> MazdaSpeed 3/6 - Big Turbo Builds
MazdaSpeed 3/6 - Big Turbo Builds MazdaSpeed 3/6 - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here.
 Old 12-22-2017, 10:07 AM   #1
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
Default Built Motors - P2W and Ring Gap Thread
I'm in the process of building an engine and I'm getting mixed information on what clearances I should be running. Specifically P2W and End Gaps.
The information provided with the Manley 2618 pistons suggests .003 P2W for coated pistons, which these are. I've been told that's way too tight for 2618's.
The provided sheet (see attachment) also lists suggested ring gaps that vary depending on what set up you have, which I completely understand. More HP/more heat -> more cold ring gap so that the running ring gap is adequate to not bind.
I'm shooting for about 450whp, which on a MS6 is about 600 crank...give or take. According to the Manley suggestion chart, the ring gaps should be:
...Assuming I'd have to exceed 30psi on this Corksport turbo to get there...
Top Ring: .0277 (.008 x 3.4645, 88mm)
Mid Ring: .0277 (.008 x 3.4645)
Bot Ring: .015 Minimum
Those numbers don't look right to me as I've occasionally seen ring gaps posted on this forum that are tighter.
So to the main point of this post is this:
An all inclusive reference for anyone doing a build.
Please post what you are running in your build.
Please list all parameters that apply to this subject. Such as...
Piston Material (cast, 4032, 2618, coated/uncoated)
P2W Clearance
At what ambient temps do you start to hear piston slap on cold starts
End Gaps
Compression/Leakdown Test Results (specify cold or warm/hot)
Boost
Fuel (Pump, E85 mix %, WMI & nozzle size, Nitrous & shot size)
Dyno numbers. While vDyno might not be perfect, I think it's close enough for this subject.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 12-29-2017, 04:42 PM   #2
shamie's Avatar
Posts: 923   (View Stats)
My machinist used the same chart you reference but we did medium boost so 0.007" x bore.
I think the tighter gaps are from people following the Mazda engine assembly manual. Those tighter OEM gaps may be what cause the OEM ringland failures - not weak ringlands.
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
 Old 12-29-2017, 04:48 PM   #3
Fstrnyou's Avatar
Ya. The OEM ring gaps are very tight. Too much heat and the rings expand enough to butt together and bind up against the cylinder walls like nobody's business...bye bye ringlands.
It's great for nearly stock engines. Tight clearances are one of the reasons engines last longer these days. Last time I checked compression, 130k+ miles on my engine, and it was pumping in the 180's. My beater truck has 354k miles and compression is in the 190's.
@shamie;
In the best interest of the thread, do you recall:
Which piston?
P2W clearance?
Experiencing piston slap when cold?
How much power ard you making?
Spraying meth? Nozzle?
Using E85? Mix?
Other rides:
History:
 Old 12-30-2017, 08:41 AM   #4
5doorsoffury's Avatar
Posts: 1,070   (View Stats)
Groans: 74
Well i have the gray sp63 2618 pistons which i believe are Manley coated and when i asked sp63 what the PWC was set at they responded .0029. So being it was almost a year later (block sat in garage while accumulating parts) they may of not known and just gave me a generic answer.
MECP
2012 BM
Rfinkle tune in progress
 Old 12-31-2017, 03:18 PM   #5
shamie's Avatar
@Fstrnyou;
Manley rods (just the H beams not the Turbo Tuff Pros) and Manley pistons from Edge. The P2W clearance was right on what Manley specs out at 0.0035" - that was about all the first builder did right when he had it bored out (88mm pistons).
I've never noticed any piston slap but I do have a pretty noisy engine bay - AT internals, BSD, and ACT clutch.
I was making ~320 (VD) with the 2867 on 91 octane. I was knock limited with the higher compression from 2 head mills.
Now I'm making 285 on 91 and 320 on e31 back on my original k04. There's probably more left on the table but my wt/HP is where I need it for TT4 and there are areas other than HP I need to address to bring my times down (aero)
 Old 12-31-2017, 03:26 PM   #6
Fstrnyou's Avatar
Good to know you have no issues with that P2W doing TT runs.
Other rides:
History:
 Old 12-31-2017, 06:26 PM   #7
shaneski's Avatar
Posts: 481   (View Stats)
Which piston? Manley standard bore, non coated when first on the market.
P2W clearance? .0035, used a brand new block.
Experiencing piston slap when cold? it was built near 3 years ago and done 35000 miles, i don't hear any slap at all as yet. It gets used as a daily, long cruises and drags
How much power are you making? Not sure, it has trapped 124.95 mph with full interior
Spraying meth? Nozzle? 100% meth using a devils own DVC30 kit and uses a cooling mist CM14 nozzle.
Using E85? Mix? No E85
Boost..around 28psi.
Haven't done a compression test in a while but it barely uses any oil and the catch can doesn't have much in it when i check it each 3000miles at oil changes.
I also have all the parts here ready to take to the engine builder including a set of coated Manley pistons with upgraded wrist pins to forge and sleeve the original motor that came out of it, which will have meth port injection and a precision 6062 on it.
 Old 12-31-2017, 07:52 PM   #8
Fstrnyou's Avatar
Have you done any roll racing or highway pulls? 4th, 5th, 6th gear? I have occasionally done that...in Mexico of course...on my stock block but I'm not pushing much power. 300wtq/300whp at MOST on a good day.
I need to build with enough clearance to accommodate that amount of heat. Again, 2618 pistons.
Once enough data is in this thread, I'll start plugin' them in a spreadsheet for anyone wanting to do build their own engine.
Other rides:
History:
 Old 12-31-2017, 08:31 PM   #9
shaneski's Avatar
Yeah man it has had a lot of roll racing and sustained WOT pulls through all gears when we go on carmeet/cruises, the car has also had long trips where it has been driven for 15 hours straight, a quick sleep then another 15 hours across Country here in Australia a number of times, that include heaps of WOT during over taking lines of trucks using 5th and 6th on single lane roads.
I am also guilty of doing a lot of short trips before reaching the correct engine temps and it has zero issues
The Long skirts beefy ringlands and overall design of the Manley 2618 piston to not slap does it's job.
 Old 12-31-2017, 09:57 PM   #10
Fstrnyou's Avatar
Stumbled on this thread from 2014 when the Manley 2618 Pistons were somewhat new.
Good read.
Manley Pistons, arrived with not much fanfare
Also, in that thread is a useful link to ring gap myths...
Institution Of Diagnostic Engineers
Other rides:
History:
 Old 12-31-2017, 11:58 PM   #11
impossible's Avatar
Posts: 732   (View Stats)
Groans: 30
The grey 2618 pistons are a custom ordered Mahle piston, not Manley.
2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning
 Old 01-01-2018, 04:33 AM   #12
Mazduhspeed6's Avatar
Posts: 157   (View Stats)
Mazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to all
Groaned at 17 Times in 6 Posts
This is an interesting read, need more posters for info.
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 01-01-2018, 06:25 AM   #13
Groans: 74
Mahle Manley they all look the same after a few cups of irish coffie!
MECP
2012 BM
 Old 01-01-2018, 09:24 AM   #14
BuddySpeed3's Avatar
Posts: 461   (View Stats)
Groaned at 7 Times in 4 Posts
That's a good read. They state that as piston rings wear out, the end gap gets bigger. Makes me wonder if higher mileage engines have a smaller chance of ring butting at the expense of slight compression loss.
- 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 2 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress)
 Old 01-05-2018, 05:19 PM   #15
Fstrnyou's Avatar
Default Interesting info direct from Manley
Hello,
Happy New Year.....and thank you for your email, your business and kind words below. It is greatly appreciated!
Based on below, you are using Manley pistons P/N 630005C-4 or 630005CE-4 (if you got the wrist pin upgrade).......see catalog page 14 of attached
Honestly, based on details you provided below, I would still recommend .003" PTW (piston to wall) clearance with these pistons.....they will perform great there.....it's not "too" tight. If you wind up at .0032" when bore/hone the block, that's not the end of the world either.....but I wouldn't bigger
Have fun with it! Let me know if have any other questions
-----Original Message-----
Sent: Wednesday, January 03, 2018 10:32 PM
To: Sales Manley
Subject: Mazda MZR and Manley 2618 Platinum Pistons - PWC / P2W Clearance
Thank you for taking the time to read my inquiry. I am building a 2.3L Mazda MZR DISI Turbo, 88mm cylinder bore. My daily driver power goals are, at most, 125whp per cylinder with boost in the high 20's. That's a bit much for pump gas, so I will be using an E85 mix, if that matters. I see the spec sheet says 0.0030 PWC for coated pistons. If that's the minimum, what do you recommend for my power goals?
Thanks again. I'm using your H-Tuff rods too. Both beautiful looking components.
Other rides:
History:
 Old 08-29-2018, 06:52 AM   #16
allservice's Avatar
Posts: 53   (View Stats)
allservice is infamous around these partsallservice is infamous around these partsallservice is infamous around these parts
Groaned at 65 Times in 47 Posts
To OP: Sorry to resurrect this thread, but I am building my motor with Mahle 4032 and I gotta say there is an error in your post relating to the gaps
"Bot Ring: .0519 (.015 X 3.4645)" is actually wrong
The bottom ring gap is straight 0.015 (or about 0.4mm). Do not multiply with the Bore!!
Please update your first post so people will not mess up their builds
Mazda 3 MPS 2008, dealer purchase June 2008. Freaktuned.
Engine: Rebuilt w/ Wiseco pistons & Manley rods, Corksport turbo, Corksport injector seals, Corksport EBCS, Corksoport 3.5 Map sensor, CPe TMIC, Corksport Boost tubes + bypass valve hose, GFB Respons BOV, JBR 3.5 WidePath Alu, Autotech HPFP, BSD & self made oil pan, CNT catted DP, Vibrant Ultraquiet & stock catback, Damond OCC, JBR Intake Gasket, JBR Throttle Body Gasket & Coolant Bypass Kit, NTK 24357 Oxygen Sensor, NGK LTR7IX-11 6510 spark plugs, Cobb APV3, E-focus RMM & Stock PMM/DMM (because BSD NVH)
Suspension: Bilstein B12 (used SWIFT springs, KONI yellows , etc), Hotchkis Sways front and rear, Self made steering correction kit based on Whiteline specs, Whiteline KLC151 adjustable front sway bar links, Moog rear sway bar links, Moog steering tie-end rods, AcDelco Camber Arms.
Wheels: OZ Ultraleggera Black Matte 18x8, 225/45/18.
Brakes: Stoptech slotted front rotors (replaced DB4000 which lasted years), EBC slotted rear rotors, EBC yellow stuff pads.
Fluids: Motul 5w30 Ford specific or Motul 5W30 Econergy or Ravenol LSG 5W30, Ford magic gearbox honey, Motul steering fluid, Motul RBF660 brake fluid.
allservice is offline   Reply With Quote
 Old 08-29-2018, 09:14 AM   #17
Fstrnyou's Avatar
Foroot about this thread and my apologies for the typo.
It has been fixed.
My build:
I told machine shop to set P2W at 3.5, despite Manley's email confirming 3 thou is good.
When I got the block back, I measured P2W to be in a range of 3.2 to 3.8. Less than pleased.
I built it as it was and set ring gaps to .024 / .026
With BSD and ACT clutch, I too have a noisy engine bay. But it doesn't get any quieter when warm/hot, so no piston slap yet. I'm curious what winter will bring.
Other rides:
History:
 Old 11-21-2018, 02:36 PM   #18
hdragster's Avatar
Posts: 30   (View Stats)
hdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to behold
It has been fixed.
My build:
That's .024 for top and .026 for bottom rings correct?
hdragster is offline   Reply With Quote
 Old 11-21-2018, 09:14 PM   #19
Fstrnyou's Avatar
24 top, 26 middle ring.
Other rides:
History:
Sasuke-kun (11-26-2018)
Cracked ring lands = Built Motor DTKII MazdaSpeed 3/6 - Build Diaries 27 02-04-2014 03:07 PM
Ford hybrids to get U.S.-built drive motors from Toshiba Haltech Automotive News 0 06-23-2010 03:10 PM
Guys with built motors Spoolme MazdaSpeed 3 - Engine, Transmission & Driveline 31 06-01-2010 01:28 PM
For the guys that have built motors??? johnac08 MazdaSpeed 3/6 - Turbo Induction 20 12-23-2009 04:03 PM
Page generated in 0.44010 seconds with 29 queries
