Notices
 Old 04-28-2012, 02:40 PM   #1
SwineFLU's Avatar
Posts: 175   (View Stats)
SwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the worldSwineFLU is the leader of the world
Default Anyone else get water build up in trunk?
It's the second time I notice water building up where the jack goes... the rest of the trunk is dry... anyone else had this happen or can shed some light on this?
I did try to search but nothing came up specifically for the MS6
2007 MS6, COBB AP, SU RMM, TT DIF MOUNT, COBB SRI/TIP, AUTOTECH
To be installed: CX racing FMIC, CS DP, TWM shifter, Oil catch can
SwineFLU is offline   Reply With Quote
 Old 04-28-2012, 02:44 PM   #2
xtasy's Avatar
Posts: 593   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groans: 98
Groaned at 6 Times in 4 Posts
I think there are threads about this topic. But yes there are water In my spare tire area
Cobb SRI Cobb TIP Cobb AP CXRacing FMIC PGV3 Exhaust Manifold, CNT DP TurboXS CBE JBR Motor Mounts
Tuned by Phate
JBR Rear Sway Bar
H&R Coilover
SPC Camber Arm
Enkei NT-03
Upcoming Mods: BNR S3, JBR Whale Penis, Treadstone IC Core, PNP IM.
xtasy is offline   Reply With Quote
 Old 04-28-2012, 02:47 PM   #3
I<3Groceries's Avatar
Posts: 1,851   (View Stats)
Groaned at 25 Times in 20 Posts
Yes this isn't uncommon. There have been threads about this that predate MSF, found on 6club. It is not necessarily uncommon. I haven't had this issue, however.
The Following User Says Thank You to I<3Groceries For This Useful Post:
SwineFLU (04-28-2012)
 Old 04-28-2012, 05:42 PM   #4
memin's Avatar
Posts: 819   (View Stats)
Groaned at 29 Times in 17 Posts
i get a lot of water behind the driver seat when rains , but it only happens sometimes. i cannot find where is coming from???????
memin is online now   Reply With Quote
The Following User Says Thank You to memin For This Useful Post:
Angr-E1 (04-28-2012)
 Old 04-28-2012, 07:11 PM   #5
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
i had the same problem with the trunk i replaced the weather strip with a new one and no more water. the old one was the original and looked fine. no tears but was a little flat compared to the new one. also i replace the trunk struts as the they were starting to poorly hold up the trunk.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
The Following User Says Thank You to 671 grains of reason For This Useful Post:
SwineFLU (04-29-2012)
HTML code is On
COMPARISON: Labonte Stage 2 Water/Meth Kit vs. AEM Water/Meth Kit The Great NY Mazdaspeed Forums User Reviews 1 01-19-2013 07:48 AM
ms6 water in trunk maddocx240 Mazdaspeed3/6 General Discussion 6 01-18-2012 07:05 AM
Importance of Water Cooling on Water-Cooled Cener Sections XRJoe MazdaSpeed 3/6 - Big Turbo Builds 1 09-20-2011 01:17 PM
Page generated in 0.29668 seconds with 24 queries
