who may not be running a JBR (because I'm not - purchased the car with another already installed) is 31.75mm Quote:
If you like aggressive cornering, I would add these to your short list. |
Are these only necessary for people who refuse to do proper maintenance on the existing Energy Suspension version? Within 3.5 years of having an aftermarket sway bar, I've failed 1 stock endlink, 1 Moog endlink, and 1 CS sway bar; all on the same set of bushings and clamps. With a lot of autocrossing and aggressive driving. These seem like overkill. |
Ask @Ray Danger 2020; and @ImGryssLOL; what they were doing to break theirs. or @lilred; @shifter48; @Nliiitend1; @galens47; etc etc. Not an isolated issue, and overkill looks good to me. |
Jamie, is there any way you can pm me so i can order a few things from you. I am new to the forums and do not have enough posts to pm people. Thank you in advance! |
I don't do any auto-x and I just installed the RSB last fall. I didn't realize that they were prone to failure. I'll maybe take a look under there and order these. Thanks for the answers. |
Looks like a good option over the billet Hotchkis brackets (which I recently bought to use on my solid 28 mm bar) for guys with 1.25" bars. Maybe you should consider sourcing a few different bushing sizes for those that run differently sized bars to make it easy for them to upgrade to these as well. :fing02: |
Will pick these up when I order my RSB from you! |
We have or can get most any size bushing to work with these brackets. We even have the bushings for the MS3 OEM front and rear bars. -Jamie |
These are damn sexy, I will buy these soon. However, this is not the suspension part I was hoping you'd release. @jbarone; BAD MONKEY!!! :spank: |
But a front sway bar you say? God I hate you right now. You make me want to cry and get horny all at once. |
OMG!!!!! YOU HAZ PM!!!!! |
It's ok for front say bar too ? |
1 Attachment(s) Well that was fast, I love your shipping method. These things are solid. Thanks, Jamie. |
Looks like a fancy box cutter. |
Just finished putting them on, and drove a couple miles. They seem to hold up strong. |
ordered! |
Any of you guys that put these on already, have you noticed any difference in response from your RSB? I'm wondering how much flex there was in the old mounts under travel/load. |
1 Attachment(s) Quote:
(Other than pitching the car around vigorously after install, I haven't done any formal "testing") |
My brackets have not broken, but they were beginning to bend slightly. So I went to a hardware store, matched up the size of the bolts and got some heavy stainless steel washers to support the brackets. It was kind of a pain, because you can't see how well centered it is. In the end I put all 4 bolts in without the washers, centered the bar, removed one bolt at a time, placed washer and loctite on them, and then torqued them down. Probably overkill but the original ones seemed sort of flimsy.... That and then some fresh grease made it sturdy and responsive again. |
need a sway bar for the speed6 :( |
Had these in my hands yesterday and you can't go wrong! Very excited about this product! Going to Mid-Ohio and test them along with the New RSB |
For those who got a MS3 over 7 years ago and scored the Hotchkis when they came out, these will fit! Hotchkis Sport Suspension Quote:
And now my car is yet another reason why @jbarone; is at the top of this game. I didn't pay attention to this thread and I had my bushings (from one of the older JBR bars - ordered in 2012) fail this weekend. I assumed I could avoid the upgrade and be fine, because I didn't heed the results of the R&D JBR always does. @jbarone; I am NOT bitching, nor citing a fault with your product - this failure was NOT a defect with your design - I drive like a hooligan and the roads here are atrocious. I just wanted to point out how ahead-of-the-curve you guys always are with updated products and I wanted to encourage people who are on the fence about your products versus someone else's that they shouldn't hesitate to go with you. So, everyone: there's a reason every single aftermarket part on my car comes from JBR (except AP and HPFP Internals, which they don't make...yet) TIS |
1 Attachment(s) Just an update, since I was under the car today. Bracket completely shattered, it wasn't a dropped bolt as I originally thought. Upgraded brackets were purchased and installed, car feels great again. As always, nothing wrong with the JBR components, just the sourced brackets which are notoriously weak. Attachment 157165 TIS Tapatalkative |
http://img.tapatalk.com/d/14/06/16/pehuryda.jpg http://img.tapatalk.com/d/14/06/16/naranebu.jpg http://img.tapatalk.com/d/14/06/16/apezamuj.jpg Am I part of the club?? F@#%k it Sent from driver seat, bro! |
2 Attachment(s) Had a killer clunk from the rear after the horrible winter - finally figured out it was from the RSB so decided to upgrade the bar and couldn't pass up these brackets. For the chunks of material you get that are simple and look well made - the price is right... and should functionally help (a little more of that torsion is going to pull down rather and yank on the rear of the subframe). They were on a couple weeks of "backorder" and then JBR forgot about my order. Once they saw my email asking if they had shipped - they fixed the mistake and sent them & the bar via 2day shipping right away - thanks for looking out. I am initially in the middle setting for the bar and it is a huge improvement in balance compared to stock (as expected). The bit of street testing I could do shows the most improvements after mid-corner and during exit. Entry seems to still be a bit pushy. But... this morning I heard the clunk again... I think from the left rear end link (still stock, 70,000miles)... so I am putting in my order now for JBR's MOOG end links w/ zerk fittings so this setup will last until the car is sold and then long after as long as they are kept greased. When I install these I will definately be moving the bar to the full stiff setting. :unitedstates: |
Wow. I'm a little late to the party here, mostly because I went awol from the forum for a few months. I don't want to jerk my own chain here- but I find myself wonder if this is related to the JBR release or just a coincidence: http://www.mazdaspeedforums.org/foru...ml#post2380281 |
Anyone have issues with these brackets? My bar just failed with these brackets. Maybe the brackets are stronger then the bar? Kinda bummed out :/ |
1 Attachment(s) I know :( |
1 Attachment(s) And another pic of it |
That's ugly. What did JBR say when you contacted them? Glad I live in rust free FL, thing looks pretty gnarly! |
It hasent even been on there for a full year. It's only seen snow twice. But some girl picked up and said she will show her boss and see what they will do. I will be shocked if they don't warrenty it. I have heard great things and most of my car is jbr including my front mount and crash bar so I bet they will fix it for me no problem. |
Holy rust. Did it fail as a result of an event (i.e. you nailed a pot hole, or a person) or just under normal driving? |
I am sure you know this, but if your local company modifies it at all, kiss your warranty goodbye man. |
My buddy at work (sell cars for Hyundai) changed my oil for me today while I was selling a car and then came and grabbed me to show me how "loose" my end link was then he realized that the weld failed and that the end link was fine. So thank god it did not fail mid corner or I would have been off the road! Car has never been to a track it is just my dd so I was shocked. Quote:
Good thing brock can't see this. |
We spoke with the customer, and received pictures for us to look over. It's clear that this is result of a manufacturing error. One of 3 welds that secure the arm to the bar was not performed, weakening the connection causing it to break. It's certainly covered under warranty and a new rear bar is being sent to the customer today along with a return label for the defective sway bar so we can inspect it. |
Just got a call from him direct. Fastest response time every! Bar is already in the mail too! He said it looks like a weld defect and that I was the first one that has ever broken one hahaha. Very very impressed with the level of customer service! Thanks again @jabarone; ! |
Is that the guy on Facebook jumping on jbr when he can? Glad a replacement bar is on the way. Great to know jbr stands behind their product Sent from my iPhone using sausage fingers |
If that's the case, I hope his attitude reverses. |
Three welds? How does that work? Two sides and two arms, even numbers... |
One surrounding the inside of the arm to the pipe, one surrounding the outside of the arm to the pipe, the third secures the cap. Total of 6. The weld surrounding the outside of the arm was missed. |
That's service! |
hell ya it is! and he took the time to call me back personally but not only that, he called back quick! Most manufactures would try to make an excuse and give you the run around to try and not have to replace it but he just took care of it no hassle at all. Super humble guy and AMAZING customer service. For sure happy most of my car wears JBR product. New intake and short shift assembly for sure coming from him. Good work! |
When I read the first failure post saying the brackets are involved I was so confused. I installed these on my car a few weeks ago, and the brackets are so beefy and clamp on so tight that the bar has very little movement through the bushing. Took them apart and re greased everything, damn thing is still mega tight with minimal movement! |
So much hate train bullshit, I stopped keeping track. |
| All times are GMT -7. The time now is 12:51 AM. |
