 Old 08-12-2019, 02:37 PM   #1
sfapsey's Avatar
Posts: 2   (View Stats)
sfapsey is an unknown quantity at this point
Default 2008 Mazdaspeed3 gearbox
Hello,
Just joined the forum as i am considering purchasing a 2008 Mazdaspeed 3 with 95k miles. No mods that the seller has disclosed. The car drives well and looks to have been maintained well enough. My concern is the gearbox. This is the only Mazdaspeed 3 i have driven and its difficult to tell when you are shifting in reverse or first gear. Normally there is a "bump" of some sort in the gear box so you dont accidentally shift in 1st. Is this normal? Could this be a short shift upgrade?
Thanks in advance.
sfapsey is offline   Reply With Quote
 Old 08-12-2019, 03:22 PM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
There is a reverse lockout. You should have to push the knob down before you can engage reverse.
 Old 08-12-2019, 04:48 PM   #3
sfapsey's Avatar
Thanks. This car definitely has a worn lockout. Is it normal for it to wear out? Anyone replace the lockout mechanism?
 Old 08-12-2019, 05:15 PM   #4
Db09ms3's Avatar
Posts: 508   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 97
Good news! JBR makes a fix for this! Scope them out and the best part is it's cheap.
Stockish
 Old 08-13-2019, 07:51 AM   #5
Vansquish's Avatar
Groans: 1,906
The JBR part may be the solution, but it actually sounds like the return spring may just be weak.
http://www.jamesbaroneracing.com/sho...roducts_id=758
HTML code is On
2008 Mazdaspeed3 mstvartak MazdaSpeed 3/6 - Build Diaries 1 07-31-2012 08:42 AM
Page generated in 0.25635 seconds with 22 queries
