> MazdaSpeed 3/6 - Big Turbo Builds
MazdaSpeed 3/6 - Big Turbo Builds MazdaSpeed 3/6 - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here.
Like Tree47Likes
 Old 08-14-2015, 07:12 AM   #201
Ziggo's Avatar
Posts: 3,843   (View Stats)
The turbo has no impact on emissions. I have an OBD2 inspection as well and have had no issues. Things like a cat less downpipe or EGR block off have more of an impact.
The OEM clutch is fine, excepting actual hard road course use. Sustained abuse on a hot day at the track results in a slipping clutch. I went to an ACT 6puck sprung probably 6 months after installing because of frustration on the race track
I get terrible MPG, about 18, but I drive 7 miles to work. I get probably 24 on longer drives. I've never cared to try to improve it, the 5/7 E85 mix doesn't help, and as always it's going to be dependent on your right foot. Some folks have reported better MPG with larger turbos than this, simply because with the delayed spool, you don't tend to squirt around as much.
No PCV or dipstick issues, but that has to do with motor health more than anything. I don't run a catch can.
Ask Me About My:
 Old 08-14-2015, 09:15 AM   #202
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
Mine should be here Monday, will probably take the old turbo out and prep it all Sunday night, should make for a nice quick install. I've taken the DP/turbo off a few times already, so everything should go smoothly. I'll probably throw up some pics just for the hell of it too.
 Old 08-14-2015, 09:49 AM   #203
Lex2007's Avatar
Posts: 554   (View Stats)
Thanks for the great info Ziggo. Much appreciated.
If you had to do it again, would you have chosen this same set up?
Why you switching from a k04 that's already making plenty of power?
Last edited by Lex2007; 08-14-2015 at 09:49 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-14-2015, 10:58 AM   #204
Ziggo's Avatar
Absolutely. Its an even better deal now than it was when I bought it. IMO its the best path to maximizing the capabilities of the stock block. Use the money you save vs an ATP kit to get a 3.5" intake and/or a meth kit if E85 isn't available.
Ask Me About My:
Code Monkey (08-14-2015), WAMBUSHHHH! (08-14-2015)
 Old 08-14-2015, 11:13 AM   #205
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
If youre getting a beaner you need teh meths!!
Good info Ziggo! Thanks for this write up too bud.
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline   Reply With Quote
 Old 08-14-2015, 11:16 AM   #206
g00s3y's Avatar
Groans: 439
I don't run it daily with the map that made 348/356. Was more of just a "push it as far as I can, and see what numbers I could hit on the dyno" map. I go daily with ~310/335.
The k04 dies off after ~5300rpm, while this BNR will pull nicely until redline. Plus I'm pretty positive I could hit my current daily numbers on just pump with the s3, and getting MPG back from having to run a corn mix. On pump with the k04 I maxed out ~290/330, so I'll be interested to see what I can get with it.
 Old 08-14-2015, 11:19 AM   #207
Lex2007's Avatar
Corksport's $1100 kit is spoken highly of on this forum. ATP has like 12 different turbo offerings. No idea what the real world differences are. So many choices is dizzying.
Regardless of the turbo, the essentials are 1. high pressure fuel pump internals to provide more fuel 2. COBB access port to be able to reprogram the computer to accept the new turbo parameters, 3. new boost controller, yes?
After that, the options for new headers, downpipe, turbo inlet pipe and larger cold air intake are all optional. Is that correct?
My problem is this is my daily driver. Cant have too much down time as I do the install and troubleshoot.
 Old 08-14-2015, 11:37 AM   #208
Lex2007's Avatar
ah good info. What did you pay for the Ko4 kit? Who sold it to you?
 Old 08-14-2015, 12:21 PM   #209
WAMBUSHHHH!'s Avatar
Posts: 1,598   (View Stats)
WAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the world
K04 comes in the car? Soooo, it was included in the price when he bought it..
Lock down what your power goals are and from there the turbo selection should start to narrow down. If you need the car up and running quickly, I would go with either the BNR, CS or GT28 series as they give relatively the same power, great turbos for the stock block and are more or less direct bolt ons. Not sure if Edge is still doing their BNR sale but they have a kit with just about everyting you would need for a BNR.
While those are bolt-ons and can be done in roughly one day, with the luck, helping hands and patience, be sure to build in an extra day or so to troubleshoot issues. If you can't have the car down for too long, building that extra day in will help ease pressure off in case something unexpected happens. When I helped with a BNR install for a fellow NATOR, his MAP sensor was bad (it was new, covered thankfully) but he couldn't read boost. So tuning couldn't take place until we got that sorted out. Obvisouly an easy fix but did take a day to get a new one. His car was drivable but we just couldn't tell if he was getting any boost or too much. Since the BNR moved the turbo over ever so lightly, his intake was rubbing and hitting his BPV on his TMIC. Things like that happen and if you need the car the next day, it may not be possible to get everything sorted out. Just food for thought.
2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017
2017 LGM Golf R - South Bend stage 3 daily clutch / DFG intake / Wagner IC / AWE downpipe / Indvidia catback / APv3 Protune
2004 Yamaha R6 - Micron Ricer Pipe / PC
2005 Honda CBR 600 F4i - R.I.P. 10/29/13
WAMBUSHHHH! is offline   Reply With Quote
 Old 08-14-2015, 12:37 PM   #210
Lex2007's Avatar
Thanks Wambush. Good info. I recognize that little issues could delay the process by a week or so. I would anticipate a week's down time. (I didnt realize he was talking about the stock turbo, clearly. Thanks for clarifying)
Its hard know how much more power Im wanting honestly. If Im gonna drop $2000 on a Accessport and turbo I expect at least another 60-75 hp. Otherwise what's the point? But I dont know what that means for driveability, torque steer, MPG when not hammering it, ability of the clutch to handle the torque, LSD and gears to handle the torque.
I also recognize that 450hp for example in a FWD is sorta worthless accept on the highway. FWD has its limitations.
 Old 08-19-2015, 12:07 PM   #211
g00s3y's Avatar
Groans: 439
Well this sucks, I must have over rotated the housing. Wastegate isn't working properly, can't build any boost on the low end, WGDC shoots up when first going WOT, then just drops to 0. Turbo is still spiking around 20-21psi at redline. Was a pain in the ass getting the WG back on after rotating the housing. No where near as easy as anyone made it out to be. And the k04 WG rotation bracket that came with the HTP under route piping didn't help either.
Not blaming any company, just for anyone else thinking of going this route, it isn't just a straight up easy swap. Modifications will have to be made.
 Old 08-19-2015, 01:01 PM   #212
JBR
JBR's Avatar
Posts: 6,608   (View Stats)
Groans: 28
You should be able to clock the S3 using the wastegate bracket that came with the turbo. We've done with our under mounted piping and it works perfectly.
JBR is offline   Reply With Quote
The Following User Says Thank You to JBR For This Useful Post:
neganox (08-19-2015)
 Old 08-19-2015, 02:08 PM   #213
ItsNox's Avatar
Man that does suck. @ms6mil; @G1sdaname; We clocked Gabes BNR for the JBR undermotor FMIC piping and didn't have any issues if I remember. Unfortunately I was balls deep in my own BNR swap and didn't see what they had to do. Can you guys chime in?
'06 Mazdaspeed 6 GT
- Miltuned
 Old 08-19-2015, 03:58 PM   #214
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
neganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the worldneganox is the leader of the world
Groans: 49
You should be able to reuse the WGA plate that comes on the BNR. There shouldn't be a need to use the k04 plate.
neganox is offline   Reply With Quote
 Old 08-19-2015, 04:20 PM   #215
g00s3y's Avatar
Groans: 439
The bracket that it comes with is what I used, but it hit the compressor housing when it was rotated, and only one bolt would line up. It was impossible to get them both in.
This has nothing to do with htp piping kit, that works perfectly fine with the turbo clocked.
I'll try to get some pictures when I fix it to show. But I tried everything short of grinding down the compressor housing to get it to work. In the end I had to enlarge the holes for the WG and bracket so it would bolt up. Now it's just a matter of getting it adjusted so I can boost properly.
 Old 08-19-2015, 07:38 PM   #216
G1sdaname's Avatar
Posts: 519   (View Stats)
G1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the worldG1sdaname is the leader of the world
Mine is clocked and under engine pipping is awesome!!!
You will need to be tuned for this but rotating the actuator rod two full turns will improve the boost lag (hopefully I didn't misunderstand the issue)
You can do it without taking out the turbo...
CP-E Catted TBE | COBB: AP, RMM, EBCS | AutoTech Internals | Wheels - Montegi R116
BNR3 | JBR: Tru 3.0 Intake, Under-engine FMIC piping, SSP | TR8 | TurboSmart BPV
MilTuned - e85
Next up: Make more money for Meth (2x)
-Gabe-
Last edited by G1sdaname; 08-19-2015 at 07:38 PM. Reason: MSF Database - Automerged Doublepost
G1sdaname is offline   Reply With Quote
The Following User Says Thank You to G1sdaname For This Useful Post:
g00s3y (08-20-2015)
 Old 08-19-2015, 07:45 PM   #217
G1sdaname's Avatar
At first that's what I thought with my BNR3 but it ended up fitting with a little (a lot) elbow grease.
MilTuned - e85
-Gabe-
 Old 08-20-2015, 05:58 AM   #218
JBR
JBR's Avatar
Groans: 28
@G1sdaname; Those are some awesome pictures.
Yeah, it can be tricky...You have to get the turbo in just the right spot.
G1sdaname (08-20-2015)
 Old 08-20-2015, 06:36 AM   #219
g00s3y's Avatar
Groans: 439
Originally Posted by G1sdaname View Post
Thanks for this picture. Mine is pointed almost directly down, seems I need to have it point towards the front a bit more.
Yeah, I know about being able to do it without taking it off. I had the same exact problem when I rotated my k04, went a bit too much with it, and boost response was horrible. Was extremely happy though when I found out I could get to all the bolts with everything intact.
I need to get this fixed asap, I'm driving around with about 80hp/140tq around the city on my base map thanks to this lol. I could add some timing to compensate for the moment, but I should be able to get this fixed by Saturday, which is the better idea.
Did you rotate the WG also? The tip on mine points downward. Best pic I could get of it at the moment, with everything in the way, can't wait to clean up all that clutter.
 Old 08-20-2015, 07:19 AM   #220
G1sdaname's Avatar
You rotate the WG rod, I gotta find the write up and I'll post it.
MilTuned - e85
-Gabe-
 Old 08-20-2015, 08:44 AM   #221
g00s3y's Avatar
Groans: 439
I understand all that, that's not what I'm talking about. The WG itself, I see yours has the nipple pointing upward, mine is pointing down. I don't believe I rotated the WG itself, so I was wondering why the nipple would be facing the other way.
 Old 08-20-2015, 05:49 PM   #222
G1sdaname's Avatar
Default BNR S3 Swap How To
Well you have to place it in the right location but no you don't have to do anything to the WG itself
Here are some other pictures maybe this helps...
g00s3y likes this.
MilTuned - e85
-Gabe-
Last edited by G1sdaname; 08-20-2015 at 05:49 PM. Reason: MSF Database - Automerged Doublepost
g00s3y (08-21-2015)
 Old 08-20-2015, 07:44 PM   #223
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Anyone here running a turbo blanket? On it
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
Project_dog is offline   Reply With Quote
 Old 08-21-2015, 09:53 AM   #224
g00s3y's Avatar
Groans: 439
Test it with an air compressor... wow... I'm an idiot. This would have saved me so much time, and blood, and beer. Why did I not think of this all these times. The air compressor was just sitting right there in the corner of the garage, looking at me, knowing damn well what it could have done...
I should probably just sell this car and get a prius now.
 Old 11-11-2015, 10:34 PM   #225
Micha's Avatar
Posts: 3,436   (View Stats)
Micha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the world
Groans: 261
Groaned at 73 Times in 60 Posts
Sorry to resurrect an old thread but its pertinent to my situation.
I acquired what is to be an early BNR S3 V1. This has been confirmed with Bryan.
Anyways, while trying to clock it to put into my speed 3(yes she is going back together) it seems that the cold side of the turbo housing gets in the way of the WGA on the turbo.
Is the diameter possibly different on another WGA or even the second gen versions? Thank you very much for your help.
Micha is offline   Reply With Quote
 Old 11-12-2015, 05:36 AM   #226
Feline Führer
neganox's Avatar
Groans: 49
That seems odd. Does your V1 look like the left turba in this picture?
Official CatDickRacing Sales Rep - All products backordered.
The Following User Says Thank You to neganox For This Useful Post:
Micha (11-12-2015)
 Old 11-12-2015, 05:44 AM   #227
g00s3y's Avatar
Groans: 439
I had the same problem with my BNR S3 v2. It was a pain in the ass getting the WG back on. Had to drill out the holes a bit on the bracket so the WG could fit correctly on the bracket and not be at an angle from coming in contact from the housing.
The Following User Says Thank You to g00s3y For This Useful Post:
Micha (11-12-2015)
 Old 11-12-2015, 06:32 AM   #228
aviator79's Avatar
Posts: 3,925   (View Stats)
Groans: 67
is it the two port WG? That is what I have so ya there are different WGs.
 Old 11-12-2015, 05:02 PM   #229
Micha's Avatar
Groans: 261
Yessir. Single port WGA.
 Old 05-12-2016, 08:44 AM   #230
Josadol's Avatar
Posts: 1   (View Stats)
Josadol is an unknown quantity at this point
Cool
Hello my friends...I am happy to join this community ... where the main and most important our Mazdaspeed3 som ... I hope to learn a lot from you
Josadol is offline   Reply With Quote
 Old 05-12-2016, 10:32 AM   #231
Code Monkey's Avatar
Posts: 7,664   (View Stats)
taf0422 likes this.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
broda (05-12-2016), ItsNox (05-12-2016), Vansquish (09-06-2016)
 Old 05-12-2016, 11:20 AM   #232
broda's Avatar
Posts: 375   (View Stats)
broda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the world
Off to a resounding start
broda is offline   Reply With Quote
The Following 2 Users Say Thank You to broda For This Useful Post:
Code Monkey (05-12-2016), Vansquish (09-06-2016)
 Old 05-12-2016, 11:22 AM   #233
ItsNox's Avatar
Originally Posted by Code Monkey View Post
At least he doesn't have a speed 6 for once.
'06 Mazdaspeed 6 GT
- Miltuned
The Following 2 Users Say Thank You to ItsNox For This Useful Post:
 Old 09-06-2016, 11:16 AM   #234
PRIME-B's Avatar
Posts: 27   (View Stats)
PRIME-B has a spectacular aura aboutPRIME-B has a spectacular aura aboutPRIME-B has a spectacular aura about
Are you guys reusing the factory oil drain gasket or buying a new one? I'm going from stock to bnr s3 with all the supporting mods in pretty much one day, so doing my best to be prepared. Also, the coolant line is the only line that needs to be extended right? I read somewhere that the heater core hose needs to be done as well, but not all the write ups say that. thanks in advanced and wish me luck
"If you're not 1st, You're last"
PRIME-B is offline   Reply With Quote
 Old 09-06-2016, 11:51 AM   #235
everton99's Avatar
Posts: 1,044   (View Stats)
everton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the world
Groaned at 8 Times in 7 Posts
I believe my S4 came with new gaskets, but it's been a while since I installed it.
everton99 is offline   Reply With Quote
 Old 09-06-2016, 11:53 AM   #236
PRIME-B's Avatar
Ah, I bought mine used so I don't get such luxuries lol
 Old 09-06-2016, 04:19 PM   #237
PRIME-B's Avatar
Is everyone pulling oem studs off of the k04 or buying new ones? With how much of a pain the dp bolts were I feel like pulling the oem studs would be sketch.
 Old 09-06-2016, 09:13 PM   #238
ItsNox's Avatar
My studs were no problem coming out. My buddies got all mangled up when we pulled his out. A lot of factors go into it like age of car, miles, location, if turbo was pulled recently, etc. I would spend the extra few dollars for those parts, just in case.
The most valuable thing in my garage is the BOX-O-BOLTS i've accumulated over a few years of install days at my house. When your balls deep in an install and you lost/break/cut off a bolt you need, that backup is near priceless at that time.
OverBoosted likes this.
'06 Mazdaspeed 6 GT
- Miltuned
The Following User Says Thank You to ItsNox For This Useful Post:
PRIME-B (09-07-2016)
 Old 09-06-2016, 09:26 PM   #239
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
I have snapped enough reuses studs in the past that I just buy new ones. Nothing sucks more than having to pull the turbo back out and extracting what is left.
Sent from my VS986 using Tapatalk
Pickles Tune in progress
The Following 2 Users Say Thank You to himurax13 For This Useful Post:
ItsNox (09-07-2016), PRIME-B (09-07-2016)
 Old 09-07-2016, 10:18 AM   #240
PRIME-B's Avatar
@ItsNox; @himurax13; Thanks for the input fellas, I just placed the order with edge auto for all the studs and bolts along with the oil return line gasket. That should wrap it up. Ill post on how the install went for me once I get it in.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f498/bnr-s3-swap-how-88946/
Turbolader ausbauen / tauschen This thread Refback 06-09-2015 11:25 AM
Eine Frage an die Turbo Spezialisten - leichtes Pfeifen unter Last This thread Refback 12-31-2014 03:56 AM
TURBO Ein-Ausbau, Tips bzw. Anleitung This thread Refback 10-21-2014 01:11 PM
Turbolader defekt - Seite 2 This thread Refback 07-23-2014 02:20 AM
How do I remove the oil drain from a KO4 turbo ? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-02-2014 03:35 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades This thread Refback 07-08-2013 10:01 AM
Bnr s3 upgrade help This thread Pingback 06-24-2013 11:36 PM
Whats New/General Speed 6 Discussion - Page 236 This thread Refback 06-08-2013 04:23 PM
Beaner time! - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-10-2013 03:37 PM
BNR Stage 3 Turbo Upgrade - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-24-2013 04:04 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades - Seite 5 This thread Refback 02-20-2013 02:00 AM
Beaner time! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-26-2013 07:23 PM
mikey32235 everything is broken - Page 11 This thread Refback 12-01-2012 06:42 AM
• View topic - KO4E Turbo Upgrade This thread Refback 11-28-2012 10:27 PM
[ALLE] BNR Turbo Upgrades - Seite 5 - Turboaufladung - mazda-mps.de This thread Refback 11-13-2012 09:41 PM
[ALLE] BNR Turbo Upgrades - Turboaufladung - mazda-mps.de This thread Refback 11-03-2012 10:53 AM
BNR Stage 3 Turbo Upgrade - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-12-2012 09:04 AM
INTERCEPTOR EVOLUTION!!! This thread Refback 11-24-2011 01:15 PM
Fs-ZE Swap Focus MSP - ECU Computer Tuning 4 09-11-2014 07:43 AM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 04:04 PM
Page generated in 0.62312 seconds with 37 queries
