Notices
 Old 06-27-2012, 08:29 PM   #41
708
Erich's Avatar
Groaned at 26 Times in 22 Posts
Preferred method for venting seems to be a rod through the block. Very popular on this site.
I run the stock location (using a block off plate) to an exhaust venturi and then the valve cover to the intake manifold.
I'm doing it wrong, just ask all the other Mazda DISIs making 700+HP
Erich is offline   Reply With Quote
The Following 5 Users Say Thank You to Erich For This Useful Post:
BigRedSpecial (06-27-2012), Easter Bunny (08-03-2012), Fobio (06-27-2012), helmetface (08-22-2012), TWOptSL0W (08-22-2012)
 Old 06-27-2012, 08:54 PM   #42
Speeeeeed
06Speed6's Avatar
Posts: 5,726   (View Stats)
I have tried both krankvents and a stainless mcmaster valve and both worked great, I am with others that dipstick probs are boost leaking to the cc.
I need to finish my cc vent/venturi setup, its seriously sweet. Thanks for reminding me.
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
 Old 08-03-2012, 06:51 AM   #43
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 409
Groaned at 205 Times in 121 Posts
Are these the check valves from McMaster? McMaster-Carr
Also, I see SilverDemon recommending a check valve between OCC and PCV.....is there a need for a check valve after the OCC between it and the venturi?
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is offline   Reply With Quote
 Old 08-03-2012, 08:10 AM   #44
SilverDemon's Avatar
Posts: 2,612   (View Stats)
Yes, potential back fire might not be the greatest for the catch can.
Worlds First Port Fuel Injected MazdaSpeed 3
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 2 Users Say Thank You to SilverDemon For This Useful Post:
06Speed6 (08-04-2012), BigjohnB20 (08-03-2012)
 Old 08-03-2012, 08:28 AM   #45
Will fuck up ur day
chimmike's Avatar
Groans: 409
Exprosion in catch can from fuel/oil vapors, hahaha.
Now which McMaster check valve? the "stainless steel" ones? Good Christ those are expensive. None in 5/8" either.
07 MS3 bone stock?
GTX3076r
 Old 08-03-2012, 09:16 AM   #46
SSinstaller's Avatar
Posts: 3,619   (View Stats)
Groans: 46
Groaned at 16 Times in 11 Posts
You want check valve 7775k54, and fittings 5346k66.
The Following 4 Users Say Thank You to SSinstaller For This Useful Post:
bcmurphy87 (08-21-2012), chimmike (08-03-2012), helmetface (08-22-2012), radbrad (08-22-2012)
 Old 08-03-2012, 12:08 PM   #47
chuckms6's Avatar
Posts: 1,375   (View Stats)
Groaned at 8 Times in 5 Posts
The vw 1.8t uses a port on the turbo inlet pipe to provide vacuum under boost and a system of check valves to control airflow. I simplified mine and connected to the tip fulltime since all three houses were cracking anyway. I was thinking our system used a method similar to this but I see now i'm wrong lol.
My method would be to cap the intake manifold port and install a check valve in the hose on the valve cover so air only flows from the intake to the valve cover and blocks airflow the other way. From the stock PCV go to the OCC then to a port on the TIP preferably close to the turbo for max vacuum.
An alternative would be to cap the valve cover so the system is always under vacuum. That would be favorable IMO.
Tapatalking
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
chuckms6 is online now   Reply With Quote
 Old 08-03-2012, 03:20 PM   #48
Evan@COBB's Avatar
Posts: 160   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
I have the stock PCV system with a MD OCC installed. Only difference is that I moved the valve cover vent much closer to the turbo with as big a line I could fit to it and I opened up the holes that the air travels through in the valve cover baffle an extra 0.020" or so, whatever seemed like the biggest I could go before the walls got too thin.
No problems at all.
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else
Evan@COBB is offline   Reply With Quote
 Old 08-03-2012, 05:15 PM   #49
crazyp's Avatar
Posts: 1,045   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 64
Groaned at 22 Times in 9 Posts
No problems at all.
how much boost are you running though? unless its more than 26 psi it doesn't really help the convo. I only blow out my dipstick above that, as well as others it seems......
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RMM and RDM, Turbine tech FDM and FMM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
 Old 08-03-2012, 05:50 PM   #50
PapaSmurf's Avatar
Posts: 6,274   (View Stats)
Groans: 89
Groaned at 56 Times in 30 Posts
My threshold was 27psi... Once I went above that it was dip stick shooting territory. I'm good now since I modified my pcv box
Sent from my flying tapadildo
Twinscroll GT3582R
PERM Tuned/Built Genpu Dragon
565whp/543wtq corrected at 5500ft asl
476whp/458wtq uncorrected at 5500ft asl
PapaSmurf is online now   Reply With Quote
The Following 2 Users Say Thank You to PapaSmurf For This Useful Post:
crazyp (08-03-2012), Dano (08-03-2012)
 Old 08-03-2012, 06:43 PM   #51
30+ psi
without poppage
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
crazyp (08-03-2012)
 Old 08-03-2012, 06:46 PM   #52
BigjohnB20's Avatar
Posts: 685   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
This is essentially how the Krankvents are set up to work except they allow venting of blow by gases under load. A check valve on the valve cover to TIP is open under vac (high load) and closed under low load (vac in intake manifold, simulating the cap'd VC). Then another check valve before the PVC is opposite, so closed under high load and open under low load (vac in IM). I have been running half the KVs for quite some time now. I don't have the PVC side installed, but I am on K04 so I don't have to worry about blowing the Dipstick. What I do have is a constant vac in the CC and have never once seen my turbo smoke in 40K miles.
Do you guys that are blowing the dipstick have an additional check valve before the PVC. If you do all that pressure is coming from blow by which probably isn't very good. If not, it likely means the PCV is leaking boost and pressuring the CC.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
 Old 08-03-2012, 06:56 PM   #53
crazyp's Avatar
Groans: 64
with the OCC kits we have they pretty much all come with check valves.
I'm good with 25 psi on stock block anyway. When I build the motor then I'll worry about fixing this issue.
 Old 08-04-2012, 02:34 AM   #54
Speeeeeed
06Speed6's Avatar
I think I have the 4620k84 check valve, but the crack pressure seems high I remember mine being between .3 and .5psi to open. You dont want too much pressure to open because that pressure will be in the cc which defeats the purpose.
2006 Mazdaspeed 6
 Old 08-22-2012, 03:04 PM   #55
Groans: 46
IIRC it takes at least 1 psi to open the high pressure check valves. That was one of the reasons I went with the quick opening brass valve, the other being the $150 price difference between the SS and the brass valves..
 Old 08-22-2012, 07:44 PM   #56
bcmurphy87's Avatar
Posts: 1,293   (View Stats)
bcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the world
How much hose are you guys using to get the exhaust Venturi to the catch can?
I only have a 2 port catch can but I'm gonna put a T into the line going to the intake manifold and hook the Venturi line into there.
Can I get away with using the 5/8s heater hose from autozone?
06 Speed 6- Built, working on a PERM tune.
In progress dyno 476/410
just bang out the tight spots.
bcmurphy87 is offline   Reply With Quote
 Old 08-22-2012, 08:10 PM   #57
-10 pushlock hose from jegs is what I use.
it is oil resistant, I am not sure the coolant hose has the same rating. You might check it out before you buy. 10 feet should be enough.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-23-2012, 08:39 AM   #58
bcmurphy87's Avatar
What about his hose? it says its cleared for fluid transfer and vaccum applications?
Shop Watts 5/8" ID PVC Reinforced Braided Vinyl Tubing at Lowes.com
 Old 08-23-2012, 08:55 AM   #59
I can't see the link on my phone, just make sure it is compatable with motor oil.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-23-2012, 09:02 AM   #60
Posts: 7,988   (View Stats)
Groans: 34
FWIW I have been running that exact tubing on my OCC for 4 years...I however would not recommend it. it gets very brittle/hard over time and the clamps will not hold tight. When I recently pulled my IM the entire front of my motor and all the fittings were covered in oily residue due to the hose getting brittle and clamps not holding tight against the barbs. I would imagine it was causing a slight vacuum leak as well.
I need to replace mine soon with something more pliable.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
Dano is online now   Reply With Quote
 Old 08-23-2012, 09:14 AM   #61
bcmurphy87's Avatar
I found this and i think its a winner!!
NAPA AUTO PARTS
 Old 08-23-2012, 11:55 AM   #62
Groans: 34
does the store tell it by the foot? The PDF says available in 50' or 300' rolls.
Also they don't mention if it is vacuum resist but I suppose if it can handle pressure it can handle vacuum...someone that knows chime in pls.
PERM
bcmurphy87 (08-23-2012)
 Old 08-23-2012, 01:43 PM   #63
bcmurphy87's Avatar
yea its 4.99 a foot
 Old 08-26-2012, 09:32 PM   #64
11cruzito11's Avatar
Posts: 816   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
You need two fittings for the check valve, right?
Cobb AP, 504whp 492wtq
11cruzito11 is offline   Reply With Quote
 Old 08-27-2012, 01:27 PM   #65
Groans: 46
Yes
11cruzito11 (08-27-2012)
HTML code is On
K04 Leaking boost to crankcase!? rob ms6gt MazdaSpeed 3/6 - Turbo Induction 5 06-04-2012 02:40 PM
CrankCase Evacuation System SilverDemon MazdaSpeed 3 - How-To's 402 01-29-2012 02:16 PM
Negative Crankcase Pressure kore2000 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-16-2010 06:56 AM
From Cow to Crankcase: Synthetic oil from animal fat Haltech Automotive News 0 12-03-2008 02:50 PM
Page generated in 0.49170 seconds with 32 queries
