| MazdaSpeed 3/6 - Big Turbo Builds MazdaSpeed 3/6 - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #921 | ![]() |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score
im pretty sure the core connections are 2.5, they have reducer couplings on it. ill have to double check that. better have 2.5 or ill be pissed!!! lol.....
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts | |
![]() | | #922 | ![]() |
| Not Ranked : 0 score ok, just checked, yes the core has reducing couplers on it. so it should be 2.5 to 2.25. like other people have stated. a small change in pipe sizing make a huge difference. wile the 2.25 is fine for stock and 30 series turbos, it might be a lil small for bigger turbos. i could be wrong though..... any thoughts? and the over, under car routing is mainly to take the shortest route, less couplers, and prolly a lil cooler, and free up space up top.
![]() | | #923 | ![]() |
![]() Join Date: Sep 2008 Location: phoenix, az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,229
Groans: 78
| Not Ranked : 0 score The OD of the TB is 2.75" IIRC, the ID is 2.5". I'm really curious to see what the difference would be with larger/smaller piping. Plus, the difference between these different piping routes. If you think about it, if you increase the diameter of the piping, you're simply increasing the amount of air in the system available to the motor, am I right? So isn't that the same thing as the Cp-e kit or something, where there is like 15ft of piping, even though it is 2.25"? Where as mine is like 6ft of piping at 2.5"?
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
![]() | | #924 | ![]() |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
Approx. The ID is 60 mm, which is actually closer to 2 3/8", but close enough. And the OD is within a few thousanths of 2.75".
So, if going under the car shortens the pipe, that in itself is a good reason to go that route. If it also happens to help a bit with cooling the charge, even if only a small amount, that is just another bonus. | |||
| The Following User Says Thank You to Speedie6 For This Useful Post: | mason (12-30-2010) |
![]() | | #925 | ![]() |
![]() Join Date: Dec 2010 Location: TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 159
Groans: 31
Groaned at 36 Times in 28 Posts
| Not Ranked : 0 score A lot of people think that bigger I/C piping causes lag, but I have evidence of this not being the case. A guy on the Focus forums is running a GT35R with 3" hot side piping and 3.5" cold side piping. He used to run 2.5/3 and he said he most definitely picked up a couple hundred RPMs in spool, same turbo, same cams, all that. |
| The Following User Says Thank You to bmylez For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #926 | ![]() |
![]() | | #927 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score The stock TB is 60mm or 2.36", but if you take the area of that 2.36" bore it is 4.374"sq then subtract out the approx area of the blade and shaft which we will very conservatively call .125"x2.36", we get .295"sq from 4.374"sq or 4.079"sq of usable area or 2.279" diameter usable bore. Then after calculating in turbulence the effective flow is even less. While mathematically all we actually need is a 2.25" ID pipe to match the flow of the TB, in the real world we could probably run a 2" ID pipe and be just fine.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | FreeFlyFreak (12-29-2010) |
![]() | | #928 | ![]() |
![]() | | #929 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
When under WOT conditions, wrapping the pipe will result in < 1°F temp changes (completely negligible). Under very light load conditions (idle/cruise), it is possible this could result in 10-20°F differences. But there is no reason to go there with respect to power/longevity.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 12-30-2010 at 03:48 PM. | |
| The Following 4 Users Say Thank You to cld12pk2go For This Useful Post: | Dano (12-30-2010), djuosnteisn (12-30-2010), MS3-a(sore)ASS-rex (12-30-2010), qtrmile beast (01-01-2011) |
![]() | | #930 | ![]() |
Groans: 79
As far as piping diameters go.... it's all bout volume. Calculate the total volume of the piping, and the intercooler... and you get something fairly small... like 6 ft of piping (you can assume square pipes to make things simple, concept still applies), and say the pipe is 2" dia. The piping volume is 6 x 0.167 x 0.167 (dimensions in feet) = 0.167 cubic feet. Negligible. Throw in the intercooler volume for giggles, assuming like 24" x 10" x 3.5" super core like mine... you get 2 x 0.83 x 0.29 = 0.48. So were looking at a whopping 0.65 Cubic Feet of charge volume. When you consider the motor is basically pumping about 121 CFM @ 3000rpm, or 2 cubic feet per second... You could run 5 in charge piping and probably not make too much of a difference on spool. In fact, if the piping is a restriction... you may actually gain spool as the bmylez explained.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 8 Users Say Thank You to djuosnteisn For This Useful Post: | cld12pk2go (12-30-2010), Dano (12-30-2010), MS3-a(sore)ASS-rex (12-30-2010), qtrmile beast (01-01-2011), SilverDemon (12-30-2010), tbot (12-30-2010), turd burglar (12-30-2010), xdm88 (12-31-2010) |
![]() | | #931 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score |
| The Following 2 Users Say Thank You to xcoldricex For This Useful Post: | djuosnteisn (12-30-2010), MS3-a(sore)ASS-rex (12-30-2010) |
![]() | | #932 | ![]() |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score ^^i think there is the reason why "rice" is in your username...just saying...
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
| The Following User Says Thank You to tbot For This Useful Post: | jmhinkle (12-31-2010) |
![]() | | #933 | ![]() |
Groans: 31
| Not Ranked : 0 score Well, it's not *that* ricey considering he did it for a practical reason and it's done cleanly. Not my style, but at least it's on the inside instead of sweet vinyls and huge spoilers on the outside... |
![]() | | #934 | ![]() |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score That gold heat tape works fucking magic man. Sucks it's super expensive for being just tape lol. Turboxs fmic FTMFW!!!!
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
![]() | | #935 | ![]() |
| Not Ranked : 0 score By the way, what xcoldricex did looks totally fine to me. I think most people think it is of negligible value, but, it looks fine to me.
Seems to me, correct me if I'm wrong, but 2 1/4" pipe should be enough unless you have a huge turbo and a bored throttle body. And at that point, 2 1/2" should cover you, no? | ||
![]() | | #936 | ![]() |
Groans: 40
| Not Ranked : 0 score Think of the difference of blowing air thru a coffee stirrer straw vs a one of those big ass straws Burger King has for their shakes...
![]() | | #937 | ![]() |
Groans: 31
| Not Ranked : 0 score Yes, the throttle body becomes the big restriction when trying to run large I/C pipes. The guy who ran 3.0/3.5 pipes also had an 80mm TB. Having such a big TB was definitely the key to utilizing the huge charge pipes. Looks like somebody needs to develop a dang bigger TB for us... |
![]() | | #938 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score Back on the top mount topic lol..... I think it'd be easy to make an intake that sits in the same position as this one. It would just kinda come over the hpfp area a tad, and tuck down in there. Would everyone be okay with this? Also, i'll have to figure out how to add a recirc pipe to it. Cause i doubt you'll all wanna run cowboy vta like me lol. I'm eager to do some fitment on an ms3 soon.
| The Following 7 Users Say Thank You to djuosnteisn For This Useful Post: | bmylez (12-30-2010), Dano (12-30-2010), manelscout4life (12-30-2010), MS3-a(sore)ASS-rex (12-30-2010), SilverDemon (12-30-2010), tbot (12-30-2010), xdm88 (12-31-2010) |
![]() | | #939 | ![]() |
Groans: 224
| Not Ranked : 0 score Intake idea is perfect! I've been running vta for 20k miles, so I say FUCK A RECIRC FITTING!
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #940 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 944
Groans: 127
Groaned at 40 Times in 31 Posts
| Not Ranked : 0 score Sounds like a great idea dj, post pics when you test fit on the ms3. That's the only thing I am "slightly" worried about. I am sure it will fit though with maybe a smaller batt box? |
| The Following User Says Thank You to kilik2 For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #941 | ![]() |
Groans: 224
| Not Ranked : 0 score It'll fit anyway. At least up to 3.25". CPE already sells an intake that size and it fits
![]() | | #942 | ![]() |
Groans: 79
Tomorrow i'm going to make the first down pipe off my jig for ms6 and do a final test fit with the SS mani. After than i want to install it on a local's car. He already has all the stuff pretty much, just need to put it all together. If that goes well... i think i'll build up 5 ms6 kits and move on to the ms3. I'll post some more pics tomorrow hopefully cause we all love pictures.
| The Following 10 Users Say Thank You to djuosnteisn For This Useful Post: | Dano (12-30-2010), doubleflusher (12-30-2010), kilik2 (12-30-2010), manelscout4life (12-30-2010), MPSdriver (12-30-2010), MS3-a(sore)ASS-rex (12-30-2010), qtrmile beast (01-01-2011), SilverDemon (12-30-2010), tbot (12-30-2010), turd burglar (12-30-2010) |
![]() | | #943 | ![]() |
Groans: 40
| Not Ranked : 0 score I wish I haz more monies...I'm excited for this!!!
| The Following User Says Thank You to tbot For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #944 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score No worries, i hope to keep at least 3 kits finished at any given time, so i'm sure i'll have one whenever your ready. Focus on your motor right now hahahaha.
![]() | | #945 | ![]() |
Groans: 40
| Not Ranked : 0 score Yeah likes that's easy with everyone in here making kick ass parts! Sent from my HTC Glacier using Tapatalk
| The Following 2 Users Say Thank You to tbot For This Useful Post: | djuosnteisn (12-30-2010), SilverDemon (12-30-2010) |
![]() | | #946 | ![]() |
In other words, CPE does NOT have a true 3.25" intake. Not with the parts they sell. | |
![]() | | #947 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score Well....... mine will be lol. Worry not speedie6, i'll find a way to fit it.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | MS3-a(sore)ASS-rex (12-30-2010), tbot (12-30-2010) |
![]() | | #948 | ![]() |
| Not Ranked : 0 score I'm sure you can. My suggestion, which you can of course take or leave, but my suggestion would be to use a 3.25" ID on your MAF, simply so that some of the MAPs being made for the CPE XcelXL can be used as a good "starting point". With all the cool stuff you are doing, I'm definitely regretting my current build, which is more conventional. I never heard the words "twin scroll" until after I had parts in hand. To my understanding, the primary benefit to twin scroll is quicker spool. So you can have a bigger turbo with the spooling of a smaller turbo, correct? But, even with twin scroll, wouldn't a twin-scroll GT35 spool slower than, say a basic 3071? Would there be a twin scroll of something on the order of a GTX3076? Of course, other brands would be options as well. |
| The Following User Says Thank You to Speedie6 For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #949 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score Yeah, there's twin 3076's as well. it all depends on what hotside you equip the turbo with. Here's ATP's 3076 page for instance. Just scroll down and look at all the different options: Garrett GT3076R (aka GT30R aka GT3037) Ball Bearing Turbo : atpturbo.com And you have the right idea behind a TS setup...
![]() | | #950 | ![]() |
| Not Ranked : 0 score Thanks for that. Presumably, you could get that GTX as well. So, perhaps, the GTX3076 twin scroll might be a good option for this system you got. If I was buying now, that is probably what I would look at getting. |
![]() | | #951 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score The GTX series are pricey, but the performance seems to almost justify it. Their compressor maps look gorgeous.
![]() | | #952 | ![]() |
Groans: 224
| Not Ranked : 0 score GTX are so fucking expensive. I'm pretty sire the HTA is cheaper for primarily the same thing...
![]() | | #953 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score So for a twin scroll turbo lets say like 3071 size wat would u guys get? This is to be used with this kit and the steedspeed Mani on a speed6
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| The Following User Says Thank You to MSP611 For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #954 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score I'm leaning towards the HTA3076R. Convince me otherwise.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following 3 Users Say Thank You to doubleflusher For This Useful Post: |
![]() | | #955 | ![]() |
| Not Ranked : 0 score I dunno if I wanna go tht big I was set on a gt2871 before, but tht was before knowing about twin scroll and if I'm gonna make this my weekend warrior and do this top mount setup might as well make it worth while. Any suggestions on twin scroll 3071's?
![]() | | #956 | ![]() |
| Not Ranked : 0 score HTA is something else I never heard of, but, I just googled it, and, sounds like a fine choice! Though since the HTA35 is supposed to spool about 400 RPMs sooner than a regular 35, that seems like a possibility too. Well, if you are going to go with this setup, seems to me that the 3076 range is a good option. Not really "bigger" than a 3071, really. Same housings. Just a different compressor wheel. And the twin scroll is, in theory, supposed to bring the spooling down. |
![]() | | #957 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score I can't lol, that'd be the perfect turbo for this setup IMO. Put a 0.82 or 0.78 a/r TS hot side on it and call it a day. Fast spool and plenty of flow. 3076 isn't really that big of a turbo. It's honestly the perfect size for the 2.3 MZR. Ask some of the guys who bought gt28's, and they'll agree they should have gone bigger to start with. The difference in spool between the two isn't all that big, and the 3076 will be able to support quite a bit more flow over the 28.
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #958 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score Maybe twin 28's with twin scroll.
__________________ 2012 WRX HB w/mudflaps yo! |
| The Following User Says Thank You to spnkr21 For This Useful Post: | djuosnteisn (12-30-2010) |
![]() | | #959 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score That'd be fucking awesome lol.... but i wouldn't want to be the guy building the manifold. Twin k04's..... maaaybe...
![]() | | #960 | ![]() |
| Not Ranked : 0 score Hmm thx for convincing me . So any suggestions on twin scroll 3076's?
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f498/top-mount-turbo-setups-61011/ | ||||
| Bosch 3 Bar MAP - ATR values | This thread | Refback | 04-05-2012 07:59 PM | |
| Mazda MPS Owners Club • View topic - New Turbo me thinks ! | This thread | Refback | 03-20-2011 03:57 PM | |
| Gauge setups | TheNewGuy | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 03-14-2011 06:56 PM |
| Top Mount Turbo Manifold | aminzer | Mazdaspeed3/6 General Discussion | 25 | 02-06-2010 08:19 PM |
| AP & Forge setups. | 08cosmic3 | Cobb Access Port/Maps | 0 | 08-08-2009 06:52 PM |
| TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! | Raider | Mazdaspeed Forums User Reviews | 0 | 06-29-2009 06:40 AM |
