![]() | | #1 | ![]() |
![]() Join Date: May 2011 Location: Chicago suburbs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
(Thread Starter) | Neutral : +1 score ![]() Compared to port injection/carburated engines that have fuel going through the intake mani and then to the intake valves. Our engines have a Positive Crankcase Ventilation (PCV) system. Basically, this connects the engine block to the intake manifold. In the event that there is boost blowing by the piston rings, it relieves the pressure in the oil sump. Problem is that there is also misc. crap that comes along from the oil sump (oil, fuel, etc.). An OCC is used to prevent crankcase blow by waste from being sucked into your intake manifold, by design this is supposed to happen (very minimal amounts to be burned off) but a forced induced engines put out a lot more crankcase pressure and manifold vacuum/positive pressure then an n/a engine, sometimes/a lot of time large amounts of unspent fuel, condensate and oil vapor go through the venting system usually under boost and plume of burn off come out of the exhaust tail pipe, attributes to possibly fouling the plugs, fouling O2's and other sensors etc also some of this can be sucked into intake piping and intercooler reducing cooling effectiveness and making a god damn mess of things. I'm gathering info to help anyone with this inherent future problem....great for noobies or for people who want to prevent this problem. And this is what is caught in the OCC... ![]() And this is what happens when all that crap from above gets fried onto the intake valves, ewww... ![]() Here are few solutions to fix this problem are: 1. Delete the EGR valve: ported intake-PCV catch can-EGR delete=DONE - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum 2. Install an oil catch can(OCC): whoosh's oil catch can teaser - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum and this: Oil Catch Can ... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum 3. Set up an water/meth injection kit: How to: Water/Meth injection install - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum 4. Use SeaFoam through the brake booster hose: Seafoam - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum 5. Have the intake cleaned by a professional: BG Findashop - Search for an authorized BG service center near you! 6. How to remove the Intake Manifold on a Speed6: HOW-TO: Intake Manifold Removal - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum and from SuperSkaterxes:How-to remove intake mani + install OCC - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Torque specs for the throttle body bolts are 71-101 in/lbs. Torque specs for the intake manifold bolts are only 13-16 ft lbs !! The bolts are very small, they screw into aluminum, and there are a total of 8 bolts securing the relatively light manifold. 1/4" torque wrench is best for this. 170 in/lbs = 14 ft/lbs 7. How-to professionally decarbonizing your engine on the Speed 6: How-to professionally decarbonizing your engine on the Speed 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum 8. Why you need an OCC for the MazdaSpeed 6: Why you need an Oil Catch Can, FYI - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Important note--->Running fuel injector cleaner through the gas tank "WON'T" clean anything on the intake side.....I wish it could. Here is some info from Porsche owners having the same problem: Carbon buildup on DFI engines. - Audi engine's too. Great info here: Audi FSI Engine Carbon Build-up Megathread GM's 3.6L V6 DI engine carbon build-up issues: Direct Injection causes power loss overtime? - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com GM's Top Engine Cleaner: GM Top Engine Cleaner Replaced - GM Techlink Here's info on where to buy stuff to fix/stop/prevent carbon build-up: Water/Meth kits: AEM Water/Methanol Injection Kits - Water-Meth Injection Systems for Turbo/Super - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics and from... DevilsOwn Water/Meth: DevilsOwn Injection Oil Catch Can Kit(OCC): Home - Performance Automotive Development LLC Seafoam: Sea Foam | Motor Treatment Seafoam Spray: Sea Foam | Sea Foam Spray MOC Cleaning Products: MOC Products - Preview Information MOC Optimizer Foaming Spray: MOC Products - Preview Information EGR Block Off Plate only from StreetUnit: StreetUnit EGR Block Off Plate: MAZDASPEED 6, MAZDASPEED 3, CX-7 EGR Block Off Plate & Plug from JBR: EGR Block Off Kit MS6 [EGRBO] - $20.00 : James Barone Racing, Custom Fabrication
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. Last edited by daztdMS6; 08-21-2011 at 09:00 AM. |
| The Following 20 Users Say Thank You to daztdMS6 For This Useful Post: | AZSPEED3 (08-20-2011), breakfstincluded (08-21-2011), Code Monkey (08-22-2012), Easter Bunny (08-22-2012), Hectik1 (08-26-2011), J'sSpeed3 (08-22-2012), JNR5005 (08-21-2011), JS + MS3 (08-20-2011), kgb (08-21-2011), manelscout4life (08-20-2011), NCZ13 (08-20-2011), PunjabiPlaya (08-20-2011), Realgib3 (08-25-2011), SKiZ0TT (12-01-2011), speedms6 (08-22-2012), tddvrrn (09-03-2012), TexasSpeed3 (08-20-2011), TriO (04-01-2012), v8killer (08-23-2012), xtasy (08-20-2011) |
| The Following User Says NO Thank You to daztdMS6 For This Un-useful Post: | SpeedSixxx (08-20-2011) |
![]() Join Date: Apr 2010 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35,474
Groans: 131
Groaned at 45 Times in 17 Posts
| Not Ranked : 0 score
most of that stuff has been posted on here too, but thanks for collecting it all
__________________ Cobb SRI CPE 75 duro RMM AP - tune in progress broke ass college student |
| The Following User Says Thank You to PunjabiPlaya For This Useful Post: | daztdMS6 (08-20-2011) |
Thanks, I did this on the other forum I belong to and i just wanted to pass the info to MSF family.
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. |
![]() | | #4 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Groaned at 39 Times in 30 Posts
Im using this new product we got at work today from MOC. Its intended for DI cars as the product foams up in the head and loosens the carbon deposits. One of the techs used it on a new turbo sonata with 15k and said he could definitely feel the difference after he used it. Its definitely a product that you have to change the oil after. So this stuff definitely makes its way through the engine. Ill report back with results. I am at 57k and have never used any sort of treatment.
__________________ ![]() 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforums.org/foru...ler-you-58361/ |
| The Following 3 Users Say Thank You to NCZ13 For This Useful Post: |
![]() | | #5 | ![]() |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 180
Great collection and reminder. This is a stupid problem but it is a problem nevertheless.
__________________ 2001 Mazda Millenia S (Brilliant Black) - SOLD. Will be missed 2007 Mazdaspeed 6 (Velocity Red) - Continuing the zoom-zoom tradition |
| The Following User Says Thank You to Karmat For This Useful Post: | daztdMS6 (08-21-2011) |
![]() | | #6 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4386 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,836
Groans: 778
Groaned at 443 Times in 239 Posts
try doing research before you post info that is ALL OVER MSF.... it's called sea foam and it will fix most carbon build up problems...
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() |
![]() | | #7 | ![]() |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 933
Groaned at 35 Times in 24 Posts
seafoam doesn't do shit for our intake mani/valves... or any DI platform for that matter. I would be interested in this MOC stuff so I don't have to do this..... how to: clean your valves vol 2 |
| The Following User Says NO Thank You to Fatguy729 For This Un-useful Post: | SpeedSixxx (08-21-2011) |
![]() | | #8 | ![]() |
Rep Power: 11918 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,906
Groans: 235
Speed6killah is a Mazda tech, and recommends Mazdas own "zoom" juice, or whatever it is called. They use it to clean the apex seals on the rotary motors, and he has had quite a few intake manifolds off also.
![]() | | #9 | ![]() |
Groans: 778
sea foam doesnt do anything for DI cars?... are your retarded... oh wait you are...
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
| The Following User Says Thank You to SpeedSixxx For This Useful Post: | sleepyspeed6 (09-03-2012) |
![]() | | #10 | ![]() |
![]() Join Date: Nov 2010 Location: Lebanon, NH
Rep Power: 162 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,061
Groans: 56
| Not Ranked : 0 score I would disagree with that, I dont think anyone on this forum has seen seafoam clean valves.
__________________ Speed 3 2007: NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer. |
![]() | | #11 | ![]() |
| Not Ranked : 0 score |
![]() | | #12 | ![]() |
I just got done with it. Engine definitely feels a bit smoother and feels a bit more peppy, and I shot out a good bit of black and gray smoke out the tail pipe. Made the bays smell nice. Also got to rev the shit out of my car at work ![]() Will do an oil change at the end of the day as well. MOC Products - Preview Information
__________________ ![]() 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforums.org/foru...ler-you-58361/ Last edited by NCZ13; 08-20-2011 at 12:44 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to NCZ13 For This Useful Post: | daztdMS6 (08-21-2011) |
![]() | | #13 | ![]() |
Groans: 778
it's pointless to argue with you guys. intake valves...sea foam won't do much but it sure does loosen up some of the build up on valves.. as for the IM, again.. where does the sea foam go when you let you brake booster vac line suck it all up?.. oh shit... it goes through the entire system and it sure does clean IM's.. not to mention there shouldnt be any build up of carbon in your intake manifold.. if there is you have some serious issues. there will be some oil residue in the IM but no carbon build up except for the EGR port. I have 80000 miles on my speed 6 and I use sea foam every few oil changes. my IM is SPOTLESS.
| The Following 3 Users Say Thank You to SpeedSixxx For This Useful Post: |
![]() | | #14 | ![]() |
Groans: 778
can I ask how do you use the MOC multi purpose engline cleaner? do you suck it through your vac line as you would with sea foam or is there another method to use it.? also what is it made out of? alcohol based?... like sea foam..?
| The Following User Says Thank You to SpeedSixxx For This Useful Post: | rfinkle2 (08-21-2011) |
![]() | | #15 | ![]() |
Groans: 56
Notice Im not arguing with you about where it ends up. I simply said it doesn't clean the valves. I duno maybe it helps slow buildup on the valves....but it seems without fail that anytime someone takes a look at there valves they are covered in shit, seafoam or not. How much does it generally cost to have your vales cleaned? And yes im far to lazy to spend a whole day doing it myself.
__________________ Speed 3 2007: NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer. Last edited by kunfu; 08-20-2011 at 01:03 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #16 | ![]() |
I used the brake booster line. It comes with a trigger and hose tool to inject it into the line. On the can it says it contains xylene propane/isobutane solvent naptha ethylbenzene petroleum distillates alkyphenol ethoxylate morpholine
| The Following User Says Thank You to NCZ13 For This Useful Post: | rfinkle2 (08-21-2011) |
![]() | | #17 | ![]() |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 743 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Seafoam does clean the intake and valves. Not sure where you guys got the info that it's not. Running a can of seafoam through the intake is just what the doctor ordered for direct injection when you suck it through a vacuum hose. The only way it wouldn't clean the intake or valves is if you only used it as a fuel system cleaner, but seafoam is so much more than just that.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost 1986 Porsche 944 Turbo |
| The Following 3 Users Say Thank You to bnoon For This Useful Post: |
![]() | | #18 | ![]() |
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. Last edited by daztdMS6; 08-21-2011 at 07:55 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #19 | ![]() |
Groans: 778
please shut your mouth. as the dude that I quoted up top stated, the MOC cleaner is EXACTLY the same as sea foam and works the same and used the same. maybe you guys don't know or trust me but read what bnoon said.. sea foam works and works well, I came in here to try and correct what you guys said and maybe I came off a little rude but in the end I'M RIGHT and always new it.
| The Following User Says Thank You to SpeedSixxx For This Useful Post: | kmac (08-21-2011) |
![]() | | #20 | ![]() |
Groans: 778
I'm not sure if it's "ok" to use sea foam or any other MOC type of product at every oil change but like I said I use it every other change and for a while now.. yes when it's all done you get a SHIT TON of smoke and everyone but you thinks your car is on fire. the car def feels a bit "peppier" everytime I use sea foam... no need to take your IM off when using any product, using it as directed works great if you take the right steps. I know you can clean the exhaust valves with a shot gun cleaning kit ... the intake valves as well... I assume if you were to take your IM off to use sea foam directly on the vlaves it would work a lot better but be careful not to hydro lock.... and you can add sea foam to your oil and gas as well... do all the steps and you will have a cleaner happier motor... use at least half the bottle in the vac line, if not 3/4ths... use the other half of the bottle in your oil and your gas and then take your 15 min drive to clear the system of the sea foam or whatever... then do your oil change and your car will wanna suck you off.
![]() | | #21 | ![]() |
Groans: 778
it's been tested, been proven and is a FACT.. please hold back on replying because your opinions are no longer valid. and i'm done.
| The Following 2 Users Say Thank You to SpeedSixxx For This Useful Post: | kmac (08-21-2011), KusteLokal (09-04-2012) |
| The Following 2 Users Say NO Thank You to SpeedSixxx For This Un-useful Post: | Fatguy729 (08-21-2011), laxplayermjd (08-21-2011) |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score I know you don't have to take the IM off to use SF silly, I'm just wondering what the results are from using MOC . If some one has a borescope to peak inside the engine, the IM removal to see the valves is not needed.
| The Following 2 Users Say Thank You to daztdMS6 For This Useful Post: | kmac (08-21-2011), SpeedSixxx (08-21-2011) |
![]() | | #23 | ![]() |
Groans: 778
I agree, looking at the Intake valves before using MOC or sea foam and then looking at them again after ... you would see a diff. if you have over 50000 miles on your DI car and just started using sea foam, use it every oil change as you def need it. if you have been using it on a constant like myself you should have a cleaner motor then most. only prob I have it 80k miles on the motor and original PCV.. I must change that soon.
![]() | | #24 | ![]() |
Yeah, I would change that PCV soon.
| The Following 2 Users Say Thank You to daztdMS6 For This Useful Post: | kmac (08-21-2011), SpeedSixxx (08-25-2011) |
![]() | | #25 | ![]() |
Groans: 778
fatguy729 and kunfu..... where are your witty remarks now?
![]() | | #26 | ![]() |
I'm waiting for when you pull your intake manifold off and shit yourself cuz your valves look exactly like every other persons' on this forum.
| The Following User Says Thank You to Fatguy729 For This Useful Post: | BigjohnB20 (08-25-2011) |
| The Following User Says NO Thank You to Fatguy729 For This Un-useful Post: | SpeedSixxx (08-26-2011) |
![]() | | #27 | ![]() |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() Thanks: 0
After cleaning the IM/valves, installing an OCC and EGR block off plates, and performing Sea Foam treatment, what "other" factors will contribute to carbon build up? I know in the perfect theoretical world, we'd all have the solution to stop carbon build-up completely. However, this is not true. Thanks in advance for any insight.
![]() | | #28 | ![]() |
| ZipTie & Duct Tape Master ![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 2458 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,732
Groans: 124
Groaned at 83 Times in 49 Posts
there is no way to stop buildup. even on port injected cars with all their fancy additives in fuel, carbon still builds up, its a fact of life. only regular cleanings can remedy the situation. all of those other things only slow the process, but we cant stop it
![]() | | #29 | ![]() |
![]() Join Date: Aug 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 4 Times in 1 Post
I recently purchased a used 2009 MS3. The service records indicate that a BG Induction service was performed at 29304 miles and it currently has 38889 miles. Does the BG induction service clean the valves very well? I've been doing some reading on this forum prior to registering and have seen alot about self service valve cleaning from Sea Foam to chemtool and walnut blasting. I guess bottom line if install a OCC and delete EGR and have another BG Induction job done, will my carbon build up worries be completely over? I should read more completely....it would seem the answer is right above me. Last edited by Oldturbonoob; 08-22-2012 at 05:37 PM. Reason: possibly a stupid question that was already answered |
![]() | | #30 | ![]() |
Here's an update thread on carbon build-up: Carbon build-up on Speed 6, 3 & CX-7. A big issue
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. | |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 289 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 354
Groaned at 17 Times in 11 Posts
| Not Ranked : 0 score NCZ13 Did you ever take off the IM and examine the valves after using the MOC? I've only got 10k on the pu and haven't installed the EGR delete and an OCC yet.
__________________ '12 MS3 Black Mica w/ Tech Power: COBB AP > HTP 3.5" > ATP DP (CATLESS) > AUTOTECH INTERNALS > GFB RESPONS > NGK PLUGS OTHER: JBR 88DURO RMM > SSP >BUSHINGS > KNOB > RSB VOODOO TOON in progress (Thanks to fortressofcomfort) |
![]() | | #32 | ![]() |
So I cleaned my valves with a combination of a pistol cleaning rod and 32 cal bore brush and walnut media. Presoaked with B12 for an hour on each port. My valves were horrible. I'm talking mountains of carbon. Sorry no pictures. Took me two days to do (most of that was cleaning and resoaking and cleaning again). Either way it needed doing (cleaned the intake manifold and EGR pipe while I was at it. I idle is more even now and the car barely vibrates at all with the AC on which is a vast improvement. I haven't gone WOT with it yet but around the block impression seemed to rev up faster and pull just a tad harder. It was a pain in the |
| The Following User Says Thank You to Oldturbonoob For This Useful Post: | daztdMS6 (09-03-2012) |
![]() | | #33 | ![]() |
Yes, pain in the butt to do. However, well worth it.
![]() | | #34 | ![]() |
I did notice that my intercooler was relatively clean on the inside and the turbo inlet tube is stout and direct. I was thinking about an intake and turbo inlet, but now that I have had a good look, I just don't see the benefit of the inlet, round or oval it is all about the space for flow and the stock has plenty. The air box on the other hand...sucks. I am a noob to turbo but not to engines. I do think an intercooler with a tad more thickness and a less sharp inlet angle would be of benefit but I don't know if FMIC is the answer. Seems like a long tube distance...that would greatly increase lag, just like in an NA engine...people make the mistake of tubing the crap out of the intake...cold air at the end of a long reach...isn't going to help that much...but the ability to breath easily in an instant, that is what can make snappy throttle. I could be wrong...haven't dealt with forced induction before this.
| DI Carbon build up removal question | ztnedman1 | Gen2 MS3 General Discussion | 8 | 05-31-2011 03:12 AM |
| Dallara to build its own carbon fiber sports car? | Haltech | Automotive News | 0 | 02-19-2011 01:10 PM |
| Intake Removal....Carbon build-up? | LoresonDE | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 11-15-2010 02:18 PM |
