 Old 11-28-2012, 08:26 PM   #1
InfamousSpeed6's Avatar
Posts: 39   (View Stats)
InfamousSpeed6 is just really niceInfamousSpeed6 is just really niceInfamousSpeed6 is just really niceInfamousSpeed6 is just really niceInfamousSpeed6 is just really nice
Groaned at 10 Times in 2 Posts
Default Car cranks but doesn't start after valve clean
After I finished putting everything back from cleaning the valves., I try to start the car and it cranks but it won't start any ideas? Thanks
InfamousSpeed6 is offline   Reply With Quote
 Old 11-28-2012, 09:18 PM   #2
Help anyone???
 Old 11-28-2012, 09:28 PM   #3
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
welcome
 Old 11-28-2012, 09:31 PM   #4
Have u come to save me :O?
@breakfstincluded
Last edited by InfamousSpeed6; 11-28-2012 at 09:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-28-2012, 09:42 PM   #5
outshined's Avatar
Posts: 423   (View Stats)
outshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the world
cleaned valves, now wont start
Originally Posted by James Madison
[The Constitution preserves] the advantage of being armed which Americans possess over the people of almost every other nation...(where) the governments are afraid to trust the people with arms.
outshined is offline   Reply With Quote
The Following User Says Thank You to outshined For This Useful Post:
InfamousSpeed6 (11-29-2012)
 Old 11-29-2012, 02:20 AM   #6
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Keep cranking
www.tunedbynishan.com
 Old 11-29-2012, 04:11 AM   #7
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
And floor the gas
Sent from my your mom's face on my junk
07 MS3
The original Genpoo Hater
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
InfamousSpeed6 (11-29-2012), ms3blackmica (11-29-2012)
 Old 11-29-2012, 04:13 AM   #8
btstarcher's Avatar
Posts: 4,851   (View Stats)
Groans: 112
Pour a little gas onto the carburetor.
SnailTune in progress
 Old 11-29-2012, 04:31 AM   #9
rbebeau's Avatar
Posts: 2   (View Stats)
rbebeau will become famous soon enoughrbebeau will become famous soon enough
I cleaned mine three days ago, and tried to start it up and experienced the same problem. ECU threw a P0193 code (fuel pressure sensor high). I then found the electrical connection was in but not "clicked" in. Tried to start again about 8 more times, then the battery went out. Got a battery charger; started it 5 more times, and it finally got going. I'd say to check to be sure there are no codes, then keep trying to start.
My co-worker thinks the car was hung over from all the denatured alcohol I used to clean the valves.
rbebeau is offline   Reply With Quote
The Following 2 Users Say Thank You to rbebeau For This Useful Post:
InfamousSpeed6 (11-29-2012), tddvrrn (11-29-2012)
 Old 11-29-2012, 05:07 PM   #10
I took everything back apart checked all sensors, reconnected everything and then it started but now i have CEL So i have to check that now, but at least it starts
 Old 11-29-2012, 05:09 PM   #11
Nishan
FWIW every time that i pull my mani i get a bunch of codes for MAP sensor, Throttle body, etc..
Most likely just the cause of leaving the battery connected and pulling all thos sensors. Just clear them, they should all go away if everything is fine.
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
 Old 11-29-2012, 05:17 PM   #12
@ms3blackmica Awesome thanks, This forum was worth every cent plus more
The Following 2 Users Say Thank You to InfamousSpeed6 For This Useful Post:
ms3blackmica (11-30-2012), tddvrrn (11-29-2012)
HTML code is On
GM cranks up no-frills car output in China Haltech Automotive News 0 11-18-2012 05:50 AM
Coda cranks up battery-car sales after California 'soft' start Haltech Automotive News 0 09-12-2012 10:40 AM
Toyota cranks up N.A. output Haltech Automotive News 0 08-12-2012 09:10 PM
How The Fuck To Clean The Valve Intake the_rolex_guy MazdaSpeed 3/6 - ECU Computer Tuning 7 07-21-2011 04:28 PM
Ford cranks up OT to build more Focuses Haltech Automotive News 0 08-12-2009 10:10 AM
Page generated in 0.32162 seconds with 26 queries
