![]() | | #1 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
![]() Join Date: Jun 2011 Location: whittier California
Rep Power: 154 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
Groaned at 32 Times in 8 Posts
Cobbs Sri is known to somewhat cause a cel due to having a larger air straightener, you would need to do a maf cal with an AP. I think it also states in their website.... I could be wrong, how this helps. Sent from my HTC VLE_U using Tapatalk 2 |
(Thread Starter) | Not Ranked : 0 score Well Apparently I'm in the very small percentile that can't run just an intake on a stock tune in my genwon. Putting the stock air box on fixed the problem. Took it around the block and the car totally corrected itself within a matter of minutes. I'm hoping it was just my fuel trims that were fucked and not a bigger problem like fuel pressure. I went WOT and all seemed fine. Just wondering why I was able to run with this thing for a while without any problems...thanks for your input.
![]() | | #4 | ![]() |
| fastest 3-cyl MS3 ![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,560
I'm assuming that you disconnected the battery to reset the ECU before you drove with a different intake?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD Dizzy Tuned by Boost_creep in progress hopefully soon: GTX2867R or GTX3076R |
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah sure did. Even tried resetting the ECU before removing the Cobb. I was very careful to let the car re learn the trims. Didn't go WOT for probably a good 100 miles. Then all of a sudden a month later I get this shit. Its all good, I will just run stock until I can save for an AP.
| The Following User Says Thank You to AKmac11 For This Useful Post: | aanguia1 (09-30-2012) |
![]() | | #6 | ![]() |
Sent from my HTC VLE_U using Tapatalk 2 | |
![]() | | #7 | ![]() |
Nah, something went wrong; he said it was running fine for 3k miles. Something came loose or something.
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | EdgeAutosport.com (10-01-2012), trf5000 (10-01-2012) |
![]() | | #8 | ![]() |
![]() | | #9 | ![]() |
But it was fine for 3k miles. So something must have changed. P0300 is a random misfire in undetermined cylinder, not even related to the intake. The lean at idle could be but there are a few other things it could be as well. I'm still leaning toward a leak somewhere; shit can loosen up over time. Also what about the ECU wiring harness? If the clamp is rubbing against it that can cause an issue. It's highly unlikely that you would suddenly start running like shit and be throwing codes after running fine for that long. If it was in the first 100 miles or so, sure, but not after 3k miles.
![]() | | #10 | ![]() |
![]() | | #11 | ![]() |
It will run rich, no doubt about that. But the sputtering probably isn't related to the fact that you had a SRI. I don't guess you have any way to monitor? Android phone? Local friend with an AP? Honestly I would try re-installing the Cobb and see what happens. Disconnect the battery, make sure the clamps are tight and that everything is seated properly and straight. Clean the MAF sensor with MAF cleaner. Did you oil the filter or is it a dry-flow filter?
![]() | | #12 | ![]() |
![]() | | #13 | ![]() |
I've been told that the old Cobb filters are oiled, but the new ones are dry. Check with Cobb to make sure. Did you recently clean and oil the filter? Check out the Torque application in the market (I guess it's Play now). Also, one of the forum members has developed a set of PID's for our cars. You'll need to buy a BT OBDII single, but I got a cheap one (like $17) on eBay and it works fine. It's not great at datalogging, but it gives you a pretty good idea what's going on.
![]() | | #14 | ![]() |
Interesting...I'll check that out. I must have one of the older versions because it's definitely an oil filter. Thanks for the help dude. Just another good excuse to buy an AP sooner than my bank account will allow me.
![]() | | #15 | ![]() |
If it makes you feel any better, we all did it.
![]() | | #16 | ![]() |
![]() | | #17 | ![]() |
LMAO! They're working fine! I actually was running with a Cobb SRI and gutted cats for awhile without any tune whatsoever; not sure how much power I was at but it was very noticeable. With a tune it was flowing nicely. There's a thread somewhere by bioevolve you should check out.
![]() | | #18 | ![]() |
![]() | | #19 | ![]() |
Why would you ever need to stock out? I mean there's no way you're still under warranty, right?
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score LOL no definitely not under warranty. And you're right, stocking out is for pussies. But you never know, sometimes mods can depreciate the value of the car if you ever decide to resell.
