 Old 12-07-2017, 02:59 PM   #1
lreyes66's Avatar
Posts: 133   (View Stats)
lreyes66 is a jewel in the roughlreyes66 is a jewel in the roughlreyes66 is a jewel in the rough
Groaned at 14 Times in 2 Posts
Default 08 MS3 moisture in the passenger headlight
After almost 10 years of ownership, my MS3 is starting to show signs of aging and one of those things is condensation in the passenger headlight. I have never witnessed moisture in the headlight until yesterday morning. It eventually dried out at the end of the day yesterday and was hoping it was one of those happen once then not have it happen again but it did happen today again. Its been raining and cold recently in houston.
Its only moisture and no puddles.
I checked all low / high beam lights and their rubber seals and dont really notice anything wrong. Then i decided to check what i think is the seal and most of it looked ok except a certain portion on the top.
Is this a bad seal? If so, is the only way to fix it is to do the oven method? The first thing i thought of in the moment was maybe using flex seal but obviously it not going to be that easy... right?
lreyes66 is offline   Reply With Quote
 Old 12-10-2017, 07:40 PM   #2
Smallville's Avatar
Posts: 30   (View Stats)
Smallville has a spectacular aura aboutSmallville has a spectacular aura about
I have an '08 with the same problem. The improper way is to apply some sort of clear drying silicone around the headlight seals. In your case you can just apply some around that problem spot and see if that fixes it. Or as you mentioned, the technically correct oven method. Either way get it done sooner than later before the moisture shorts out your headlights. On GT models getting those lights replaced is $$$.
Smallville is offline   Reply With Quote
 Old 12-12-2017, 07:36 AM   #3
darkmx-6's Avatar
Posts: 82   (View Stats)
darkmx-6 is a jewel in the roughdarkmx-6 is a jewel in the roughdarkmx-6 is a jewel in the rough
Mine was leaking and it burnt up my hid ballast, do it sooner rather than later. Those ballast cost $450 from the dealer. I found it on ebay for $40-50 new.
Besides the oven baking method you can also use a heat gun. That's how we did mine. heat guns are under $10 at Harbor Freight
Here is a quote from my build thread.
Originally Posted by darkmx-6 View Post
I mentioned that this part burned out on me because my headlight was leaking and a heavy rainstorm came and got water inside of it.
I replaced it with this one by searching by the part # in the bottom right. That helped me find one so much cheaper and on top of that it was new.
My cousin and I also resealed it the headlight with red silicone. Which you can barely see when the hood is closed. If I was to do it again I would use grey clear or black. It took forever to take out the old sealer!
Last edited by darkmx-6; 12-12-2017 at 07:36 AM. Reason: MSF Database - Automerged Doublepost
darkmx-6 is offline   Reply With Quote
HTML code is On
Moisture in Headlight marco427 Gen2 MS3 General Discussion 3 03-24-2015 12:42 PM
15k and right headlight has moisture inside? MrTeddyChills Exterior 9 05-08-2012 09:05 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Page generated in 0.23094 seconds with 22 queries
