Just ordered 80 duro passenger and tranny mounts and stage 2 catch can with vta kit. Late night shopping FTW! Sent from my DROID RAZR using Tapatalk 4 |
Update on my rmm: 350miles, vibs are pretty much gone. No threadlocker but tested the bolts for tightness a few times, all good. The vibs are too little. Need moar mounts. |
~550 miles on the JBR 80 Trilogy, and am really happy with em. It's really surprising how nice it is to drive the 6 when the engine & trans stay where they're supposed to. The first 70 miles were harsh- vibes and trans whine- totally expected and knew it would be gone soon so didn't stress. Right on 70 miles the first harsh edge eased off and it was amazing- it was like hitting a light switch, the vibes just settled down. Now, at 550ish miles the trans has quieted down quite a bit- about half the gear whine compared to new, and the only time I get vibes anymore is just off idle when I rev the engine. I'm running the stock idle, bump it up a touch and even that would go away. For reference, this is on a new engine that still has the balance shaft. I can see the first several hundred miles being pretty harsh if you've done the BSD. At this point tho, I'm already not worried about doing the BSD when this engine gets it's forged bottom end next year... Yeah, love the Trilogy. It's a good thing.... |
@Funkster777; I suspect something is not correct with your install or you are very sensitive to NVH. Your description is far from the norm. Look things over and let me know if I can help. Thanks, Jamie |
I got all of @jbarone; mounts, the pmm only has one of the bolts and the nut securing it and I don't have any excessive vibes. |
Got this morning RMM, just came from shop, my mechanic returned stock one, and said it can't be mounted without cutting piece of metal that holds rear part of mount . What I'm missing here? As I read it is pretty straight forward |
There are two tabs at the mounting location on the sub-frame that need to be spread apart and then narrow end of the mount will fit in. Some guys remove them but, with our mount you don't have to. It's a tight fit but it can be done. |
Thanks guys, will go again tomorrow. |
I had no vibes at idle and they became worst with rpm. ~3000 was the worse. Everything was shaking in the car: mirrors, change, tools, people. I'm OK with what I'm running now as it is stronger than stock but not too crazy. This is not to knock JBR as his stuff is great. My car appears to react differently to things. It is what it is. |
My mount has certain parts in the low band where it vibrates but not bad at all. Kinda disapointed, looks like i need to order the other two. |
My JBR mounts are not even broken in yet, 500 miles on TMM and RMM and only 50 miles on PMM mount and I love them so far. My mirrors vibrate more from my catted DP and CP-E 3" dual exhaust than from the mounts. The engine just feels solidly mounted and shifts are butter smooth. |
It's so damn strange how big of a variance you will get in reports of NVH. I understand everyone has different tolerance but some of these stories are too far apart to think that is the only issue. How can one guy think it's chattering the fillings out of his teeth and completely un-driveable while another says vibes are barely noticeable after the break in period? |
I understand the concerns. Personal taste does have some impact. If I did them myself, then I would wonder about install error but I had three guys help that really knew what they were doing. For the record I do have the BSD but my crankshaft was balanced with the rebuild. |
Just a rmm isnt going to kill you. All 3 may. |
The ms6 owners are much more sensitive to vibration because of how smooth the car is to begin with. I think that is why the comments on NVH is so far apart. |
I'd consider a substantive retort to your implication of delicacy, alas I must delay owing to previously scheduled manicure.... |
Lots of sandy vaginas in this thread. :D |
Product Release MAZDASPEED 6 Motor Mounts in Stock!! Quote:
I would be interested to see if you though the cars who report much less dramatic results shared the same out come. |
Another local MI NATOR member is putting in 70 duro PMM so we can compare when we meet next. |
Finnaly installed today RMM on my MS6. Hope it will vibrate less after braking in. Also noticed exhaust is bit louder now. Is that OK? |
I'm installing My JBR 70 sidemounts this weekend. I have the cp-e rear mount already installed, the car dosent vibrate unless the AC turns on at iddle. Give a nice back massage when it shake. |
Does anyone know the size/thread/pitch of the bolts used to secure the JBR PMM to the frame rail? I installed the PMM last night and was tightening the rear frame bolt to the spec (70 ft lb) listed in JBR's instructions when I felt it go soft. So either the bolt is letting go or the threads in the frame rail are stripped. I figure I'll have a spare bolt and a heli-coil/time-sert kit ready to go when I remove the bolt so I don't have any down time. And, no, I did not cross-thread the bolt. Is it just me or does 70 ft lb seem a bit excessive? @jbarone |
1 Attachment(s) According to the manual bolt(s) to frame rail should be 43.4-58.5 ft-lbf |
Thanks. |
Yeah I broke that bolt and have yet to fix it haha. It did seem excessive. I pmed Jamie tp let him know and he said the spec was fine so I chalked it up to my shitty torque wrench haha |
Stock spec for the stock mount is fine. We chose 12 ft/lbs over for this application and have installed many at this spec without issue. -Jamie |
I have an 88 AWR rmm and the 80 JBR pmm. just took my first cruise since pmm install and I think the NVH increase wasn't bad all. definite increase but not uncomfortable and I love how it feels along with the added shift performance. Knowing the nvh is gonna die off later kind of has me depressed lol. I still have my balance shaft. Can't wait to order the TMM and APv3 next month DON'T CHANGE A THING JAIME! :You_Rock_Emoticon: |
+1 I've got ~1,300 on my 80 duro Trilogy now, and love it. It's my daily driver and at 76K miles it feels better now than when I purchased it with 19K miles. Yes there's a difference between being mounted or being isolated, but I like your version better, and I'm exceptionally pleased with 'em. |
Got my 70 pmm installed today... torqued to 70/lb no problem. I think I will loosen them hower. Is it just me or the engine is loud as fuck now ? vibration are very low, but the sound level is very high inside the cabin |
| All times are GMT -7. The time now is 12:50 AM. |
