Notices
 Old 10-17-2012, 03:23 PM   #1
mig02's Avatar
Posts: 48   (View Stats)
mig02 is a jewel in the roughmig02 is a jewel in the roughmig02 is a jewel in the rough
Default cant hit more than 9 psi need help
i drove around 40 miles on the stock stage 0 map because im going to the dealer soon and i did some wot runs for fun and couldnt even hit 9 psi take a look a my log somethings wrong ?
mig02 is online now   Reply With Quote
 Old 10-17-2012, 03:24 PM   #2
Able
helmetface's Avatar
Posts: 4,423   (View Stats)
Groans: 125
kael tsoob
helmetface is online now   Reply With Quote
The Following 8 Users Say Thank You to helmetface For This Useful Post:
cbspd3flip (10-17-2012), chimmike (10-17-2012), Easter Bunny (10-18-2012), LatinKraze (10-17-2012), silentwolf8 (10-17-2012), silvapain (10-18-2012), smoogs12 (10-18-2012), whos_MS3 (10-17-2012)
 Old 10-17-2012, 03:26 PM   #3
Mortose's Avatar
Posts: 1,631   (View Stats)
Mortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the world
Groans: 30
inb4 "you guys are mean"
2008.5 Metropolitan Grey Mica
GTX2867r--Cobb AccessPort--CNT Racing Catted DP & Catback Exhaust--Autotech Internals--NGK 1 Step Colder--PTP Injector seals/studs--Sure TIG (Intake Mani)--HTP 3" intake--Grimspeed EBCS--JBR OCC (V2)--TWM STS/Solid Base Bushings--JBR LTD Silver Vein Heavy Knob--JBR 80 duro trillogy--Synapse BPV--Synapse FMIC--Koni Yellow's--H&R springs--JBR Rear Sway Bar
getting re-Stratified
KO4 - 360 whp/426 wtq Corrected 6600 ASL
GTX2867r - we will see.......
TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat"
Mortose is online now   Reply With Quote
The Following User Says Thank You to Mortose For This Useful Post:
 Old 10-17-2012, 03:32 PM   #4
mig02's Avatar
what ?
 Old 10-17-2012, 03:37 PM   #5
dale_gribble's Avatar
Posts: 1,048   (View Stats)
Groaned at 7 Times in 4 Posts
Look between 12.23-13.85 seconds.
Your accelerator position is reporting 99% (WOT) but your throttle position sensor is reporting 23-25% for the same time. It should be reporting ~75% when your accelerator position is reporting 99%. That would cause a problem. Maybe you have a bad accelerator sensor. That would really screw things up since boost is based on Accelerator Pedal Position, along with many other things.
Are you sure you didn't load the wrong map? Like a valet map or something?
Why are you going to the dealer? Are you saying the car was fine and you just happen to be taking it to the dealer? Or the car had a problem and you are taking it in for repair? What mods do you have
If your car was fine before, I would uninstall the AP, reload the map onto your AP, and reinstall the AP on your car and reinstall the map.
Typically when people ask for help, they give more back story, mods, etc. than just a log that we are supposed to make suggestions on...
dale_gribble is online now   Reply With Quote
 Old 10-17-2012, 03:46 PM   #6
mig02's Avatar
im going to the dealer for suspension repairs under warranty... thats why i loaded the stock map, everything was fine with my v210 stage 1 map for k&n
also this morning i noticed that after the car was turned off if i would press the gas pedal i would hear a squeaking noise from the engine bay for like the first five pedal push
Last edited by mig02; 10-17-2012 at 03:46 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-17-2012, 03:52 PM   #7
Assuming your car was fine before the map change, I would uninstall the AP from your car, disconnect the battery for 30 mins, reconnect the battery and then reinstall the AP. Don't load any maps and you will be at your Stage 0 map by default. See if the problem persists.
 Old 10-17-2012, 03:52 PM   #8
mig02's Avatar
and is the accelartor pedal position suppose to be the same has the throttle position ?
 Old 10-17-2012, 03:56 PM   #9
No; when a car is working how it should @ WOT the TPS will report about 75% while the accelerator position sensor reports 99%. There is some scale factor there; it isn't 1:1.
 Old 10-17-2012, 04:00 PM   #10
mig02's Avatar
thanks dale_gribble for your help it could be the cold weather affecting my accelerator pedal sensor ill check on that
 Old 10-17-2012, 04:18 PM   #11
mig02's Avatar
Weird thing is when im in neutral i get 75 throttle position
 Old 10-17-2012, 04:24 PM   #12
jm211's Avatar
Posts: 302   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Did you reset?
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified Tune | JBR Stage II Intake | cp-e 3'' Straight Exhaust | cp-e RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Amsoil Fluids | NKG Step 1 | Autotech Internals | Shell T6 Juice
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 10-17-2012, 04:24 PM   #13
I am telling you, uninstall AP, and reinstall. Things can get squirrely sometimes when loading maps. I had a boost flutter problem that went away with an AP uninstall and map reload.
 Old 10-17-2012, 04:44 PM   #14
mig02's Avatar
i just uninstalled the ap and i could feel the huge difference in power so i guess the map was the problem just like you guys said! ill check the map on atr for fun
 Old 10-17-2012, 04:48 PM   #15
It's worth donating to take full advantage of the website. I don't mind helping brownies up to a certain point and this is that point. Glad it worked out. Donate.
 Old 10-17-2012, 04:50 PM   #16
cbspd3flip's Avatar
Posts: 807   (View Stats)
cbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the world
Groans: 288
Groaned at 8 Times in 7 Posts
I had an issue before with Cobb's ots where my I would be 99% APP and would only build 12psi or so. Changed the map and it went back to normal.
2010 BMW M3 Coupe
Lowered - Brand unknown.
Exhaust - X-pipe/Axle back Brand unknown.
Rennen Forged with 255/30zr20 on front and 315/25zr20 on rear.
cbspd3flip is offline   Reply With Quote
 Old 10-17-2012, 07:14 PM   #17
mig02's Avatar
How much is a normal donation
 Old 10-17-2012, 09:17 PM   #18
I think $25. It gets you access to classifieds, shop manuals and a bunch of cool stuff.
2006 MS6 WWP Sport
Autotech guts | Sure Aeros Full 3" CAI mod | CS race pipe | 18x8 TR C2 | 235/40
Turbosmart BPV | AP | Stratified | 3" dual catback | SU tmic | Autoexe springs
Do Stage 2 WMI D07 50/50 | Derale 190F fan controller
Next: NATOR down pipe
 Old 10-17-2012, 09:29 PM   #19
PPD369Speed3's Avatar
Posts: 438   (View Stats)
PPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the world
Groaned at 91 Times in 15 Posts
that 25 is the best to do. Especially if you plan on modding even further. You will get great prices. I bought an AP for 450, brand new at internals for 310, and a barely used ur test for 100. All these prices included shipping. the savings is well worth that 25.
Sent from my SGH-T989 using Tapatalk 2
2011 Speed3
JBR 3" Widepath / AT Internals / Cobb AP / UR Test Pipe / UR CBE / Cp-e TMIC / JBR 88 Duro RMM / JBR EGR Delete / JBR OCC / JBR Boost Tubes + Recirc
Freektune in progress!
PPD369Speed3 is online now   Reply With Quote
The Following User Says Thank You to PPD369Speed3 For This Useful Post:
XerocX (10-18-2012)
 Old 10-18-2012, 07:28 AM   #20
mig02's Avatar
Okay ill donate tonight thanks guys and btw just wondering what does the other guy mean by kael soob
 Old 10-18-2012, 07:33 AM   #21
Posts: 5,614   (View Stats)
Groans: 121
It's "boost leak" backwards.
silvapain is online now   Reply With Quote
ASHMS3 (10-19-2012), mig02 (10-18-2012)
 Old 10-18-2012, 07:36 AM   #22
mig02's Avatar
Wow lol thanks
HTML code is On
Page generated in 0.44055 seconds with 27 queries
