| MazdaSpeed 3/6 - Big Turbo Builds MazdaSpeed 3/6 - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #1001 | ![]() |
![]() Join Date: Dec 2010 Location: TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 159
Groans: 31
Groaned at 36 Times in 28 Posts
| Not Ranked : 0 score |
| The Following User Says NO Thank You to bmylez For This Un-useful Post: | Enki (01-06-2011) |
![]() | | #1002 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score Well I kinda decided Its better to be safe then sry and build the bottom end atleast. Well what kinda power am I lookin at for say a tune between19-21lbs for a 3076?
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #1003 | ![]() |
Groans: 31
| Not Ranked : 0 score Ugggh, I'm stupid. Ok, sorry. Let's back track. You won't quite need 50 lbs/min to hit your goal. I redid the math, taking into account how efficient DI is as well as assuming you can rev to 7k rpm with a built motor. 21psi should pretty much get you to 400awhp. Don't quote me on that, though! |
![]() | | #1004 | ![]() |
| Not Ranked : 0 score I was wondering cuz. I've seem guys on like stock turbs at like 22-24lbs or wit bnr's runnin like 380s but I wasn't sure I'm Not the mathmetician here lol
![]() | | #1005 | ![]() |
![]() Join Date: Jul 2010 Location: st louis, mo
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
like to keep my options open | |
| The Following User Says Thank You to xdm88 For This Useful Post: | djuosnteisn (01-01-2011) |
![]() | | #1006 | ![]() |
| Not Ranked : 0 score Good questions^^
| The Following User Says Thank You to MSP611 For This Useful Post: | djuosnteisn (01-01-2011) |
![]() | | #1007 | ![]() |
Groans: 31
| Not Ranked : 0 score I suppose it's not that much of a hardship to tune for VTA BOV. My car is already running 50/50 as is. I might still want a recirc pipe, though... |
| The Following User Says Thank You to bmylez For This Useful Post: | djuosnteisn (01-01-2011) |
![]() | | #1008 | ![]() |
| Not Ranked : 0 score ^^fuck tht. Question... If u have EWG u can still run recirc correct?
![]() | | #1009 | ![]() |
Groans: 31
| Not Ranked : 0 score Yes, you can have an exhaust shop make a custom recirc tube into your downpipe. I forget who it was, but they had Meineke weld up a pipe for $125. I'm still torn on recirc'ing or not. It's much more complicated to recirc. Maybe I'll have them make an extended tube with a mini muffler on it, haha. |
![]() | | #1010 | ![]() |
| Not Ranked : 0 score ^ya but then if u go VTA u have to tune for the missing air goin into the atmosphere which probably isn't hard, but if u don't get the tuning right ull be runnin pig rich every where poppin on decel. At least to my knowledge
![]() | | #1011 | ![]() |
Groans: 31
| Not Ranked : 0 score Bro, what are you talking about? Wastegate or blow off valve? Two VERY different things. Wastegates don't have to be tuned for. BOV, yes. |
![]() | | #1012 | ![]() |
| Not Ranked : 0 score I'm talkin bov sry. I've nvr had EWG so I don't know much about them I thought they were always VTA
![]() | | #1013 | ![]() |
the mini muffler doesn't work too well...too much restriction...a buddy of mine with an LGT gave a few "performance" motorcycle mufflers a try and the WG couldn't dump enough and he got creep....he the got it connected to his DP for a lil over 1 C note.
| The Following 7 Users Say Thank You to Dano For This Useful Post: | bmylez (12-31-2010), djuosnteisn (01-01-2011), doubleflusher (01-01-2011), DSIT995 (01-01-2011), MS3-a(sore)ASS-rex (01-01-2011), xcoldricex (01-01-2011), xdm88 (01-03-2011) |
![]() | | #1014 | ![]() |
Groans: 31
| Not Ranked : 0 score Alright, scratch the muffler idea then! Thanks for the heads up. I'll prolly run open dump until I get tired of the noise, haha. |
![]() | | #1015 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score Yeah, no harm in that at all.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | xdm88 (01-03-2011) |
![]() | | #1016 | ![]() |
| Banned ![]() ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
Groaned at 113 Times in 32 Posts
| The Following User Says Thank You to cageyvet For This Useful Post: | djuosnteisn (01-02-2011) |
![]() | | #1017 | ![]() |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score DJ, for the oil and coolant lines...... are you just welding on AN fittings to the stock connections? then we run SS braided lines from there to turbo rite? im just going over all the fittings i need for turbo. bango, oil restrictor, AN ect... and was also wondering the proper length of SS lines we will need for top mount set up?
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
| The Following User Says Thank You to mason For This Useful Post: | djuosnteisn (01-02-2011) |
![]() | | #1018 | ![]() |
Groans: 31
| Not Ranked : 0 score Oh I was under the impression that we didn't have to buy anything for the oil/coolant lines. I thought he modified the stock ones to connect back to OEM points. I was getting excited that I didn't have to figure out any hoses or fittings on my own (just being lazy, I am capable). |
| The Following User Says Thank You to bmylez For This Useful Post: | djuosnteisn (01-02-2011) |
![]() | | #1019 | ![]() |
| Not Ranked : 0 score Well I want to spend like 5 grand on the whole motor build including turbo and everything if I can. I jst want a quality quick spooling turbo tht will make good power on low boost nothin more then like 21lbs. I Dont really care on numbers to much so I kinda understand where ur sayin save with not Gettin a huge gt series. I thought the 3071 would be a good choice but I dunno WTF I'm lookin for when I'm getting into individual turbos. I'm jst a good mechanic with mediocre knowledge (more on jets though), since this Is my first BT adventure.
| The Following User Says Thank You to MSP611 For This Useful Post: | djuosnteisn (01-02-2011) |
![]() | | #1020 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 944
Groans: 127
Groaned at 40 Times in 31 Posts
| Not Ranked : 0 score Are you building yourself? that's cutting it kinda close, and there are going to be a lot of hidden expenses that come up out of nowhere. |
| The Following User Says Thank You to kilik2 For This Useful Post: | djuosnteisn (01-02-2011) |
![]() | | #1021 | ![]() |
| Not Ranked : 0 score Yes building myself
![]() | | #1022 | ![]() |
![]() | | #1023 | ![]() |
Groans: 31
| Not Ranked : 0 score You'll just have to deal with more lag if you go with journal bearing. As a side note, perhaps you should make your own build thread so we don't keep going off topic . You'll probably get more help that way. |
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | djuosnteisn (01-02-2011), kilik2 (01-01-2011) |
![]() | | #1024 | ![]() |
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna | |
![]() | | #1025 | ![]() |
| Not Ranked : 0 score I would but I'm not building anything yet jst finding suggestions and keepin interest in this top mount subject.
![]() | | #1026 | ![]() |
For the power and boost you're talking about I'd get the 60-1 (garret t3 60-1) or precision sc6169(the 6169 should have the stage III turbine wheel) Last edited by cageyvet; 01-01-2011 at 03:32 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #1027 | ![]() |
| Not Ranked : 0 score ^^^ Coo thank for ur suggestions and Insight I'll start doin a lil more research on what I should get. Can u still get these other journal bearing turbos in a twin scroll hotside?
![]() | | #1028 | ![]() |
Groans: 31
. I know the stock turbo is journal...it's also not big. When you start talking about 400whp, you're gonna have to go up a couple sizes. Considering he's probably only going to rev to 7k, he needs something that will spool soon enough to give him a decent powerband. I agree the 60-1 would be great, but there would definitely be noticeable lag compared to a similar BB turbo. | |
![]() | | #1029 | ![]() |
| Not Ranked : 0 score Thx for the suggestions on the turbos. The 60-1 is a good choice and a shit load cheaper. Still comes with the option of a .78 A/R t3 divided so twin scroll Is still a go!!!
![]() | | #1030 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
check this place out as this is where i got the gt3582 from for a customer that i am building his car and i chose the .82 a/r housing with no additional cost!!!! http://www.extremepsi.com/store/cust...e.php?cat=1119
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport | |
| The Following 2 Users Say Thank You to qtrmile beast For This Useful Post: | djuosnteisn (01-02-2011), jracer (01-03-2011) |
![]() | | #1031 | ![]() |
| Not Ranked : 0 score I'm not goin tht big of a turbo. I'm tryin to save money not waste it becuz not a powa chaser.
![]() | | #1032 | ![]() |
Groans: 79
(Thread Starter) | Neutral : -1 score
JK, yeah, i plan on modding the stock oil feed and oil return lines, and i can supply the proper lengths of SS tubing as well (I'll have to charge you what the local shop charges, but they're pretty reasonable). I won't be including any of the oil restrictors, etc, just the lines essentially. And the lengths are yet to be determined. I'll know once we install a turbo on one of these manifolds.... hopefully in the very near future. But if i had to guess, it'd be between 14" & 18". I honestly don't know yet. For coolant lines, some will need a bypass, and others will simply need extensions. I honestly think this would be as simple as ordering some nice coolant hose and just swapping it out. For the MS6, the coolant hose to the transfer case switches sizes (oem hose is larger on one side than the other), so the people would have to buy a barb nipple and just hook the new line to that. I can post pics if needed.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | bmylez (01-02-2011), doubleflusher (01-02-2011), MS3-a(sore)ASS-rex (01-02-2011), turd burglar (01-02-2011), xdm88 (01-03-2011) |
![]() | | #1033 | ![]() |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
Before ordering from there shoot me a PM with what you're looking for and I'll see if I can hook you up.
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA | |
| The Following 5 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: | djuosnteisn (01-02-2011), doubleflusher (01-02-2011), kilik2 (01-02-2011), qtrmile beast (01-05-2011), xdm88 (01-03-2011) |
![]() | | #1034 | ![]() |
Groans: 31
| Not Ranked : 0 score Yeah, charge me for the lines! Just trying to get this thing as bolt-on as possible. What's holding you back from installing a turbo? Is that MS3 guy hard to get a hold of? |
| The Following User Says Thank You to bmylez For This Useful Post: | djuosnteisn (01-03-2011) |
![]() | | #1035 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score Na, he's easy to get a hold of. I just want to finish the 6 kit first.... so i can button up my whip and free up a spot in the garage for the 3. It's colder than a witch's titty here.... and i'll be damned if i'm gonna work outside doing this stuff lol. I'm actually gonna see if i can borrow his car for a few days if necessary... maybe i'll let him borrow my wrx or something.... And drive the ms6 to and fro work.
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | bmylez (01-03-2011), Docnox (01-07-2011), MS3-a(sore)ASS-rex (01-03-2011), turd burglar (01-03-2011), xdm88 (01-03-2011) |
![]() | | #1036 | ![]() |
Groans: 31
| Not Ranked : 0 score I would gladly accept a WRX as a loaner car if you were fitting a sick azz top mount kit on my ride, haha. |
![]() | | #1037 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score lol... only rule on the wrx is no WOT though...... it'll break.... no where near as tough as the speeds.
![]() | | #1038 | ![]() |
Groans: 31
| Not Ranked : 0 score What year? I know the '02 - '05s had transmission problems, among other things, right? Why not trade it in for somethin tougher/more economical/etc? |
![]() | | #1039 | ![]() |
Groans: 79
(Thread Starter) | Not Ranked : 0 score 2002. bug eye. I actually sold my jeep cherokee for it. I just love the look and sound of it, and the gas mileage is way better than my jeep. So it basically was my more economical purchase lol. I snow board a lot in the winter, so i'm usually driving like 3-3.5 hours to resorts in CO. Figured the subaru was a perfect fit (and it is actaully). Once i finally get my mazda pretty much finished, i'll probably save up and pull the trigger on the wrx. 6 speed swap and 2.5 liter... fitted with a fun turbo.... Maybe shoot for like 450 with it (where my 6 used to be). It'll then be bullet proof and still fairly economical. I just have to save up a lot, cause those 6 speeds ain't cheap. Going rate is like $4k or so.
![]() | | #1040 | ![]() |
Groans: 31
| Not Ranked : 0 score I guess you must REALLY love the look because you can find '04 STIs for $16k...much cheaper than all the work you're talkin about. Also...I didn't know the stock EJ25 could take 450. Most people stop at 400 from what I've seen. |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f498/top-mount-turbo-setups-61011/ | ||||
| Bosch 3 Bar MAP - ATR values | This thread | Refback | 04-05-2012 07:59 PM | |
| Mazda MPS Owners Club • View topic - New Turbo me thinks ! | This thread | Refback | 03-20-2011 03:57 PM | |
| Gauge setups | TheNewGuy | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 03-14-2011 06:56 PM |
| Top Mount Turbo Manifold | aminzer | Mazdaspeed3/6 General Discussion | 25 | 02-06-2010 08:19 PM |
| AP & Forge setups. | 08cosmic3 | Cobb Access Port/Maps | 0 | 08-08-2009 06:52 PM |
| TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! | Raider | Mazdaspeed Forums User Reviews | 0 | 06-29-2009 06:40 AM |
