> MazdaSpeed 3/6 - Big Turbo Builds
MazdaSpeed 3/6 - Big Turbo Builds MazdaSpeed 3/6 - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here.
 Old 07-16-2010, 08:37 AM   #1
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
Question BT intake options
I've been jacking dustin's thread...sorry bro.
So now with a BT on my shelf, I'm looking into options...top mount turbo relocation sounds cool and all, but the thought of flipping the turbo around and likely needing new lines, custom dp and intake/inlet is a bit daunting, but I'm still weighing my options...
I've been looking around at different intakes/inlet combo...they are a couple I'm considering, namely from CP-e and ATP...
My first question is:
Looking at ATP:
and here's CP-e's, which comes with a filter to vent the VC:
It looks like neither one of this is plumbed for the PCV vac line to return to it like say, my Cobb SRI does:
I'm also wondering about velocity stack and straightener as well...the CP-e one has it "built-in" but I can't picture it, and I also like to have an extra filter around to prevent downtime...if I go with the ATP kit or DIY, should I also vent the VC? I'd prefer to plumb it back, for the sake of easier tuning?
-- Mario Andretti --
The Following User Says Thank You to Fobio For This Useful Post:
djuosnteisn (07-16-2010)
 Old 07-16-2010, 09:39 AM   #2
Posts: 12,649   (View Stats)
Venting the VC versus plumbing won't really change your tuning. It's meant to pull vacuum from your VC (relieve crankcase pressure) under boost and it is an emissions requirement why it is plumbed back into the intake versus just vented.
djuosnteisn (07-16-2010), Fobio (07-16-2010)
 Old 07-16-2010, 09:42 AM   #3
Driver
Fobio's Avatar
Groans: 44
yeah, I always thought venting the VC is illegal...those enviro tickets are like $600....
 Old 07-16-2010, 09:45 AM   #4
What turbo did you get?
 Old 07-16-2010, 09:46 AM   #5
Driver
Fobio's Avatar
Groans: 44
the ATP 3071R kit...
The Following 2 Users Say Thank You to Fobio For This Useful Post:
djuosnteisn (07-16-2010), Lex (07-16-2010)
 Old 07-16-2010, 09:48 AM   #6
Looking forward to how this one turns out
 Old 07-16-2010, 09:56 AM   #7
Why not just replace the inlet and keep the SRI MAF housing and filter?
Doesn't CPE sell a BT inlet? You can always make your own with some silicone couplers
EDIT: DOH, I realize you want a top mounted setup. Nevermind then ... just buy a MAF housing and make your own intake using silicone couplers.
 Old 07-16-2010, 10:04 AM   #8
Driver
Fobio's Avatar
Groans: 44
I'm considering the top mount option, and have looked at the CP-e inlet, along with the ATP inlet...both options are good if I stick with stock location, which is where I'm leaning now...
but yeah, if I go top mount, I'll have to buy some parts and have them welded...
also, the MAF housing for the Cobb SRI is not true 3" ID...it's been measured to be 2.6x - 2.75"?
 Old 07-16-2010, 11:34 AM   #9
Driver
Fobio's Avatar
Groans: 44
thanks to spnkr21:
Top mount turbo setups
Originally Posted by spnkr21 View Post
Don't worry about the intake-valve cover line. If you run a huge intake then there is no vacuum so that line is pointless after you rip off stock intake. Just vent it.
 Old 07-16-2010, 11:44 AM   #10
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
subparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the world
Groaned at 6 Times in 6 Posts
FYI Socks had his valve cover vented and the car ran like crap until he plumbed it back. I forget exactly what the reasoning is there, something like at idle or low loads it becomes a vacuum leak and pulls air in through the crankcase or something, as opposed to pulling in air that has already been read from the MAF.
2006 Lotus Elise: Toy car
1999 B4000: DD / Parts hauler / SC Project
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
subparpunk03 is offline   Reply With Quote
The Following 3 Users Say Thank You to subparpunk03 For This Useful Post:
djuosnteisn (07-16-2010), Fobio (07-16-2010), xcoldricex (07-16-2010)
 Old 07-16-2010, 11:50 AM   #11
Posts: 9,484   (View Stats)
I am currently running the CPE BT inlet and an Injen CAI cut off in SRI mode. G/s went up by 40 w the GT28 upgrade. I may look into a 3" MAF as well. The Injen is 2.75 IIRC
Does it really make that much difference??
 Old 07-16-2010, 12:04 PM   #12
BoostedBlack6's Avatar
Posts: 261   (View Stats)
BoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond repute
If you can find a subaru 3" maf housing those will work as well. FYI
2006 Black Mica MS6: Cobb AP, Stage 2 v105 93, MSD Dashhawk, Speedie6 TIP, CPe Nano SRI, HKS SSQV, Custom FMIC, Custom 3" Single Exhaust w/ Dynomax Race Muffler, H&R Sport Springs, SPC Adjustable Balljoints, TWM Stage 2 Short Shifter w/ SU bushings, 18" Drag DR-34s
BoostedBlack6 is offline   Reply With Quote
 Old 07-16-2010, 12:16 PM   #13
Driver
Fobio's Avatar
Groans: 44
Looks like I'm the only one active in both posts...lol...
Is this the 3" Subie DENSO MAF housing from ATP that we can use to build our intake?
3" MAF Housing - Billet Aluminum-for DENSO Element : atpturbo.com
 Old 07-16-2010, 12:27 PM   #14
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Groaned at 13 Times in 7 Posts
The top mount is tempting, don't get me wrong, but I wish I could have just slapped on an ATP turbo and just gotten things running. Messing with the lines and ensuring everything matches up is a PITA. And in my case, I'm using the stock location, just not using a bolt on kit........ I think it's more trouble then it's worth if you don't plan on pulling your turbo after it's setup.
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following User Says Thank You to -cj- For This Useful Post:
Fobio (07-16-2010)
 Old 07-16-2010, 12:28 PM   #15
SSinstaller's Avatar
Posts: 3,826   (View Stats)
Groans: 48
All you really need is a long 45 degree coupler a short length of 3.5" or 4" piping and your MAF housing. Any decent welder should be able to weld on a small fitting so you can reconnect the valve cover port.
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
 Old 07-16-2010, 12:34 PM   #16
Driver
Fobio's Avatar
Groans: 44
any need for an air straightener/velocity stack when going big?
 Old 07-16-2010, 12:36 PM   #17
Groans: 48
As long as there are no bends immediately before or after the MAF housing you shouldn't have any issues..
 Old 07-16-2010, 12:41 PM   #18
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I will post pictures of my last 3" intake I made, which will soon be for sale. I will also post what I'm using for my new one once I get everything.
The Following User Says Thank You to madvillain For This Useful Post:
Fobio (07-16-2010)
 Old 07-16-2010, 01:29 PM   #19
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
bcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the world
Im following this because im looking to replace CAI. i also have the 3071 but im not going top mounted
bcmurphy87 is offline   Reply With Quote
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
 Old 07-16-2010, 02:03 PM   #20
Driver
Fobio's Avatar
Groans: 44
I'd say that it'd make enough of dif that if you don't do it now, you'll end up doing it down the road anyway.
 Old 07-16-2010, 02:34 PM   #21
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
You're right, you are pulling in unmetered air through the Pcv but it's not enough to throw your fuel trims off too much. My car doesn't act funny, couple after-fires now and then, but overall it's good.
You certainly can hook it up, but it isn't needed so don't sweat it.
2012 WRX HB w/mudflaps yo!
The Following User Says Thank You to spnkr21 For This Useful Post:
 Old 12-03-2013, 01:44 PM   #22
Jeff23spl's Avatar
Posts: 1,216   (View Stats)
oups just seen it is a 3 years old thread
1993 Ford Probe KLZE
2012 Mazda3 Gs-sky to save fuel and when the speed is broken
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
2007 speed3 burned
...Because French Canadian...
 Old 12-03-2013, 01:47 PM   #23
Code Monkey's Avatar
Posts: 7,634   (View Stats)
LOL
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
MCS coilovers|Brembo BBK|6UL 17x9|Nitto NT01|ACE 350|Delicious tuned
2000 E39 M5
2001 MR2 2ZZ
turbo options LiEast MazdaSpeed 6 - Engine, Transmission & Driveline 6 07-30-2010 11:38 PM
Cold air intake vs short ram intake knarfies MazdaSpeed 3/6 - Turbo Induction 3 04-27-2010 03:15 PM
STS options Zeya MazdaSpeed 3 - Engine, Transmission & Driveline 77 07-28-2009 04:09 PM
Tuning options? steedspeed MazdaSpeed 3/6 - ECU Computer Tuning 1 05-03-2009 04:43 PM
BOV/BPV options Derek88 MazdaSpeed 3/6 - Turbo Induction 12 04-18-2008 05:58 PM
Page generated in 0.43691 seconds with 31 queries
