 Old 03-02-2019, 06:13 AM   #1
danb's Avatar
Posts: 158   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
Default airbox interchangeable between the gens
Has anyone used a gen 1 airbox in a gen2? I have a friend wanting to go back to stock and needs the airbox.
I found 1 mention that theyll work but in the post the op said he was buying the filter and its the same filter number. Google pics looks like there are slight differences
Thank you for any info you can provide!!
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 03-02-2019, 08:35 AM   #2
danb's Avatar
I found this site. https://www.oemautopartz.com/mazda/
They dont match, someone thought they might but... anyone have a stock setup they wanna sell? He needs everything from the airbox to turbo
2011 mazda 6
 Old 03-02-2019, 05:34 PM   #3
MSMS3's Avatar
Posts: 2,393   (View Stats)
Groans: 135
Post is confusing. It helps if you are clearer. Which gen is your friend's car?
2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 430 hp.
HTML code is On
Suspension between gens DevilSpeed MazdaSpeed 3/6 - Suspension & Brakes 8 02-04-2014 04:41 PM
OBB MAZDASPEED3 Airbox Kits and SF Intake + Airbox Combos Cobb Tuning Mazdaspeed3/6 General Discussion 17 12-25-2013 03:33 PM
COBB MAZDASPEED3 Airbox Kits and SF Intake + Airbox Combos Cobb Tuning Gen2 MS3 General Discussion 58 11-11-2012 09:42 AM
diffenece in gens. swerv0428 Gen2 MS3 General Discussion 9 10-11-2012 10:30 AM
Page generated in 0.25169 seconds with 21 queries
