 Old 06-15-2011, 05:21 AM   #1
252stayfly's Avatar
Posts: 14   (View Stats)
252stayfly is an unknown quantity at this point
Default 3 Weeks after OCC Install, P2187 OBDII Code
I installed my OCC 3 or 4 weeks ago, and now my CEL is on. I used a OBDII tool and it said there was a P2187/P2187PD code. Any suggestions where to start troubleshooting?
252stayfly is offline   Reply With Quote
 Old 06-15-2011, 05:25 AM   #2
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
"CHECK ENGINE CODE P2187 SAYS SYSTEM TOO LEAN AT IDLE BANK 1"
Thats what i found via google
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline   Reply With Quote
 Old 06-15-2011, 05:34 AM   #3
252stayfly's Avatar
I saw that but I do not know what it means? Not sure where to start on that.....
 Old 06-15-2011, 05:36 AM   #4
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
you have unmetered air entering the engine, something is loose. go over all your connections and make sure they are tight
btw this is the most common code. search does wonders
 Old 06-15-2011, 06:11 AM   #5
Walkman's Avatar
Posts: 247   (View Stats)
Walkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the world
Also donate you brownie, and find and use Google and search buttons. do not ask question that already have answers.
PS Donate you brownie Fuck
Walkman is offline   Reply With Quote
 Old 06-15-2011, 06:20 AM   #6
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,162   (View Stats)
Groans: 792
The line, "I don't know what that means." referring to lean at idle, means you guys are wasting your breath.
"Exclusivity" - CP-enis
Demodded.
The Seals
WetzMS3 (09-29-2014)
 Old 06-15-2011, 07:47 AM   #7
252stayfly's Avatar
I have googled, and read some older posts. Some of the common issues are with the purge valve getting stuck open. Is there an easy way to test to see if this is the issue, I know replacing it would, but other than that?
 Old 06-15-2011, 11:19 AM   #8
Walkman's Avatar
See above post.
 Old 06-15-2011, 11:34 AM   #9
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Mazdaspeed Forums - Search Results
 Old 06-15-2011, 01:07 PM   #10
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
dude, your shit is so fucked.
it's fun to do bad things
The Following 5 Users Say Thank You to jack_hammer For This Useful Post:
Ckmazdaspeed3 (08-03-2011), helmetface (08-03-2011), PunjabiPlaya (07-30-2011), Raider (06-15-2011), WetzMS3 (09-29-2014)
 Old 06-15-2011, 01:25 PM   #11
Posts: 9,484   (View Stats)
Start with what you changed. Common sense troubleshooting 101
It's not your purge sol it's the lines to the OCC, PCV valve or the can itself.
Good hunting.
 Old 06-16-2011, 10:59 AM   #12
252stayfly's Avatar
Thank you for the SERIOUS responses... Issue resolved.... pcv valve
 Old 07-30-2011, 12:56 PM   #13
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
HOw'd you know it was the pcv? How'd it get fixed?
bzwyatt is offline   Reply With Quote
 Old 07-30-2011, 03:48 PM   #14
Groans: 549
yay!
 Old 08-03-2011, 04:38 AM   #15
252stayfly's Avatar
It was the last thing that I had messed with. The OCC and the pcv valve.
 Old 08-03-2011, 04:41 AM   #16
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
This thread is lol
The Following User Says Thank You to helmetface For This Useful Post:
Mochi (09-29-2014)
 Old 08-03-2011, 11:44 AM   #17
HLR Element's Avatar
Posts: 2,477   (View Stats)
HLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the world
Groans: 109
was going to say if you didn't figure it out yet, it's the pcv valve. i had that hose fall of like 3 times on me. Do you have the longer pcv valve matt damond has? i forget what it was actually... the better one to prevent leaks or back pressure or some crap. I know the old one he had was short and the hose would never stay on long because it couldn't get a good grip.
Mk7 GTI
HLR Element is offline   Reply With Quote
 Old 08-03-2011, 12:32 PM   #18
wankular's Avatar
Posts: 4,343   (View Stats)
Okay, in an attempt to jack this thread, I just did my OCC and my fuel trims are 14%. But ONLY above 2.4 MAF volts. They fluctuate between -0.8% -> +5% and then when I hit 2.4 V they jump to 14.1%. If it was a leak wouldn't it leak constantly?
I reset my ecu but after 25 miles it still did it. Should I wait until more miles?
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
rfinkle2 (08-03-2011)
 Old 08-03-2011, 12:42 PM   #19
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Are you monitoring with a Dashhawk?
I wouldn't doubt that your old pcv valve was clogged, and now your trims are showing.
wankular (08-03-2011)
 Old 08-03-2011, 12:56 PM   #20
wankular's Avatar
Yes, DashHawk. My car only has 10k, the pcv can be clogged in that short a time?
Last night I zero'd out the MAF table in my SB so I can start adjusting them from scratch again.
2009 MS3 sport MGM
 Old 08-03-2011, 01:04 PM   #21
rfinkle2's Avatar
Groans: 298
I don't know about 10k as far as completely clogging, but maybe enough to affect trims.
 Old 09-29-2014, 10:11 AM   #22
RE7
RE7's Avatar
Posts: 1   (View Stats)
RE7 is an unknown quantity at this point
I had 2187 and 0455 codes that I repeatedly cleared and they returned within 20 miles. I bought the Dorman 911-702 replacement purge valve, checked the hose (clear) and CEL is now clear for 10+miles.
RE7 is offline   Reply With Quote
 Old 09-29-2014, 12:49 PM   #23
Groans: 549
your first post ever after being a member for 5 years, and it's to bump a 3 yr old thread? awesome.
The Following 6 Users Say Thank You to jack_hammer For This Useful Post:
CrawlingMS3 (09-29-2014), danmillerok (09-29-2014), Gunslinger (10-03-2014), Mochi (09-29-2014), Raider (09-29-2014), Snip (09-29-2014)
HTML code is On
Intermittent P2187 Code after K&N Filter Install aintitthelife98 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 09-11-2012 12:26 PM
Ok more than P2187 code miatabert MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 06-20-2011 08:24 AM
ELM 327 USB OBDII Zai_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 06-02-2011 03:25 AM
Lean Idle After FMIC Install CODE P2187 Sphincter MazdaSpeed 3/6 - Turbo Induction 10 07-30-2009 12:11 PM
OBDII CONNECTORS bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 5 07-10-2008 03:27 PM
Page generated in 0.41670 seconds with 33 queries
