Go Back   Mazdaspeed Forums > Mazdaspeed Forums Sponsors > CorkSport
CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best.
 Old 05-15-2019, 12:45 PM   #1
san1234's Avatar
Posts: 20   (View Stats)
san1234 is an unknown quantity at this point
Default CS Turbo preload
I am needing to adjust the preload on my CST4 turbo, while it's on the car. . . What is the easiest way to get at it, would it be from underneath the car or from the top? Thanks.
san1234 is offline   Reply With Quote
 Old 05-17-2019, 04:13 PM   #2
Fstrnyou's Avatar
Posts: 2,457   (View Stats)
I adjust mine from the top. You can get it done with two 10mm combo wrenches.
If you don't mind me asking, why are you adjusting it?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-17-2019, 06:11 PM   #3
san1234's Avatar
Sure, my tuner said it's not building enough PSIs and I need to increase the preload on the wastegate.
 Old 05-18-2019, 06:13 AM   #4
Fstrnyou's Avatar
My preload is factory set and I can get 28psi. What boost are you aiming for? Lol.
Other rides:
History:
 Old 05-18-2019, 06:19 AM   #5
Police - Grammarhead
Vansquish's Avatar
Groans: 1,896
Define, "not enough PSIs". What boost pressure are you targeting? Are you sure that everything is buttoned up properly and that you don't have a leak somewhere in the system?
 Old 05-18-2019, 12:22 PM   #6
san1234's Avatar
I'm getting 19.5 psi, looking for more than that.
 Old 05-18-2019, 12:43 PM   #7
Fstrnyou's Avatar
Hell, my boost creeps to almost that with 0% WGDC.
Other rides:
History:
 Old 05-18-2019, 01:00 PM   #8
san1234's Avatar
Ive triple checked all my connections, no leak
 Old Yesterday, 12:18 PM   #9
pacunning's Avatar
Posts: 3   (View Stats)
pacunning is an unknown quantity at this point
Bump, did you get this resolved? I’m also having issues, I’m at 80%WGDC and only able to hit 24.5 psi. Checked 2 times for boost leaks, none found. I feel kinda odd adjusting the preload to be honest. I have a CS EBCS set up in bleed mode and CSt4
pacunning is offline   Reply With Quote
 Old Yesterday, 12:41 PM   #10
san1234's Avatar
No not really, I adjusted preload. You can get to it feom the top of engine. I did find a small boost leak that helped some.
 Old Yesterday, 02:55 PM   #11
Fstrnyou's Avatar
Change your setup to 3-port interrupt instead of 2-port bleed.
Other rides:
History:
« Gen 1 MS3 Crashbar | - »
MS6 AWD trans bearings / preload question Boltz MazdaSpeed 6 - Engine, Transmission & Driveline 15 01-25-2014 03:25 AM
Adjusting preload IWG shawn. MazdaSpeed 3/6 - Big Turbo Builds 7 08-05-2013 08:02 AM
Adjusting WG spring preload on turbo? p057 MazdaSpeed 3/6 - Turbo Induction 10 10-30-2012 04:55 PM
Page generated in 0.36526 seconds with 23 queries
